0 Members and 401 Guests are viewing this topic.
forest
Quote from: baroutologos on November 23, 2010, 02:05:33 AM
Nice theory Ltbolo, but who told you in the first place that NMR spoils ferrite's properties?
You just speculate. Secondly, CosmoLV suggested an experiment looking to SR device, with simple means and described an effect. This proved to be nonsense.
When asked to give guidelines to see the effect, he told about our imcompetence, lazyness and generally avoided to give any help.
COsmo has made a series of statements. He told Kapanadze device works upon Magnetic Amplifier setup. I did experiment with MAG-AMP setups. Those are nice experiments but in what sense they are used for energy creation?
I have asked COsmoLV about Kapanadze's weird green box of 5Kw. Kapanadze device's suck power from earth. No earth, no power. ANd they suck it at low frequency (at least is seems so) and high amperage. I told Cosmo, how is it possible to move such hige currents at low frequency to a plain standing device. This would required an enormous single terminal capacitance.
He proposed the mop analogy, that a specialty made coil, sucks huge current in it. This is a capacitor actually. How a coil can become an enormous capacitor with a single terminal?
Weirdness upon weirdness. (Or in square) If you guys want my view do not even mention Cosmo again. He is a failed (as we are all) Kapanadze experimenter who perhaps has done some interesting setups, achieved nothing of value and now wonders from forum to forum to give advice.
@COre,
I also have noticed that my Russian ferrites conduct electricity also. (if you look back at Cosmo replication experiment of mine you will see) I firstly draw sparks to my finger and then i realized that. I measured resistance with DMM and found that a aring from end to end will have a 20Kohm resistance.
You can make a small version of mop-like circuit using Avramenko plug, capacitor and antenna.Connect antenna to the source of longitudinal (?) waves and see how slowly capacitor is charged. Then place a good ground connection to it and see how fast it become.
I suspect that with bifilar capacitance and very abrupt high voltage longitudinal wave it will be able to suck enough electrons at high frequency.
LtBolo
Yes, I am speculating, but it is based on a bunch of experiments. I wouldn't be quite so quick to throw out the idea, nor would I call Cosmo's experiment nonsense.
One thing we have observed over and over here is a strange saturation-like behavior when a spark is discharged into a coil around ferrite. Two things are present when that spark happens: 1) a strong magnetic field, and 2) a sharp transient...both of which are required for NMR.
Is that the answer? Still can't say, but I'm not ready to throw it out yet. If you have other theories, I'd love to hear them.
baroutologos
Het Ltbolo,
No offence meant by that. We are all speculating here. The thing that i cannot personally tolarate is people around presenting ideas and widely circulated speculations around the Net as facts. (not you my friend since you more that once told its all about speculations)
By the way, as repeatedly said, assuming that you could alter ferrite's magnetic permeatability from 2000 to 0 or so under "magnetomotive force" by the NMR theory application, then readily you would have a magnetic transistor which will allow and disrupt magnetic flow on demand, thus creating electricity similarly to a common transformer by the use of permanent magnets. Not yet the case i am afraid.
@ Forest,
I know what you mean. An AV plaug to an antenna, other end grounded or not and filling a cap. By this way we are talking about Mhz frequencies that utilize the small (pF) single terminal capacity of the circuit, thus filling the cap. Kapanadze as it seems (by the clamp meter) utilizes low frequency electricity. By doing that the single terminal capacity of the whole apparatus is way too low for achieving such huge amperage. (repeatedly said)
Personally i cannot formulate any theory based on what i know and have seen from Kapanadze device, since it make use of different bizzare electrical elements that exhibit weird behaviour (e.g grounded cable)
energia9
Quote from: baroutologos on November 24, 2010, 02:38:00 AM
Het Ltbolo,
@ Forest,
This whole overunity website is a giant speculation, and no working devices in any area, sitting front of the computer and not experimenting is the real waste of time,     Experimenting blindly is the way my friends wheter you want it or not, all of the inventors achieved their machine by experimenting blindly, this is how you can really understand the real operation of this device,   if the inventor of transistors would have theorised he wouldnt achive anything, instead they tried connections, every possible ones, this is how the world will operate, a ground without knowing where to connect will lead you nowhere with theories, if you try the closest possible connections to those infinite you shall find your answers,
Best regards
