0 Members and 37 Guests are viewing this topic.
core
Quote from: iceweller on January 27, 2011, 10:12:24 AM
.......................... (testing it now with the 2 joined counter coils - the famous blue and red coloured primary in SR's demo).
It has been confirmed on many occasions even by Tariel that the SR device has nothing to do with TK's device. Not trying to discourage you from trying but mixing the two devices creates massive confusion. Clearly the SR device deserves its own thread.
Respectfully,
Core
dllabarre
Quote from: core on January 27, 2011, 10:58:58 AM
This is a good opportunity if any. It has been stated 1 million times that a direction is needed. Also working is easier when there is more then one person involved.
  Maybe we can all get together and sing 'Kum-Bah-Ya' for five minutes then get to work.  8)
Starting with the description above, I have a few questions, here is the description in its entirety.
Based on the above I have a few questions, please feel free to answer to the best of your ability.
Question:
Instead of building a Tesla transformer does anyone believe that a regular 'auto-transformer' (induction coil) from an old car can be used to produce the required voltage and frequency?
Question:
Looking at Tesla patent #685,955 We can see almost a very similar description. In this patent device the receiver must in 'sync' with the transmitter. Also the device must have a large storage capacitor. From this device we might be able to build a working electrical diagram for an output.
Does anyone else believe that this Tesla patent applies?
Question:
What would be the easiest way to reduce frequency and voltage?
Based on the above Tesla patent we can discharge out storage capacitor at any rate we want. This then can pass through a transformer as 'step-up or step-down' ...any idea's?
Question
The oscillator in the 'flash' circuit comes to mind. Here we are producing 350 volts. This could then drive the induction coil. Does this sound feasible?
There are two types of people on these sites (well maybe other types) those that can build and those that don't have the resources to build. Those that don't have the resources your input is still valuable as you can use your time wisely to 'lay-out' circuits and compile data.Those that can build clearly have to make an attempt to try the designed circuits and assist in a 'prototype'.
If anyone has input on the above question please let me know.
Respectfully,
Core
BTW - I have had it with the snow  >:(
You've gotten all the snow that we usually get each year!!  Thank you for taking the snow this year before it gets here.  ;D
I can build.
We need a schematic and parts list.
Even though it will change, we need a starting point.
Don't confuse a Tesla Transformer with a Tesla coil.  Some Google searches show Tesla Coils when searching for Tesla transformers.
I was thinking of a old car "Spark Coil" also for the first Tesla transformer.
Then feed a capacitor?
Then to a "power transformer".  This I believe would be a regular step-up/step-down transformer like to go from 120v to 12v?  Or am I wrong? Or a custom step-down wound air coil like Tariel's coil?
DonL
Choose username
Quote from: Shokac on January 27, 2011, 05:52:01 AM
Can you translation this video?
http://www.youtube.com/watch?v=uxQ99R4gOWY&playnext=1&list=PL63547D173F4A047A
Thanks in advance!
0:15 -It is less, than 4 ohms. Good grounding here
0:18 -Now ground is entering device
0:23 -Here are a first coil
0:30 -Second coil..
0:34 -Most important: here are 3 coils total. Tesla had 3 too.
0:36 -This is independent coil. It is located here thus,
         because it must be influenced by an electromagnetic field from the first
         coil.
0:53 -And here, this big black detail is a radiator
0:57 -Count quantity of this lamps. 200 watt each. 3 kWt here.
1:22 -...(?)we have replaced it. Before at us was electronic,
        but it has broken.
1:33 -It will be checked first of all for density of an electromagnetic
        field, and maybe for radiation too. Because first of all we
        have corrected it.
2:09 -Look, you can stand here and touch ground and no problem
2:12 -It is better to hold it in hands
2:17 -Let I will hold it
(Georgian language only)
2:51 -...Heat because right now it provide a lot of amperes
2:59 -But here.. here is not heat
3:03 -We didn't test it for long term. How long it can work in maximal time.
        But it must work a very long time.
        Therefore I have offered to install two such identical devices. If
        the first will stop to produce energy, that second will be
        connected automatically. The consumer shouldn't suffer from it.
End RUS Titles: Let's discuss variants of this scheme realization.
Greenbox was filmed in 2003, this vid and device was before it (?)
iceweller
Quote from: core on January 27, 2011, 11:10:06 AM
Respectfully,
Core
   I have tried many times to reference what you say - do you have any link or relevant post? I have only seen unreferenced or incorrect speculative information until now. When Tariel referred to this, he did not really say it had nothing to do with his device (SR started from a TK replication attempt), and this has been confirmed by more than one of my Russian contacts. Furthermore, I have now doubts regarding the function of the external coil in the green box setup as clearly the turkish setup and even the plexiglass box were less "smoke and mirrors". I am always open to further information or any constructive criticism of course if you have any insight.
dllabarre
Does this idea make sense to anyone or should I just forget it?  :-\
I've been reviewing Tesla's Magnifying Transmitter Patent 1119732 called "Apparatus for Transmitting Electrical Energy".  It appears that Tariel's coil that we see outside of the green box, could be a Magnifying Transmitter type of coil.
The Secondary wind on the whole coil form, Primary wind on the left (on top of secondary) and the "third coil (induction)" could be the copper tubing wrapped around the outside that doesn't touch either of the 2 other coils.
What do you all think?
DonL
This should bring out the dis-informationalists either for or against this thinking.  :D
