0 Members and 397 Guests are viewing this topic.
core
Here is something that will make you laugh.
  If you recall Cosmo shared a link to his website way back on page 200 something. here is the link http://www.umbrellatech.lv
  Well I was watching the movie 'Resident Evil' and saw something eerily odd. I started to wonder why someone would steal a logo and company name from a Hollywood movie? Maybe it's just a bad coincidence. I don't know.
  What I do know is that I have tried to recreate the first experiment. I can't get the ferrite to 'de-magnetize' like Cosmo said. I have tried Russian 2000 perm. rings, American 2000 perm. rings, Ukraine ferrite rings. I have been able to adjust the frequency on my HV supply (4kv A.C). I get 'no' results. I can get a silent arc with very high frequencies but it does nothing.
  Anyway enjoy the photos.
Respectfully,
Core
The first pic is from Cosmo's website the others from the Hollywood movie Resident Evil.
LtBolo
Quote from: core on November 22, 2010, 12:42:03 PM
Some thoughts on this:
1. I'm pretty sure that the basic principle is NMR.
2. The NMR frequency is a moving target based on the static magnetic field strength.
3. The higher the static magnetic field intensity, the higher the NMR frequency and the higher the NMR resonance Q.
4. At earth's magnetic field strength, the NMR of iron (and by extension, ferrite) is very low, and the Q is too low to be useful.
5. Somewhere between nothing, and a whole bunch, the Q will become high enough that NMR will persist long enough and strong enough to disrupt ferrite's ability to carry a magnetic field.
6. If the string is stretched tight enough, and it is plucked hard enough, it will ring and the exact frequency is irrelevant...just so it rings long enough to provide parameter change for the period I need it.
So, when looking at Cosmo's experiment, the low voltage high current is there is stretch the string to raise the Q. The spark discharge is plucking the string. Only when both are present, and at the right levels, will the effect manifest. What are the right levels? Not sure. I'm thinking the 4kv Cosmo suggested is probably high enough for the spark. Big question is the magnetic field strength. The specific current probably isn't relevant, only how strong the field is....which is dependent on the material, dimensions, number of turns, etc.
We found it interesting that when we hit one of our ferrite devices with a very stout spark, we saw sparks coming out of the ferrite itself. Ferrite isn't suppose to be conductive, however, I wonder if when the nuclear resonance is happening if it actually changes the conductivity of a material...rendering non-conductive materials conductive. If such were prone to increase conductivity, it might even render copper more like a superconductor...
core
Quote from: LtBolo on November 22, 2010, 02:56:19 PM
  I agree with you. But the problem is that there could be hundreds of variables most specifically with materials and dimensions. In short it may work with 15 rings but not 16 rings. Worse then that 16 rings may require a larger or smaller magnetic field then 15 rings. So basically it's 'pot luck'.
  Actually ferrite becomes EXTREMELY conductive when subjected to high voltage and high frequency. So much that the voltage bleeds right though the ferrite and a sustained spark can be had. It does not matter if it's A.C or D.C.
  Look at these video's on my YouTube page. There are no wires connected to the high voltage. Two very short, separated, copper spirals are connected inside the ferrite. I can sustain a arc across the rings. I can not do this with steel tube.
http://www.youtube.com/watch?v=BkXmlKHIZ88   This is the D.C. spark
http://www.youtube.com/watch?v=TN4aVCYiHx4   Same thing but with A.C.
  Also I have been able to get, with D.C. only, the sparks to come out of the ferrite. The sparks I see are 'yellowish' in color. Kinda looks like when you take a grinder to a piece of metal but not nearly as many.
  Anyway none of that stuff has been spoken about by Cosmo. He made it very simple:
  - Wrap HV wire around ferrite
  - Wrap another coil as load. (A.C. or D.C.)
  - Result ferrite loses its magnetic ability.
Anyway for what its worth the HV bleed through is kinda cool.
Respectfully,
Core
core
  On the topic of 'bleed' through of high voltage. I am not sure if I stated this on the http://www.overunityresearch.com/index.php website or here. I close look at SR's device show's he is not using the correct wire for HV. This implies that he is getting massive bleed through from HV into LV. On my end I have been able to take a 110 volt .5 amp A.C signal and bleed through some high voltage to create 150 volt .5 amp signal. The issue is trying to use this.
  This leads me to believe that the SR device is a 'Bleed through' concept. So the secret is not in the ferrite but in using the dirty signal.
Respectfully,
Core
baroutologos
Nice theory Ltbolo, but who told you in the first place that NMR spoils ferrite's properties?
You just speculate. Secondly, CosmoLV suggested an experiment looking to SR device, with simple means and described an effect. This proved to be nonsense.
When asked to give guidelines to see the effect, he told about our imcompetence, lazyness and generally avoided to give any help.
COsmo has made a series of statements. He told Kapanadze device works upon Magnetic Amplifier setup. I did experiment with MAG-AMP setups. Those are nice experiments but in what sense they are used for energy creation?
I have asked COsmoLV about Kapanadze's weird green box of 5Kw. Kapanadze device's suck power from earth. No earth, no power. ANd they suck it at low frequency (at least is seems so) and high amperage. I told Cosmo, how is it possible to move such hige currents at low frequency to a plain standing device. This would required an enormous single terminal capacitance.
He proposed the mop analogy, that a specialty made coil, sucks huge current in it. This is a capacitor actually. How a coil can become an enormous capacitor with a single terminal?
Weirdness upon weirdness. (Or in square) If you guys want my view do not even mention Cosmo again. He is a failed (as we are all) Kapanadze experimenter who perhaps has done some interesting setups, achieved nothing of value and now wonders from forum to forum to give advice.
@COre,
I also have noticed that my Russian ferrites conduct electricity also. (if you look back at Cosmo replication experiment of mine you will see) I firstly draw sparks to my finger and then i realized that. I measured resistance with DMM and found that a aring from end to end will have a 20Kohm resistance.
