0 Members and 573 Guests are viewing this topic.
forest
Quote from: Ghost_Rider on January 25, 2011, 09:39:49 PM
I look at last 350 pages.  Mostly arguing and talk.  Many foolishly believe SR123 and CosmoLV.
Where is auto resonance discussed?
If output is AC, what this says about how current is created?
Where is the cable to ground discussed?  Why is cable in core of coil?  Does this increase current?
Broli is correct about 350 pages of shit and very little good discussion.
Yes,I believe we would not know how those wires are connected to the coil. But I saw somewhere a short video where Kapanadze seems to be explaining more. Do you recall it ? He is pointing to one of Tesla patents carried in his own hands.
The MOST annoying is that there is nobody who can translate Georgian here. Kapanadze seems to talk a lot in his own language about green box device.
TheCell
I am no Expert.
But this doc describes function and a lot of design specifics of the
Tesla Magnification Transformer.
It's name:
Eric+Dollard+Condensed+Intro+to+Tesla+Coils.pdf
The size is 23MByte.
I am unable do upload it. The site complains about that I have not provided a title, but I did.
The functioning principal is described with displacement currents to which
Vladimir Utkin  in his FREE_ENERGY_1.DOC also refers to.
iceweller
Quote from: quarktoo on January 25, 2011, 07:51:19 PM
Funny how in every Kapanadze photo, you see a coil that has the ends covered up. Ie, this is not an air coil transformer. On a photo back a few pages you plainly see what appears to be a copper tube core.
When people begin to look at what gas is inside the tube, then perhaps you will see a replication. Until then, expect another 350 pages of nothing.
In the green box photos, it appears that Kapanadzi is using a water bottle as the gas chamber / coil form.
Another aspect that went unnoticed was the large coil on the outside of that photo. It is not copper and appears to be silver. Silver is used in accelerator coils.
Here is someone experimenting with Meyer's gas generator patent. While I don't agree with many of his claims, it is interesting.
http://www.alexpetty.com/category/general/
@ Broli. Do you think my plasma core suggestion is smoke and mirrors or do you think it has investigative merit?
    So you think the thick black wire, that is routed through the core, somehow is perfectly sealed at low or higher pressure and than atmospheric, going in and exiting the core, by white silicon?
    Would it not be just that he placed some silicon sealing to prevent the thick cable to move around and avoid being ripped off while being connected and handled?
   After the Green Box demo in the original footage at around minute 55-56, the coil is handled and placed on the desk and the silicon sealant is not there as the black cable has been removed.
   Here is an edit:
http://www.youtube.com/watch?v=PG3ALEVkILE
wattsup
Quote from: iceweller on January 25, 2011, 03:51:38 PM
Sorry for that, I missed two characters when copying:
http://www.youtube.com/watch?v=bs9TxcJZs-k
If anyone can speak to that guy, please ask him to do the same test but now without the coil. Put the bulb to the output directly via a dioded capacitor. I think it will do the same thing just more erratic.
I myself am beginning to think that the TK unit (green box) is the OU device and the TK coil is just a diversion. I don't believe TK spent years and years trying so many many different coil combos to finally find this what looks to be a three coil combo.
TK said the TK coil fixes the output for the bulbs, or something like that. Well that coil is just tooooooooo thick of wire and toooooooo few turns to mean anything. I am sure he was using it like a long wire turned around a tube that essentially does nothing to the output but "maybe" cut down on the higher frequencies of the spikes coming from the spark gap before it meets the resistance of the load. Kind of like in sound systems where you have peak power rating (without the TK coil) and rms power rating (with TK coil just doing some smoothing out). But there is not three coils there because inter coil relations using those wires is like using a whip to cut your grass. Does not make sense for such wires to be used in coupling, so there is no coupling going on. It's one big coil with that outer heavy awg stock coil of 6 turns in series to the inner one, again useless, ha, ha, ha. A choke would do the same thing. But this coil makes a good diversion so you don't concentrate on the little green box.
The plexy TK unit did not have any TK coil. It has two smaller coils of finer wire with much more turns.
I think now after all my own progression of changing views with added observations, at this stage the TK device is inside the Green Box and he made the coil so we would think you have to know how to run the coil to figure out his device, instead of you working to figure just what is going on in his green box. Helloooooooo. Anyone home. But TK wants others to think there is more to his device then a green box. TK is a pretty sly OUer and he will not give out his device.
You can explain all the operational theory you want, but with those wires in that coil, there will be nothing happening in a true coil where you are looking to transfer or induce into another coil body.  At best there is no more then 40% transfer potential between two coil windings off that type. Resonance or not.
Oh, I forgot to mention that from my own close up checking of the video, there is only one white wire that leaves the green box and goes to the TK coil. The other end of that coil is the positive to load. Only one wire guys. So one wire to the TK coil and one wire from the TK coil to load.
SRs coil has no resemblance to the TK coil.
wattsup
PS1: There is no gas in that TK video besides any of those present letting one out.
PS2: The taped ends of the coil are simply to hold the coil on the U bracket otherwise the TK coil would have slipped off many times during the demo.
dllabarre
Quote from: TheCell on January 26, 2011, 03:41:26 AM
I am no Expert.
I skimmed through the first 15 pages and it is an interesting read.
It's based on principles of operation as opposed to actual application examples. Meaning none of the schematics have component values.
DonL
