0 Members and 223 Guests are viewing this topic.
Yucca
OK, I have read through this doc of smiths:
http://www.free-energy-info.co.uk/Smith.pdf
Good reading, a few things that he says are a bit weird, like he wondered why mechanical advantage (levers, pulleys etc) had not been deemed OU? But anyways an interesting read,  I loved his wheeled suitcase with a wall socket in it, I´d like one of them if it does the business!
Quote from: bolt on July 17, 2009, 05:08:07 PM
You need to get HT supply into RF domain. > 50Khz better 1 meg or higher.
Smiths HT supply (in the annotated pic earlier in the thread) is an 8kV laser PSU, it charges the two white caps on the left that then jump the gap when they have charged high enough and then the caps quickly dump into the primary coil. His HT supply frequency will IMHO not have any bearing on the operation of the circuit, it could be flat DC and his circuit would work the same, it´s the cap and gap that creates the powerful pulses and then the coils resonate (at many MHz) after being struck with a pulse.
His gap maybe pulsing in the kHz range if he sets it very narrow, but each pulse will create thousands of oscillations in his coils. I would think you´d want the oscillations to have stopped just before the next excitation pulse occurs because there´s no way you can guarantee the next excitation pulse will be in phase with any ringing still happening. The resistor on the output stage is probably selected so ringdown has finished just before the next pulse arrives.
Note to all: high voltage resistors are quite pricey, but you can make them for nothing and they´re fully adjustable:
http://home.earthlink.net/~jimlux/hv/rwater.htm
bolt
"However there is also two earth ground points in some of Don Smiths devices probably just for pulling LF electrons for the inverter transformer tap in the final output stage, but the RF electrons enter the system via the air through the bloch wall once the resonance frequency is in the HF/VHF range thus charging the caps to a much higher potential charge."
Don't get confused a circuit showing separate earth points is normal convention drawing for common single earth and does not means separate wide apart earth feeds unless it explicit tells you to do this.
Also unlike standard low frequency tesla coils the entire purpose to use RF energizer source is so the the source TRANSMITS as E field RF will invoke ambient free electrons to some distance away RX matching coil. The left hand spin Free electrons create right hand spin B induction in to the RX coil. The energy here is in the form of VARS and so MUST be PF corrected to sustain resonance. This requires in the case of Don Smith VHF systems a bank of meaty HV caps. Just hanging a load without PF correction will kill  the resonance and the load  lamp will barely flicker.
With some careful thought you can have harmonic rich source i/p power 10 watts  5000 volt 500Khz HV supply L1 resonance to 10th octave 50 megs 50,000 volts  L2 (ratio 10:1)  go to L3  as 5Khz 480 volts (bigger winding lower frequency also ratio drops volts as PD tap)  PF correct to 50 Hz using a very large choke and some very large caps. You can do all this without any inverters just coils and caps. o/p power without even trying > 10Kw.
BTW if you stick a FWBR on the 5khz 480 volts o/p you get something extremely close to a TPU.
SM quotes i pulled out that directly relates. ALL OU RE systems are the same they are just packaged different. Just in case you cant see the connection because you have been brain damaged from years of garbage on here LOL
"So, it aint batteries and it ant radio waves, but it is electron flow
of a high order creating a large magnetic field. Or vice versa? Ha,
Ha!!!"
This discharge of magnetic energy is vary similar to the discharge
of magnetic energy during an atomic explosion. . .
Or more appropriately, the power converter technology, because that is
actually what it does you know.
It PROVES that there is an interaction between the magnetic field of the
earth and simple electrons running through wires.
It may be a small influence but it is actual OVER UNITY.
Yes it does cause RF burns.
Your interest in the harmonic resonance is also stepping toward the
right direction of things.
depends on your viewpoint about exactly what
harmonic resonance is and how it relates to mag fields and
converting energy as does my power unit.
The multiple frequencies traveling around the coils are of too high
a frequency to provide for any motive effort.
They are only a means to achieve an end.
The multiple frequencies begin to feed themselves and the
multiple kicks become a combined big kick.
I call it resonating.
There is a book about Nicola Tesla "The Man who Had lightning in his
hand".
I suggest that you find a copy of that book and read it."
Many combination here read Don Smith pdf five times you get the hang of it dead easy:) Everyone can do L1 and make sparks but only 1% understand RF and PF and that's the only place you find RE OU.
nievesoliveras
Quote from: rensseak on July 17, 2009, 01:53:50 PM
May be this one?
http://danielwebb.us/projects/pd_tech_books/
It is, the only problem with that one is that the screen is sideways.
This one has the screen photos straight.
http://rawfire.torche.com/%7Eopcom/tbe/the_boy_electrician.pdf
I found the link again!
Quote from: HeairBear on July 17, 2009, 06:51:48 PM
I have it, but, it is 40MB! Does anyone have a place I can upload it too?
There is a place, I dont remember the name now, but it sounds something as mediafire or something like that.
Jesus
Edit:::
Yes the place you can upload the file is  http://www.mediafire.com/
You have to fill some information pages first.
Jesus
xenomorphlabs
QuoteMany combination here read Don Smith pdf five times you get the hang of it dead easy:) Everyone can do L1 and make sparks but only 1% understand RF and PF and that's the only place you find RE OU.
Very true and that is 99% of the job to see anything unusual with this setup. And it will take a lot of brain and research to replicate that part hehe. Smith has studied that field all his life, hard to comprehend for people that don´t have that  (professional background).
QuoteHis HT supply frequency will IMHO not have any bearing on the operation of the circuit, it could be flat DC and his circuit would work the same, it´s the cap and gap that creates the powerful pulses and then the coils resonate (at many MHz) after being struck with a pulse.
I share your opinion, there is nothing in that particular device that indicates the application of HF to run the initial inverter. Smith has hinted to that in other device schemes, but in a simplified form just showing a tank in front of a transistor, but it´s o.c. not that easy.
Spark gaps were used in the early radio days as HF transmitters and can generate very rich HF.
My camera didn´t like it  ;D
Smith states that he used the 2 caps just for slight oscillation frequency correction since with the correct dimensions everything should be close to resonance already.
QuoteNote to all: high voltage resistors are quite pricey, but you can make them for nothing and they´re fully adjustable:
Cool that might work, but the hard part is to find a 100 kv bridge that switches in that nanosecond range. There is some 80kv ones out there for around 100 euros, but not sure if they are that fast.
And a cap bank like that is also quite expensive hehe.
the_big_m_in_ok
It is, the only problem with that one is that the screen is sideways.  This one has the screen photos straight.
http://rawfire.torche.com/%7Eopcom/tbe/the_boy_electrician.pdf ... I found the link again!
I'd like to look at the file, too.  But the whole thing on my available industry standard American IP servers renders a 200 MB file in its entirety.  I've never gotten a file that large to run.  The computer often gives some kind of error---like "data under-run" and then stops.  65 MB was the limit on a good, fast system and a commercial/university grade data line.
Can it be subdivided into smaller files?
Edit:::
Please (!) try and rework the file to smaller PDF's.  American systems I use are often limited in speed and size.
--Lee
