0 Members and 275 Guests are viewing this topic.
energia9
milnichenko also says frequency is around 1 mhz, back to my experiment where i have disconnected the source the frequency was in this range, stability was gained as long as i have not moved my coils, i dont know guys what you believe or not, but i know what i saw and i would like to help, please read my previous posts i posted where i disconnected frequency generator and lamp still burned, i could not replicate my own effect after that, this is what im telling for ages now, nobody listening??
there was NO iron in the experiment, it deteriorates apparatus, yes i do know and its not a belief that Tariel kapanadzes device do NOT use any kind of iron from my own experience.
core
Quote from: energia9 on November 18, 2010, 06:52:14 PM
What does the 1mhz come from? I doubt there can be only one frequency. It's resonant frequency would require taking the weight of the object into consideration.
I looked at your wiring diagram of your experiment. Do you have access to a camera? possible take some pictures? or video? I am not exactly sure what help you are asking for. Sounds like you have a different set-up. Maybe a new 'thread' is in order so that you can keep all your information condensed in one spot.
Respectfully,
Core
energia9
Quote from: core on November 18, 2010, 07:47:35 PM
Respectfully,
Core
the frequency depends on atomic weight of the copper  and lenght of the area, But the resonant frequency allways stays on the same level no matter how long wire you use or what thickness, it stays above 800 khz in that particular experiment i have done,
penno64
@energia,
I think I am correct in saying that the frequency(ies) generated via the spark gap can vary greatly.
I wonder if you happened to get lucky on that one time.
I know from my own setup, simply two copper wires inserted into a block of timber, changing the
size of the gap, vastly changes fluctuations in light output.
Penno
ter
to cosmoLV
where is your promised *revelation* circuit/schema/diagram that would SOON be released THIS month?  ::)
WE are all ready to understand it now...
