0 Members and 467 Guests are viewing this topic.
the_big_m_in_ok
Quote from: Shokac on November 10, 2010, 06:55:15 AM
Look at the current source!!!
(Referring to the drawing on posted Reply #4481)
Have I figured it out?
Solder a diode between the 'Interruptor' and the positive side of the battery.  The anode goes to the positive side of the battery.  That will prevent ring back voltage spikes from frying your relay contacts by BEMF/CEMF back to the relay coil.
Was that what they were getting at?
--Lee
grizli
Quote from: cosmoLV on November 24, 2010, 11:20:21 AM
By the way, Trigger coil is the output power coil, look at the Turkish device and how are coils build...
you need to think backwards and look outside the box
So you claim output it capacitively/ electrostaticly coupled like in this flash device ?
sigma16
Quote from: CosmoLV
CosmoLV you suck!  I posted Grumpy's idea for capacitive collection over a month ago and you were too busy with your worthless ferrite bullshit to even comment on the idea.
That approach requires the inner cable inside the coil to be grounded, not just an outer coil for collection, and there is no damn ferrite in the core!  If you are going to steal an idea, at least get it right.
Here it is again:
core
Quote from: cosmoLV on November 24, 2010, 10:22:08 AM
To make a go this little bit faster, this is the High voltage side principle (it is based on this) maybe it look funny, but that's it...
Take the mirror and look on Tariel's device â€" Good luck!
  Here's the first strange statement. Cosmo has stated that SR's device and Tariel's device are different. So now we are back to talking about Tariel's device  ???
  What does ferrite have to do with Tariel's device  ??? As you can see more confusion.  Cosmo has also stated that parameter change was important in ferrite. Question: 'Does Tariel use parameter change in ferrite?'
  Cosmo has stated that he has a 400watt unit and that getting more is difficult. His device is limited and is unclear if an inductive load can be operated. His device is limited most likely due to the switching. So for him or SR to get 1kw or more power they would have to switch that much.... good luck. Tariel does 3kw with ease.
  SR speaks of 'black matter' that has nothing to due with Tariel's device. Tariels 'green box' is as big as Cosmo's suitcase device. But Tariel outputs something on the order of 3kw, Cosmo 400 watts???
  The 'spark gap' from SR's unit absolutely different from Tariel's.
  Cosmo speaks now of talking with Tariel 'face to face' a month ago he stated he has only spoken with Tariel on Skype. If he has visited Tariel since making the 'Skype' statement why does his computer log into OU.com on a daily basis? Do you really believe he's over Tariel's house and logging into OU.com?
  I firmly believe Cosmo does not know how Tariel's device operates. At best he can only speculate just like everyone else. I think he is waiting for a 'ah-ha' moment to come from someone. The more minds working at the problem the faster it gets solved.
The big question 'Why build a limited 400 watt device when you can build a 1Kw device in a smaller footprint?'
Scalability does not apply to everything well. Of course Cosmo will answer 'Core what makes you think I have not built one? Think  ;)'
The appropriate response is 'If you have a 10" dick you don't tell the ladies your packing 4" ' Think  ;)
Respectfully,
Core
core
Quote from: cosmoLV on November 24, 2010, 10:59:20 AM
this makes me crazy, that so such simple thing and exeriments can make peoples here a fail...!!!
that mean that you are not ready for such tecnology..
  What makes you think everyone is being honest? Think  ;)
Respectfully,
Core
