0 Members and 379 Guests are viewing this topic.
Goat
Hey guys...can anyone look at the coil and circuit setup discussed in the following thread... @ the_big_m_in_ok seems to think that's it's a  "Kapanadze-style grounded output setup."....might be relevant to this thread.
Quote from: the_big_m_in_ok on November 19, 2010, 06:12:16 PM
I went through most of the scribd e-book until I got to the full schematic near the end(pg. 54 of the manuscript.)  Looks like a rotoverter AC-type of arrangement with the output connected to a twin coil Kapanadze-style grounded output setup.
(Look at the scribd book near the end and you'll see what I mean.)
I would simplify the whole thing by replacing the AC input with a heavy duty signal generator that varies the voltage and frequency to the Kapanadze coil.  Then experiment with maximum available output.
--Lee
Regards,
Paul
LtBolo
Quote from: energia9 on November 20, 2010, 09:09:58 AM
i do not know what happens when these effects happen, cannot see inside the nucleus....  but if its going to work, after that we can have speculations. NOT now.   carry on experimenting must be our word for now.
best regards
Blind experimentation has gotten us nowhere, and clearly the effect is difficult enough to reproduce that you were unable to get the same assembly to work twice. I would think that coming up with possible explanations, then experimenting with them, is exactly what needs to happen.
More to the point, I was hoping that you could elaborate further on what your exact setup was. Since what you did worked briefly, some of the important characteristics must be included in what you did. It would help us all greatly if we knew what those were.
LtBolo
Quote from: baroutologos on November 20, 2010, 03:24:02 AM
Many people from times to times, since they heard SR's waffles about NMR, ferrite domains and so on, claimed they achieved experiments with ferrites that are completely undocumented (as Cosmo suggested) and novel and help towards OU creation (if still so, i do not perceive how).
On the subject of NMR, I was doing a bit of reading last night about Earth Field NMR. I would have expected the resonant frequency of atomic structures to be very high, but in fact, NMR is looking at proton relaxation times, which in the weak magnetic field of the earth, is actually at very low frequency. The magic number for a proton is 42.576 Hz/uT...which in the earth's magnetic field of 50uT, makes hydrogen a bit over 2KHz and iron about 69Hz, for example.
I'm not a mechanical engineer, but I think increasing the magnetic field strength is the same as increasing the spring tension in a mechanical resonator, which in turn raises the frequency and changes the mechanical Q. Cosmo's entire experiment involved a low voltage AC or DC current together with a high voltage high frequency spark. Looking at that from the standpoint of NMR, the low voltage coil is tightening the string, and the high voltage coil is plucking it. It isn't hard to see that there is a combination of both that would produce a change in the ferrite that affects its ability to carry a magnetic field, and by extension, its permeability.
I'm not sure how that translates into free power, although it seems that parametric variation is still the likely answer.
energia9
Quote from: LtBolo on November 20, 2010, 12:49:09 PM
Here is my own website  http://feny555.blogspot.com/    you can visit it any time, i make experiments every day now and update it often,   thanks
i have also created a social network with forum only concentrating on source current (tariels device) apologize if calling tariels device source current, i cal it this way and so here is the website  http://kapanadze.spruz.com/      this place is only for those who experiment, of course everyone can register, but i want this site a progressive one, and here we can help eachother.    now you ask why?  because overunity has all the subjects topics and even people who dont do anything just post misbelief, so in this site you will see progressive work, thank you
