slapper
speaking of user xdole thank you for the link to this vid:
Quote from: dole on January 13, 2011, 08:03:37 PM
At least “They” allow to teach this at schools to
http://www.youtube.com/watch?v=G3eI4SVDyME&feature=related
Take a time and see, if not at least last 10min
Lewin seemed more distracted in the video.
BUMP
take  care.
nap
we are not alone :)
Choose username
Quote from: iceweller on January 26, 2011, 07:40:10 PM
  What about this "3.73 KV limit" he's talking about? I didn't quite understand what he's saying about this value and not exceeding it or maybe the translator is messing it up.
  Is it also true that Tariel has completely eliminated the spark gap and implemented a semiconductor solution (SCR) with the same results (what apparently is demonstrated with the newer blue box device)?
   Thanks
SCR yes, its true! And maybe already inside Bluebox, i don't know.. ???
3.73kV limit - it was the opinion of the one forum's person... Tariel never talked about it. Moreover, voltage in his Turk installation - much higher at the first transformer. And? What? Obviously this man would like to warn about the dangers of working with such voltage, but i dont understand WHY so exact number - 3.73kV and no more  ;D ;D
BTW, in Turkey Tariel cut off the wire between two transformers (1 of 3 phase module) and all could see that it continued to work! Seems it can work like radio.. Wireless close range transmitter-receiver.
khabe
http://www.youtube.com/watch?v=swWiIoAsfFI&feature=player_embedded#
At first this man does render thanks to Nikola Tesla, then special thanks to Andrey Melnitshenko (who by his opinion is the second man after Nikola Tesla) and then to Kapanadze  :)
Now the test:
Transformer 220/40 V, ca 150...200W, then series capacitor 100 mkf, 360V ... then el-drill is as load and as inductance --- all thes components making resonance device. This is 1000W el.drill , he declares (when experiment) it makes ca 500W ...  But how he can be sure about this power - I do not see any meters  ::)  What is AC current in cable of 1000V el-drill when full throttle and no load?  I have never tried but I dont believe this is 500W, at that when Voltage is unknown ... surely much  less than needed. This man is thinking that power of el.drill is some constant quantity, does not depend about Voltage, does not depend about speed and about actual work you are doing with  :) OK, he tries to stop this drill by hand and it looks like this drill is impuissant because low voltage at that capacitor between ... but OK ... can you do like that when you have 1000W el.drill and correct 240V  ??? ... Never
He declares with these simple parts he has ca 1.5 coefficient of OU ... oh dear  :o
Then he draws simplified scetsh of Kapanadze gen,
Looks like this is the right person from who to ask correct scheme of 8)
OU unities growing like a mushroom,
cheers,
khabe
iceweller
Quote from: quarktoo on January 27, 2011, 08:33:18 AM
After reading hundreds of pages this thread, I think I am going to back off my gas tube suggestion for now and here is why.
Nobody seems to be worried about being shocked by the ground wire and that is indicative of a cold electricity circuit.
I think Dole has more of the answer so far with his youtube video (user name xdole).
Hopefully he can share some of his knowledge of exactly how he did his experiment. Anoher thing I do see in the kapanadzi videos are inductive loads being drive - again cold electricity although it could be converted (I think).
What the hell, I try and build it. Who has got the best coil winding schematic /plan?
  Sorry, but I don't adhere to this "cold electricity" myth. There is only one kind of current and this argument has been dealt by Tesla and he has said himself that there is only one form of electricity. All the other talk ala Peter Lindemann & Vassilatos is pure over speculative "lala land" talk. A current, through a conductor that is not a perfect one creates heat as with every process that is not 100% efficient. The extra energy comes from a source not accounted for. Simple.
  I believe a good starting point was MADSATBG's schematic which is not completely correct regarding the counter winding of the primary HV coil; this I mentioned to delamorto a while ago and he confirmed it (testing it now with the 2 joined counter coils - the famous blue and red coloured primary in SR's demo).
core
 This is a good opportunity if any. It has been stated 1 million times that a direction is needed. Also working is easier when there is more then one person involved.
  Maybe we can all get together and sing 'Kum-Bah-Ya' for five minutes then get to work.  8)
Starting with the description above, I have a few questions, here is the description in its entirety.
Also at that meeting he said further details of their installation. This is two Tesla transformers. They are connected through a wire from the top. Between them must be a resonance. First transformer works via spark on 100 kHz and higher. Second - is a power transformer. In the first transformer we have small capacitor on primary coil for the high-frequency discharge. On secondary coil (power transformer) we have large capacitor for decrease our high frequency. In the output of the Turk device are powerful diodes. They fix output energy. Next step - it passes through a capacitor and then formed 50 Hz.
I guess that between first and second Tesla's transformers take place a capacitor.
Spark is used for resonanse selftunning. According to Tariel - many people achieve in their experiments Free Energy, but they don't understand how to reduce frequency and voltage.
This method and some another moments (which while hiding) - have a very simple solution. Those who want to succeed it - must think simple and do it simple too.
Tariel also said that he already has sparkless version of kapagen. It is a fully electronic solution. I think that Kapanadze use thyristor for this purpose.
We talked about vacuum tubes too. He said that this is a best solution! But sadly vacuum tubes can live in such device not more than ~1000 hrs.
Giya (Kapa's assistant) suggest that the best way for replicators - begin from high voltage as the input power (against 12V akkum. or battery) for start process. It must be 220V or even more.
Tariel said that the resonance between two transformers "shakes" the aether and it give more energy. Ferrite core prevents the process and therefore does not apply at his device.
Based on the above I have a few questions, please feel free to answer to the best of your ability.
Question:
Instead of building a Tesla transformer does anyone believe that a regular 'auto-transformer' (induction coil) from an old car can be used to produce the required voltage and frequency?
Question:
Looking at Tesla patent #685,955 We can see almost a very similar description. In this patent device the receiver must in 'sync' with the transmitter. Also the device must have a large storage capacitor. From this device we might be able to build a working electrical diagram for an output.
Does anyone else believe that this Tesla patent applies?
Question:
What would be the easiest way to reduce frequency and voltage?
Based on the above Tesla patent we can discharge out storage capacitor at any rate we want. This then can pass through a transformer as 'step-up or step-down' ...any idea's?
Question
The oscillator in the 'flash' circuit comes to mind. Here we are producing 350 volts. This could then drive the induction coil. Does this sound feasible?
There are two types of people on these sites (well maybe other types) those that can build and those that don't have the resources to build. Those that don't have the resources your input is still valuable as you can use your time wisely to 'lay-out' circuits and compile data.Those that can build clearly have to make an attempt to try the designed circuits and assist in a 'prototype'.
If anyone has input on the above question please let me know.
Respectfully,
Core
BTW - I have had it with the snow  >:(
