0 Members and 184 Guests are viewing this topic.
penno64
Hi Flathunter,
Yes, the schematic is via the link in the post for that user.
Regards, Penno
baroutologos
Hi,
I understand it also to be a thin copper sheet.
Bart once suggested that it is equiv to a single turn.
Hi Penno,
Actually i was refering to the coil inside the stacked ferrites toroid that equals to a single turn equal to a sheet of copper.
If the copper sheet is put outside the ferrites stack then you get nothing as far inductance concerns.
@Cosmo,
If you follow this thread, more that 10 times i have stressed the fact that energy should come from somewhere. Some conceptualize this can come from the vaccum or ether, others by bypassing the law of entropy at nanolevel, thus exploiting noise (thermal energy) and making it electricity by some kind of procedure etc.
In any case, The procedure is EXCACTLY that eludes us, not the concept.
penno64
@Bart,
Thanks for clarifying that.
If I may ask, what is your take on the video and circuit that grizli linked to?
As I have seen much of the great work in your posts, I would be interested in your view.
Regards, Penno
baroutologos
Quote from: penno64 on December 13, 2010, 05:01:54 AM
@Bart,
Regards, Penno
Honestly i do not know. From experience i know that many people are fast to claim OU or sucessful Kapanadze replication without be so. I really wish this time be differnent.
In any case, replicators and inventor will clarify this case. Practically, i have not understood what this man says. Not a clue in russians or modus operandi of his device.
iceweller
 Energy must come from somewhere - granted. What we are looking into is from where and how it is changed into what we need. From where, well, the "ambient" for sure. In what form this occulted energy presents itself, that is also interesting. We have to "transform" one type of energy to another i.e. into a usable type (heat or electricity). The process of this "transformation" has it's losses like any other process, but the result is a greater output vs input due to a second occulted source ("gate" or whatever you feel fit to call it) so the losses in this process are totally negligable. We can call this only an "apparent" violation of the conservation of Energy, because that's what it is, only apparent as there is, as sure as the sun is shining, another source.
   The coil accesses this ambient source, HV HF stimulation (SG) with specific EM resonance(s). Whether the ferrite atomic "domains" capture this extra field with a GND reference to close the "circuit" or the field around the core does, it comes from a source which I believe is our planet thanks to it's own field and movement through space (and so forth: "nature's wheelwork").
   So, again, the questions are what are these frequencies and systems to access this source? Is there a specific relation factor to access them (material/element, field, frequency)?
