0 Members and 202 Guests are viewing this topic.
scratchrobot
iceweller
FYI a recently released video with (approximate) translation:
http://www.youtube.com/watch?v=XTQYjWHSkxg
(00.00)Welcome.
(0.01) All of us are closely watching videos with generators Tariel Kapanadze. And dozens of times and probably hundreds. Each time trying to figure out how he does it. The latest versions of its generators all the stuffing carefully camouflaged rather hidden in the body. But in earlier versions recall the movie with an aquarium and a green box at least that is so evident.
(0.34) A lot of people have gathered on the various forums dedicated to the free energy. All of us ask the same question. How is it again? How can we make the same generators?
I'm also sick of this topic. The more time I devote to these issues the more convinced that we are specifically taken away from the truth. It is quite possible solution lies under our noses. And we do not see this emphasis.
(1.09) Let us consider one of the options for a possible fuel-less generator device Kapanadze.
(1.18) This has already been a big fuss in RuNet and most countries obscure or rather ignored by the scheme. This inertia welding machine Budyonny. Ask a welding and here? Now understand.
(1.34) Even the name is unusual. No inverter and inertia may be the author to the most hints that it uses is not quite a classic scheme? Really look carefully. To enter, we see an oscillating circuit. Bifilar coil, and even iskrovik! Perhaps Tariel just finalized a welder.
(2.06) And now remembers roller to the aquarium.
There are clearly visible for at least three coils. And the wound as well as in the diagram sections. Now remember the video with a green box. And once again overcame the scheme. One of the wires from the green box goes through iskrovik and more on the coil and the coil is removed from utility power. Well? Think it's just a coincidence?
(2.39) Go ahead. In the scheme of the welding is a massive transformer of special design. Is it something like  Kapanadze's design? Again we return to the box of Plexiglas and see what we'll see when the operator removes the lower part of the device. And we see that there is quite a large object rather them even two, and they are on all sides except the bottom of the carefully concealed from the old boards Telico tube. I am a special, even just to say that this board video amplifiers.
(3.20) and listen to the sound when connecting the garland of powerful lights. Clearly hear the buzz of the transformer.
(3.30) If it is indeed the generator has a base in the form of a welding to run the must come fairly powerful impulse voltage and current. That is why to start it Tariel connects a strange box and presses a button.
(3.46) The battery is simply not capable of giving a boost so he hid in a box of mini converter. And if in fact the basis of welding tuned to resonance at 50 Hz is probably the sine generator and in this little box is. And note that there is also a spare battery he holds in his hand as the battery charge is sufficient only for a few runs.
(4.12) When such welding work on the network for its intended purpose then the resonance frequency of 50 Hz is supported directly from the outlet. And in the case samozapitki needed than it is here to support you, and use of power transistors to generate a 50Hz input.
(4.35) Note here on this waveform is going on in the coil U2. In here again, a coincidence. Let's take this piece of waveform repeated several times and glue in one. In one continuous signal. Now remove the excess debris from the lines.
(4.56) Ask and it is why?
(5.09) Not so long ago, a man also involved in researching the replication of the generator sent me his scope waveform.
(5.10) I got it by filtering the audio track with video capabilities which demonstrate the green box. And if you compare this with the waveform that we have restored the scheme welding. We can see how they are alike. What is it that there is slow and noisy outburst decline.
(5.34) Well how do you still think it's just a coincidence? I propose to think carefully about this version. And draw appropriate conclusions.
Thank you for your attention ..
forest
I'm not sure but there was somewhere transcript and translation to English of this video http://www.youtube.com/watch?v=KZYm9brl_WA&feature=player_embedded#at=395
Where ?
There is an important moment when Kapanadze talks with bald guy in house. Seems that the small guy with moustache is trying to  stop this dialog.
Please translate.
forest
About Kapanadze green box video :
Have you thought about black wire in Kapanadze green box device ; that one which is going through the coil tube ?  ???
I wonder why when device was carried in place of experiment that wire is already attached to device with a good long piece rolled into a circle and kept by a man in hand ...
If as many think,  that black wire is only pulled inside tube and there bulbs are connected would it be easier to carry wire separately and do that just before demonstration ?
My idea : I think it is impossible because that wire IS CONNECTED to something inside tube.
What do you think ?
khabe
Quote from: forest on December 16, 2010, 12:00:38 PM
Where ?
Please translate.
Yeah, no way, at least for me. In house with bald man they are speaking in Georgian. This young guy with mustard I think is his son, there is one son or relative more on background, look at eyes and face lines. I looked full LP video yesterday, they speak about not any informative thing, at least not by Russian, just talking about that after each show he destroy this device and builds up a new one when new presentation ( I dont believe that ;-) and talking about what it will cost, where to patent ... journalists asking also very stupid questions ...  Yes he is speaking how he got it, but not any details, he was building something else but by result he got this - lucky strike. I must agree with  mishail71 that this green box is faster welding machine Kapanadze built or someone else built and Kapa just tried to use it for his experiments until found this phenomena. This large outer coil ... yeah, may be ...  but during the war and after WWII in soviet union many people who did live near big soviet MW and LW radio antennas, they got electric energy when put huge coil on to backyard trees and wires went in to house from, very simple! This Tesla-like coil works the same way - huge radiation ... and I do believe that all  amp-, volt- and watt-meters just come to be false because strong interloper electromagnetic radiation. Of course, this is just my opinion,
But have you seen at least one selfrunning device with your own eyes and kept it in your hands and it really works?
Even smallest one,  powering just one led?
I have not -  seen just videos where jumble of wires, horrible discomposure, poor lighting, filmed with cheapest camera by very incapable cameraman :-\
And folks trying to get it work with inverters, transformers, lot of wires, semiconductors ... all these things cause only LOSSES,
Thats because hard to believe.
I want to believe, I want it is possible ... but how?
Cheers,
khabe
