0 Members and 122 Guests are viewing this topic.
baroutologos
it is in this topic i talked about this a 1 month ago or so, people were interrested in it for a moment, then again they have gone into theory fantasies.  my website is www.feny555.blogspot.com
most of the explanation is missing from the site.
it is tiring to find all my previous posts on this topic, i have posted exact descriptions in this topic, everything worked as i said, no lies or theorizing from me,  sorry i work all day im really tired, i think this is the last time i post about this case , i do think its important and i dont get why people ignore it,
ZZZzz   off to sleep,
energia9
@ Energia,
Hey, I was interested in your setup. We talked in private and i asked you several questions that you tackled or just went unanswered. I remember you had a different schematic, one with a capacitor shorted across the load - now you changed it - then again you believed that the working frequency was 500 Khz. Now a whole range of new findings come from you. As it works with any frequency etc.
Ok... all you have to do in case you have something interesting is to arrange a well explained setup (many photos) and upload to youtube an operating video as you describe.
Everyone will appreciate that! Then help will flow.
energia9
Quote from: baroutologos on December 18, 2010, 04:30:30 AM
@ Energia,
Hi,  I did several experiments that stand out,  those are separate experiments if i have forgot to mention, yes im a bit confused, i said different things in different times, there are a number of things i posted and those are all different wiring diagrams,  so now im reffering to the device i disconnected from source, concentrate on that one,   the 500khz device is a bit something else, it has its own interrestingness, but it can be easily explained by simple resonance,     now as i said about the simple wiring with the two diodes and 1 capacitor,  it worked with disconnection only 1 time,  I cant make the experiment again even if i try because it just doesnt work like before,   i followed the procedure i did by accident, but i cannot make the bulb light again with the leads disconnected,   i must miss something,  but im sure it was something about a different kind of resonance, other than just the freq generators resonance, because i did not mention that the light dimmed or brightened by frequency adjustment,  the setup did not go away when i did this,  the effect were lost when i moved my coils,   im trying to chase the effect,  could you please tell me what can i do to make this diagram more stable?  perhaps you know more than me,  this happened by accident,    so have you ever done or heard of an experiment where the freq generators output were very low voltage  0.4 v  and it was disconnected from the circuit  and the lamp shined over distance same as if were connected to the diagrams input,  the leads were in my hand and i pulled it more than 1 meter away from the device but the lamp was absolutely 100% unaffected,  in ordinary transmission it must dimmer right?      i would be happy to put a video up on youtube, if i could reach this stage again, but i think there are components missing from the wiring to make it more stable and dont get lost of it,  i know im not wrong because i have seen it with my own eyes, hard to believe if you have not seen it,   may be you can just look on the diagram and try to put more components in that would make it more stable,   with the capacitor and the secondary coil  it is only an LC
baroutologos
Hello agan Energie,
It is perfectly natural to change "oppinions" or points of view regarding those setups since we are investigating and discover the knowledge as we proceed rather than to have a fix view on those things. I have changed oppinions more than once...
Honestly, i cannot help you replicate the effect of disconnecting a power source and a lamp keeps burning (without capacitors etc) This is outstanding if happens so. When experimenting and face a strange effect, anyone must do his/her investigation to see if the effect is attributed to any OU procedure or just a coincidence that happened. Personally i am extremely cautions to declare any procedure OU. It must be investigated beyond doubt. (take your time)
Anyway, at the moment i pursue another line of experimentation that involves field study. Perhaps in the near future we can "cooperate" somehow.
Cheers
exnihiloest
Quote from: khabe on December 17, 2010, 06:35:45 AM
But of course strange, how it is possible to get these lamps to lighting with this small battery and how long it will perdure  ::)
We can light them from HF sources, by magnetic coupling (induction) or electric coupling (capacitively at a distance).
Here are views of my own experiments, using 10 W, 25 Mhz, and a magnetic coupling (2 or 3 W should be enough but my setup was not optimized).
http://exvacuo.free.fr/div/Sciences/Experiences/Induction/Lampe%201.jpg
http://exvacuo.free.fr/div/Sciences/Experiences/Induction/Lampe%20Ensemble.jpg
I tried with many frequencies between 1.6 and 30 Mhz: no difference.
forest
I wonder if HV coil should be insulated from ferrite or in direct connect ?
