0 Members and 586 Guests are viewing this topic.
iceweller
@ core: I tried to follow the live interview today and some users translated some stuff for me. Anyhow the interview should be available shortly, even if in Russian. You are correct, he did demo some pretty interesting stuff and it's all available on his site for free for now:
http://ferromagnetic-energy.com/core_of_the_physical_effect/
There are theories about reactions at an atomic level for ex. but in any case the setup is pretty basic if you look at the circuit and it's not a problem to reproduce it (at least it appears so).
   They also said that TK said he was on the right track though missing some concept and that yes they wanted to meet up.
forest
I doubt Melnichenko can patent process. Only actual implementation I think yet still it is possible to void implementation too by previously published material.
Anyway, Tesla was first who described process and there was also author of doc "kak pabotaet kapanadze"
the_big_m_in_ok
Quote from: MasterPlaster said:
quote]
Melnichenkos patent
(WO/2003/061110) METHOD FOR ENERGY GENERATION BY MEANS OF ELECTROMAGNETIC WAVES AND DEVICE FOR CARRYING OUT SAID METHOD (VARIANTS)
So can some one translate it please?
That might be nice, but I downloaded the address above, and there is no wiring schematic to accompany the text.
(At least in the 14 pg. initial application for the international patent.)
--Lee
wattsup
@guys doing translations
Please keep in mind that the parts about seaside, his problems with legal aspect and all other such diverging topics are not that important to us. I don't really care about the story or his legal problems. All guys with OU devices that look to make money on it will have problems from day one of signing a contract with money guys. What else is new.
What is only important here is any more news on the device.
And related to that, from what I can understand from your translations, with thanks to all, is that my last post on how the device works is very very close indeed. Some slight changes needed. I am glad about that.
It's too bad this Denis guy did not have the smarts enough to get TK to crack open some more.
Some major points I took down are as follows;
I will comment inside them also.
START
First video: nothing new.
Second video:
TK: Ground is not needed.
wattsup: I'm worried he's not telling the truth. Each time he talks about making juice, his device is grounded. TK is just playing with the guy.
Denis: I can envision how it works. It's like with Tesla, there is a need for impulse. The spark and we have to tap this. There is a need for a mechanical pulsing device.
TK: And we are using electrical ones. But Tesla was able to achieve 2 millions of pulses per second. But so far, we were using only 50% of that speed. That means 1 million of pulses per second.
Third video:
Denis: So we should not have the BEMF right. We should avoid it.
TK: Yes, Yes. If you don't get rid of it you are going to have so much mess.
wattsup: Again here I differ and believe that if Denis knew enough about that question, he would not have responded with the following dumb ass comment.
Denis. Yes, well I was learning about Tesla technology only after I saw your video. I've heard about Tesla Tesla but who is Tesla. What he did. I have no idea.
TK: Tesla is a genius.
Denis: That green box you have, there are no ferrites in this device right.
TK: No, there is no way. Just look, where you see in Tesla ferrites?
Denis: Well there is iron but not ferrite flame treated.
TK: Yes because at that time there was no ferrites.
Denis: The metal that he was using was serving the same purpose. Right?
TK: No. No. No. No..... No. Absolutely not. People who are saying resonance is needed, not needed, bifilar, yes, you can use bifilar, but you can do it without it, I don't know.
wattsup: All this is very confusing, right.
TK: Well I just presented and I only presented the spark and how do I get this into the point of spark. And how do I transfer the forces of that coil. And I was showing devices sitting here and taking from over there and there is a glass box. There is one coil, a second coil, a little bit smaller coil and from that how did i took that energy that I got.
Denis: So you meant that there is the white spark that you have there is the nergy that you have from the surrounding ha ha ha field.
TK: Yes.
Denis: That means that this spark it change to current.
TK: Yes Yes, this goes to the power coil and then is being transformed to electrical energy.
Video #4:
Denis: Well ahhh flame treated iron, did you use that?
TK: No I did not. I never used it. When others says that resonance is needed, not needed, use bifilar coils, we can do it with it, without it. I don't know. I know what I was able to achieve.
Some time later......
TK: You know that pure induction is transmission. Using wires, in these transformers....
TK: OK I showed them a big coil and the second one a little bit smaller coil and I how did I take from over there and how did I make this. Yes I did take this energy from the surrounding environment.
Denis: Well the white spark is the surrounding energy from the environment, right?
TK: Yes. It is.
Denis. It looks like from that moment we have the conversion to the current.
TK: Yes. We are transforming the energy to the power coil and then this is being converted to the electrical energy. And, I was using four square mm thickness wires. 3 wires. They were connected from four square mm three wires and they were outgoing.
END
So we learned a few things with thanks.
Now to make a build and do some testing of my ownie.
wattsup
