0 Members and 266 Guests are viewing this topic.
core
Quote from: iflewmyown on November 15, 2010, 09:41:51 AM
@ Core
You said
Ok read that paragraph again. Tesla is claiming OU. He states that with a 1 kilowatt generator he can produce 5kw of power.
YOU should read it again. ;)   He states that with a 1 kilowatt generator he can produce 5000 kw of power.
Also, I have owned Tesla's book of patents for over twenty years, the book of his deposition for the patent fight, and read all of his books that I could lay my hands on since the fifth grade of elementary school. The most intriguing part of all  is the point referenced above. Is Tesla saying?
1. I can produce the 5000 kilo watts from 1 kilo watt input for the same amount of time and thus create overunity. That is, I input 1 kw for one hour and output 5000 kw for the same one hour. A gain of 5000!!! ;D
or
2. I can produce the 5000 kilo watts from 1 kilo watt input for a proportional amount of time and thus create unity. That is, I input 1 kw for one hour and output 5000 kw for [one hour / 5000] or  .72 seconds
:(          Said another way... A flash bulb will blind you for a long time although the total light output per hour is tiny.
My hope is that number three choice is valid.
3. By using the 5000 kw effect some material will exhibit an effect that will let us obtain free energy. Such as a core being aligned by a super pulse of tiny total energy (5000 kw for an instant) that resumes it's old alignment and creates our much larger current for us.
If I modify my car alternator to produce 5000 times the energy that it does now, it would melt and I think Tesla would have noticed his equipment melting. So I think he was pointing to magical effects created by a huge pulse of a very short duration.
Garry
@Garry,
  Your asking me to read it again because your speculations don't fall inline with my words? Simply because you have 'owned Tesla's book of patents for over twenty years' makes you an authoritative figure on the subject?
Since you are such a 'Grand Master' of Tesla you most likely already built a 'Impulse Generator' to Tesla's spec's. Could you answer the following questions.
How are you powering your Tesla coils?
Could you please share your drawings of your Impulse Generator?
How exactly are you breaking the wave at the peak?
What timing device are you using?
Are you using 60hz or 300 c.p.s. input wave?
Is it mechanical, as in the patents?
I'm sure with your 20 years of research you must have the best 'impulse generator' going. I look forward to reviewing your work. My 2 months of research pale in comparison to your 20 years.
I eagerly await your reply.
Respectfully,
Core
iflewmyown
@ Core
you said "Character assassinations are the signs of a desperate idiot"
Your method of debate is to use sarcasm? Your ego stated that you are the only person on the planet who correctly reads Tesla's words.
Your sentence "Tesla is claiming OU. He states that with a 1 kilowatt generator he can produce 5kw of power" is wrong. I gently pointed out that Tesla himself stated a gain 1000 times more than your sentence stated. I pointed out that Tesla claimed 5000 KiloWatts from a source of 1 KiloWatt. You were happy for a 5 times increase. Why are you not happy for a 5000 time increase? Many beginners confuse watts with watt hours. I suggested Tesla's words could be read two different ways. None of Tesla's contemporaries created free energy nor any of the people who tried since except maybe Kapanadze. I have not created free energy with 20 years of experiments so I eagerly await your machine. You said I was a Tesla master.  ;D  Thank you. I only claimed to be someone who could read.
Garry
forest
 ;D don't play bad games
core is right and here is the essential explanation by Tesla what he was doing :
"The radio men who came after me had the problem before them of making a bell sound, and they immersed it in mercury.  Now, you know mercury is heavy.  When they struck their bell, the mercury did not permit it to vibrate long because it took away all the energy.  I put my bell in a vacuum and make it vibrate for hours.  I have designed circuits in connection with an enterprise in 1898 for transmission of energy which, once started, would vibrate three years, and even after that the oscillations could still be detected.  Professor Wein's theory is very beautiful, but it really has no practical meaning.  It will become useless as soon as the inefficient apparatus of the day, with antennae that radiate energy rapidly, [are] replaced by a scientifically designed oscillator which does not give out energy except when it gets up to a tremendous electromagnetic momentum."
So!?  He took 1kW impulse and make it vibrate for a long time without much losses and each period of oscillation  created an ambient response or roughly 1kW, that accumulated because of incoming SYNCHRONIZED impulses generating continuous oscillation.That obvious if you read another excerpt:
"Then I had a sensibly damped wave because at that time I still was laboring under the same difficulties as some do this dayâ€"I had not learned how to produce a circuit which would give me, with very few fundamental impulses,  a perfectly continuous wave.  That came with the perfection of the devices.  When I came to my experiments in Colorado, I could take my apparatus like that and get a continuous or undamped wave, almost without exception, between individual discharges. "
and another one:
"This is one of most beautiful things ever produced in the way of apparatus: I take a generator of any kind.  With the generator I charge a condenser.  Then I discharge the condenser under conditions which result in the production of vibrations.  Now, it was known since Lord Kelvin that the condenser discharge would give this vibration, but I perfected my apparatus to such a degree that it became an instrument utilizable in the arts, in a much broader way than Lord Kelvin had contemplated as possible.  In fact, years afterwards when Lord Kelvin honored me by presenting to the British Association one of my oscillators of a perfected form, he said that it was "a wonderful development and destined to be of great importance." "
baroutologos
Hey Core,
not mad so far my friend. Now you said it, i remember. I was confused by Cosmo's experimental setup and that's the reason i asked you to redo the experiment.
Sorry about that. Its a nice experiment but of nothing new.
Yes, the HV charging a cap to a voltage level and then breaking the SG giving a series of electrical vibrations is standard Tesla method.
No, i am the one who constantly criticize people for claiming OU in every single occasion witout it to be.
And yes, reading is fundamental but when comes to Tesla methods, it has not been added anything since a century and i have read enough materials to formulate an opinion of what is going on regarding HF transformers. :)
Perhaps you will enlightens the rest of us :P
see you
