0 Members and 119 Guests are viewing this topic.
energia9
Quote from: forest on December 21, 2010, 02:21:16 PM
Cosmo
Please!  if you can measure if your ferrite DO NOT PRODUCE NEUTRON RADIATION !
Just to be sure that Meyer & Macy patent is not a the source of effect.
I think it is very important.
French  patent application FR2680613
i know the "real tesla effect" doesnt produce any harmful radiation,  if cosmos device is meyers, that does not mean teslas,  neutron radiation makes everything r active around it, even your bones and the metals in your body.
teslas effect need no ferrite, i have prooved this,  even if i did not achieve overunity yet, i achieved the most efficient power transmitter without even an antennae, no pos neg connection ,  anywhere.  distance is a joke to teslas device,   here in tesla effect as i experienced,  earth is the medium, not the ferrite.
forest
Quote from: energia9 on December 21, 2010, 02:55:27 PM
I hope so. I think that ferrite makes this effect just more powerful due to delay in magnetic field and more inductance to the coil so self-inductance is higher without more wire turns. Tesla transformer patent barely touches this but it can have MAGNETIC core. US593138
I wish I could have radiation detector.
energia9
Quote from: forest on December 21, 2010, 03:21:34 PM
Tesla did mention the following formula=
High self induction = low capacity capacitor needed for stable resonance,
Low self induction = high capacity capacitor needed for stable resonance
so he used iron as for reducing copper windings, because what he mentioned is very high inductance and very low capacity, so, bingo,
and what i have experimented out is that only the primary would require the ferrite
i did very low self inductance and high capacitance, and it did work.
tesla said the high self inductance and low capacity is more stable so im going to play with that one,  my primary coil being about 4 microhenries,   my secondary coil being exactly  702.1 microhenries,
and my capacitor was 420 microfarad one,    resonance freq peak were 1.2 mhz   fo this coil,  i have experimented out that only the primary needs a ferrite rod inside the coil, because if you put it under both primary secondary , or secondary alone, power will decrease,   primary requires an inductance lift while secondary is the receiver and it doesnt need a ferrite medium, but it requires the earth as the medium,  get it?    primary requires ferrite for the output transformer for only a better efficiency,    this i have experimented,   it came out looking the same as kapanadzes device,  two coils being far away,   the two coils being the primary and the secondary,  another coil under prim sec it is a "carrier of current"    so for primary-the medium is ferrite for a better transfer, but for -secondary it is the earth for a better receiving,
so this is exactly how i accomplished my results which i have posted,
in my opinion you should use variable capacitors (saltwater glass type) with an additional variable inductor,
forest
Quote from: energia9 on December 21, 2010, 03:35:17 PM
and my capacitor was 420 microfarad one,    resonance freq peak were 1.2 mhz   for this coil,
Ok. Now consider problems with spark gap. Do we know what has to be input frequency for HV to spark gap and a spark gap size etc. to obtain at least small effect at 1.2 mhz among other frequencies ?
For higher inductance coils with ferrite core for example resonant frequency would be in khz range and spark gap input HV need not be very high frequency maybe even just from 50hz  to a couple khz.
I hope it is the only reason for choosing ferrite core but that possible neutron radiation makes me anxious.
LtBolo
Quote from: forest on December 21, 2010, 03:51:44 PM
...but that possible neutron radiation makes me anxious.
Do we know for certain that the French patent holders know for sure that was the source of the extra energy? Or is it possible that was the explanation given to satisfy a skeptical patent office, and the real source was ambient?
