0 Members and 404 Guests are viewing this topic.
scratchrobot
QuoteIt seems that things went wrong when we were trying to imagine a closed system. That is something achievable only in theory. Because every system existing within this universe is in constant and continuous exchange with the rest of the universe. And how this universe is made, what it consists of and how it functions, we have not even remotely begun to understand.
Josef Hasslberger
Rome,
8 May 1993
energia9
Quote from: scratchrobot on November 18, 2010, 02:22:15 PM
but this universe is not the way we understand it, closed system is reffered to closed loop where no other energy is converted, i remind people that we are Converting this kind of energy, not making it, i think all of you know this,   a closed system can not gain energy otherwise tuned to a source like in radionics, the door is clear but since inductance resistance and capacitance relates to how our circuit works in tune with this source is critical, and if you cant calculate them out just as in radionics, you will not get any kind of signal. read MR Prentices patent, at the time of 1923, people had to proove that their device worked.  that device worked and if you look in the circuit diagram you might be able to copy some of its really basic designs, and you will finally understand why frequency stability must be attained, and why it is the most important thing as i have stated it in previous comments,  the light bulb or any other device will become a part of the circuit and it will affect the frequency, this must be solved by a frequency stabilizer as it is allready  stated in mr Kapanadzes patent. also if you dont use any load the coil itself acts as a load if you try to hook it back,  all the circuit must be in the correct resonance with its source
penno64
@Core
Would you agree that we are moreover attempting sr173's system (ferrite) over tariel's (aircore)?
If so, your comment regards HV through the centre would, if you watch the 173 video, appears
to run through the centre and join onto the earth/ground wire.
As I always do silly things, I had an air coil setup yesterday morning that would light leds without
a spark, simply including the main winding of the coil in series with the primary of the flyback.
I am trying to recreate this setup, thinking that this particular coil is resonating, and then add the
hv spark and see what I get.
Penno
p.s. I feel that after the info you provided, watching sr's video, seems to bring things together.
core
Quote from: penno64 on November 18, 2010, 04:33:17 PM
@Core
    When I first started on this forum I subscribed to the mindset that SR and Tariel had the same device. Now I am more leaning to them being two different devices. I would say that SR's device can never reach the power that Tariel delivers. Of course that is speculation based only on the one SR video. SR only filmed one video as far as I know, why he did so is unclear to me. How SR and Tariels devices operate are still a mystery even if you stumbled upon the correct 'theory of operation' and built a device you still would not know unless someone 'in the know' told you so.
I am willing to bet that if someone does stumble on that magical theory and starts displaying impressive results via experimentation you will hear of a 'big announcement'. The last thing I imagine both Tariel and SR would want is someone else making the discovery and staking claim to it.
   Not sure what info specifically you are referring to but I spent all day at work thinking about the 'split core' theory. I have to say I like the concept and may move it up on my 'things to do list'. We can think of the split core as one side a transmitter the other side as the receiver. A typical receiver would require a 'tuning' capacitor to capture the electromagnetic wave from the transmitter. In the case I outlined the HV on the inside of the core material runs the entire length. It's frequency I imagine has to be at one of the resonant frequencies of the ferrite. Due to it running the length of the split core it will 'automatically' tune the antenna side (driven side) to the transmit side (driver) kinda like a 'self-tuning' system.
   Also based on my most recent theory stated in my last post I believe getting a magical 60hz or 50hz may be easier then we think. The biggest problem may be the type of ferrite used. I believe there is no 'one size fits all'. Again nothing but speculations.
   On another note. about 5 weeks ago I spoke about 'tube-in-tube' heat exchangers in fluid system. My concept at the time got a thumbs up from Cosmo. Indecently the concept of the HV inside the ferrite with the lower energy coils 'on-top' falls right in line with the 'tube-in-tube' heat exchanger that commonly seen in fluid systems.
   Anyway until the theory is backed-up with experiments its all BS talk.
Respectfully,
Core
core
Quote from: poynt99 on November 18, 2010, 12:23:33 PM
Core, this was also posted in April 2010 by Omnibus here:
http://www.overunity.com/index.php?topic=7679.msg238192#msg238192
I've moved that OUR thread from "Inductors" to the appropriate Kapanadze thread here:
http://www.overunityresearch.com/index.php?topic=237.0
.99
.99,
   I like the layout of the forum is it yours? I haven't applied for membership yet.
Respectfully,
Core
