0 Members and 168 Guests are viewing this topic.
energia9
http://www.rexresearch.com/prentice/prentice.htm
original patent from sept, 18, 1923 by Frank Wyatt Prentice, my coil resonated at the exact frequency of 500 khz, i didnt know this patent before, now i know why 500 khz is a harmonics that i have experienced too.
core
I believe this was posted here back when Clinton was president, found it on another site and re-posting it. Clearly very similar to what has been spoken but with a little more detail.
I haven’t experimented with ferrite cups, however, a ferrite rod turns into a permanent magnet quite easy: bring a small magnet to one end and apply HV impulses (pulse) to a coil  (150 windings of ПЭЛ-0.35) wound around the core. The remanent magnetization is evident: tangibly attracts a screw driver (well, not a Neodymium but nevertheless). It’s preserved for a long time â€" I checked it after two days â€" still there. A ferromagnetic material which is magnetized in this way can be returned in its initial state (demagnetized) by again applying a HV impulse to the coil without this time bringing a permanent magnet or by causing a reversal of poles by bringing the magnet to the other end. This has been checked personally, practically, more than once.
OK, then wind on a piece of ferrite a two-step autogenerator with an inductive primary coil (it will readily set itself in resonance in different situations) … also another small coil on this core â€" which we will connect to the primary high-voltage transformer (no diodes, no constant current) … Then, on top of this transformer we’ll place an inductor in the form of a thick copper tube … And we’ll apply HV to that inductor through a meager discharger (inductor should be placed over the coil on the correct side so that it won’t coincide in phase with the autogenerator) …
What did we get … Here’s what we got â€" autogenerator, by its coil, magnetizes the ferrite in the necessary direction â€" and here, the discharger  KA-BOOM into the inductor (with the correct direction, naturally) â€" and the ferrite OOPS has become a S-N magnet (at that we spent almost nothing to achieve it) … now the autogen has chased the impulse in the other direction â€" and here, the discharger KA-BOOM into the inductor … causing the MAGNET to re-magnetize into N-S … and that’s how it goes cyclically (no discharges would be seen, only a silent ARC … well, at least this is how it appears)
And here we’d like to obtain 50 Hz and not 500-900kHz … we take the HV transformer (we att 50Hz to the frequency of the autogenerator) … that is, every KA-BOOM of the discharger will be different in amplitude … At the output there will be a miracle slapping at 50Hz
Oh, well! There’s also one more question how is to utilize this? â€" well, correct â€" we can’t wind on top, a pile of harmful phenomena for us! .. While it’s need that we glue small circles in a column â€" and wind on them .. while we take of  the load by the Zatzarinski method â€" with his degenerate transformer (however, without that copper winding) … and just squeeze a thicker copper through the ferrites.
Here’s an immediate question â€" where can the necessary quantity of free charges be found in copper to supply 5kW. What do we need ground for? (yes, any massive piece of iron; we’ll just push them here and there, won’t take them away forever) …
This Kapanadze called â€" autoresonance of the primary and the secondary …
And, do you know what the magnetic field must be created â€" so that the ferrite becomes a magnet without further application of external magnetic field? A rod of 8mm diameter and 2cm length needs on the order of approx. 500W !!!
And when spark is applied only 1W is needed.
The main idea is that we initiate the process from without the toroid (the column of rings) â€" while we take off the load inside the toroid … And that isn’t Zatzaricin any more … we throw out that copper winding … in our case the role of output coil is taken by that thicker cable squeezed through the rings …
Without 5Hz â€" ground isn’t necessary … there are enough free charges in the copper to spread HF … you’ll have enough lamps as load (they shine normally at HF) … and to make it self-sustaining NF needs to be rectified through diodes and decrease …
You don’t at all want to accept the fact that magnetic field of the inductors and the magnetic field of the autogenerator coils have to be strictly synchronized … that is, the mutual influence in TAM transformer, on the contrary, is the reverse … this is exactly what SR wanted to tell you with his transformer experiment (applying HV) â€" so, when the frequency of the discharger coincides in phase somehow with the frequency of the transformer + the domains of the transformer â€" that’s when the lamp begins to shine brighter.
Respectfully,
Core
poynt99
Quote from: core on November 17, 2010, 08:07:46 PM
Respectfully,
Core
Any idea who this "toptamburg" fellow was? Seemed to have some direct inside information.
.99
core
Quote from: poynt99 on November 17, 2010, 08:48:22 PM
.99
I have no idea. Maybe just another mysterious person with the 'one post and out' routine. I had no idea that his name was 'toptamburg'. Cosmo did show us a picture of a coil in his ferrite this person talk about that. Cosmo also spoke about magnetizing the ferrite. This guy said the same thing.
The last three paragraphs are interesting, sounds like A/C voltage used for spark gap, feeds a coil then feeds a full wave bridge as a 'feedback' circuit. Maybe this post will help.
Respectfully,
Core
core
Would a 'two-step autogenerator' be just a basic primary/secondary setup? any idea's. Also sounds like there is just a straight high voltage coil wrapped around the ferrite.
Respectfully,
Core
