0 Members and 131 Guests are viewing this topic.
khabe
Quote from: grizli on December 14, 2010, 10:51:22 AM
Can anyone translate  this image please, it look VERY similar to SR device
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=49417;image
This is  Budenniy`s welding apparatus,
One guy (mishail71) is speaking that "you need NOT to play with Tesla, I have studied Kapa´s "green box", it works exact like Budenniy`s welding apparatus ..." and so on ...
But other guy he did look mishail71 videos more carefully, all voltages and amperages and is speaking that there is no supranormal things because when low amperage then also voltage is very low ... and so on.
Some guys are sceptics because "how such kind of genius (Kapanadze) made such kind schlock and rubbishy constructed unit ... huge lot of cheesy wires and near none correct electric  contacts ... and so on
I do agree with mentioned above,
cheers,
khabe
khabe
Quote from: grizli on December 14, 2010, 11:19:31 AM
http://www.youtube.com/watch?v=KAplLEjTriE
What about this weird welding machine ?
This is unknown language for me  :-\
About mishail71,
I have read some other Russian forums, this mishail71 uses too often unprofessional therms (like always most of  "super smart" guys does), he will come very edgy and nettled when someone asked about ... even when asked without smallest mock.
khabe
scratchrobot
iceweller
Magic's description of TK's coil operation (translated from russian and adapted at best):
"Capacitance is discharged through a gap in the primary short thick coil. Classic TT. The second coil is located at the bottom, though it is not visible. It is well insulated. This a bifilar coil, which has increased its own capacity and stores much more energy than a simple coil. For a given amount of its resonant frequency of about 60 ... 70 kHz. The second coil in this installation option, with one end connected to a grounded cable inside the coil. The second end apparently goes to nowhere. Therefore, the ground wire is mechanically connected inside the coil. On top of it a third load coil is wound. The necessary amount does not fit in the length of the cage and is released (exits) symmetrically at both ends. Therefore you can not see the secondary coil, and you can see the bottom layer of the third coil and vlezshie(?) coils on each side. The third coil is reflected in the patent as a square with the word "current power". And then on the patent are all elements of the converter in a standard voltage and frequency.
The Management arrester is arranged so that the discharge occurs at the peak sine (90 degrees or 1/4 wave) at the maximum vibration. In other words, the energy transfer occurs in phase with the resonant vibrations of the secondary coil 60 ... 70 kHz. It works in resonance with secondary coil. Adopts and transforms energy. Primary coil conveys a strong magnetic field towards secondary.
It takes some time to synchronize the system at the start of the process. Then after some time/cycles he switches the second switch. It would be better to automate it, but he had little time.In a short clip when it’s turned on at installation you hear a distorted metallic noise. Ie the sound is not balanced, not sine. This was necessary to demonstrate that 50Hz can be achieved and measured. This is done only to demonstrate using a simple amplitude modulation of 100% of the rectangular pulses of 50 Hz. But the carrier frequency was always present - the resonant frequency of the circuit - tens of kHz. Much easier to charge an interim capacity rectified DC voltage and then a standard converter with stable voltage and frequency."
