Waves
Choose username
Quote from: Choose username on January 26, 2011, 01:21:22 PM
new Kapa`s video:
http://www.youtube.com/watch?v=CXwcw1wt0-w
Quote from: teofiliussThis is a principal scheme of the hydro-generator which was given me by Gia (Tariel's assistant).
https://sites.google.com/site/teslafreeenergy/_/rsrc/1296064809193/home/galeria/Hydraulic_circuits_275px.JPG
About principal of this device - Tariel says that he had constructed special hydropump, which have 1 kWt consummation and puts hydraulic pressure on oil: more than 200Bar. The power of this pressure is transform to the energy more than 18kWt. I think that its work with the help of hydroturbine. It is a good, if generator is more 1000 rpm. This was filmed some days ago.
(Bulgarian->Russian->English transl.)
Choose username
are you need (in this forum) for next translation with more info from Kapa about details of previous electronical kapagen?
iceweller
Quote from: wattsup on January 26, 2011, 09:07:58 AM
I myself am beginning to think that the TK unit (green box) is the OU device and the TK coil is just a diversion. I don't believe TK spent years and years trying so many many different coil combos to finally find this what looks to be a three coil combo.
TK said the TK coil fixes the output for the bulbs, or something like that. Well that coil is just tooooooooo thick of wire and toooooooo few turns to mean anything. I am sure he was using it like a long wire turned around a tube that essentially does nothing to the output but "maybe" cut down on the higher frequencies of the spikes coming from the spark gap before it meets the resistance of the load. Kind of like in sound systems where you have peak power rating (without the TK coil) and rms power rating (with TK coil just doing some smoothing out). But there is not three coils there because inter coil relations using those wires is like using a whip to cut your grass. Does not make sense for such wires to be used in coupling, so there is no coupling going on. It's one big coil with that outer heavy awg stock coil of 6 turns in series to the inner one, again useless, ha, ha, ha. A choke would do the same thing. But this coil makes a good diversion so you don't concentrate on the little green box.
The plexy TK unit did not have any TK coil. It has two smaller coils of finer wire with much more turns.
I think now after all my own progression of changing views with added observations, at this stage the TK device is inside the Green Box and he made the coil so we would think you have to know how to run the coil to figure out his device, instead of you working to figure just what is going on in his green box. Helloooooooo. Anyone home. But TK wants others to think there is more to his device then a green box. TK is a pretty sly OUer and he will not give out his device.
You can explain all the operational theory you want, but with those wires in that coil, there will be nothing happening in a true coil where you are looking to transfer or induce into another coil body.  At best there is no more then 40% transfer potential between two coil windings off that type. Resonance or not.
Oh, I forgot to mention that from my own close up checking of the video, there is only one white wire that leaves the green box and goes to the TK coil. The other end of that coil is the positive to load. Only one wire guys. So one wire to the TK coil and one wire from the TK coil to load.
SRs coil has no resemblance to the TK coil.
wattsup
PS1: There is no gas in that TK video besides any of those present letting one out.
PS2: The taped ends of the coil are simply to hold the coil on the U bracket otherwise the TK coil would have slipped off many times during the demo.
   Wattsup, I agree: it doesn't even look like (even after many frame checks) that that coil is connected to anywhere. The thick output wire (red then taped to another) actually appears to go directly into the green box and then there is the white one "routed" through the larger coil. If you look at the part where the coil is on the table where he turns it, one side is not connected to anything at all and the pieces that are cut also appear to not be connected to anything. At max it may act as a secondary filter, but I even doubt this at this point!
