stivep
Here is the hint When I was experimenting (I'm not till next 2 months- assembly of mechanical part- machinery)
I have connected old High Voltage Breakdown Tester by  Slaughter Company from  Piqua Ohio  This one has  one meter build in from 0 to 5 KV Heavy metal box
Right below the meter there are  two connectors for the probes. But I bought it without connentors so instead I have had two holes  wit hte inner central contact about 1" inside of each  of them.
I was working on SR project.
Secondary of HV transformer (the one that goes to spark gap) was temporarily connected to  right  connector  of that meter. with one wire only and the wire that goes to that hole I'm thinking was touching the  inner part of that connector.I mist have completely forgot about  this wire.
The electrical  cord from the meter was connected to the outlet but power switch was OFF. Actually the circuit breaker of that particular outlet was OFF as well.So both of the switches where OFF. On the right upper corner of that meter there is small fluorescent indicator with the red "diamond" cover "breakdown" this  one  in the time of the event showed light as well.
I was playing with the  bifilar coils in the ferrite.
Over sudden my 150W bulb started to get brighter and brighter in 8th second it  blow up
The measured total power delivered was  roughly 2.75W.Voltage level delivered  8V ( but to flyback ,square signal adjustable  duty cycle)  current of primary 0.35A
I'm sure  what I'm talking about.
You may laugh...That is OK with me. In upper post there is the question asking for the hint so I'm giving it to you. After that fact I have called to  few guys from the scientifically involved group I'm in. "What should I do" I have asked.
The answer was:
"Do not do anything, do not run  for another bulb.You can not experiment  like amateur.
Mess on the table, when you have no idea what is going on.You have seen it once You will see it again."
After that I invested in my lab than in mechanical part of it.
I was approached by Shocac and I was hesitating to give  whole story to you guys till now.
Also I have solved problem with the spark no  more oxidation and clear VISUAL!!! representation of the frequency of the spark  and frequency changes with  NO METER USED!!!
If you want I will post video with How I DID IT.
My videos to Tariel are so  much  insured that Free Energy is working
My approach to this subject is purely scientific.I'm not interested with building device but understanding and learning  how it works.First there is theory, than experimenting,than technology ,resulting product.
That's all no more abut this till I will be ready for something solid and undeniable.I do not want to earn any credits, but  additional humiliation is unneeded.
So feel free... your critics.. is yours.
Wesley
dllabarre
Quote from: stivep on January 28, 2011, 11:26:08 AM
Wesley
I would like to see the video of how you did it.
DonL
stivep
Quote from: dllabarre on January 28, 2011, 11:42:07 AM
DonL
No problem give me some time and I will show you the secrets of how to
have no oxidation at all,
-clear uninterrupted spark,
-extremely repetable and steady level of the spark
-visual representation of frequency changes with  no meter  or scope used,
-Frequency response due to "dips" in resonant points
-accurate differentiation and spotting of   max resonance
-harmonic components visual representation
-measurement and graduation of "from the strongest to the smallest" of resonance responses.
That is a lot for no money spend on the instruments.
Wesley
PS:
Please read carefully what I meant by using words " How I did It."
Please note what is in my statement about experiments and information shared
Please ... sentence Quote:"Show me  the video"...... is  offensive..
iceweller
Quote from: forest on January 28, 2011, 10:28:30 AM
Yes,I believe you are correct. I spotted something which may be the same effect years ago but never was able to reproduce. Suddenly air become like highly electrified with stinging effect on skin.It was this effect or x-rays (hopefully not)  I do not know but rather this effect we are looking for just for badly low frequency -I had trouble to disconnect circuit because even car battery casing was kicking.
The circuit was surprisingly simple - only old car coil with a piece of wire soldered to the incandescent bulb. This bulb was broken as I remember , there was no plasma inside but instead this strange electrostatic intense field around. I recall this because in green box video guy keeping device was kicked exactly like I was when trying to shutdown circuit. I was scared about x-rays probability and quickly dismantled circuit.
So it must be very very simple but probably require certain exact parameters to match !
    The guy (Tariel's son) was "kicked" because he stuck his finger in the 12V fan while reaching for the switch.
    Also, the ether is a "medium". As such it transports EM longitudinal waves (Tesla said that it is like "a sound wave" in the ether). Another important Tesla quote is that the effects of static are the effects of ether "under stress" and that the effects of dynamic electricity are the effects of ether in motion. In all these setups we have both, I believe a "sine qua non" condition for this to "extract" energy from the environment (= convert or absorb high energetic levels which are present in our natural surroundings into a current).
   A question to all about the presence of ferrite or not in the core:
   Considering that this effect is present at a rather high frequency (100-400KHz) triggered by the SG and tuned to 1/4 wave resonance, why would the presence of ferrite which would lower the resulting frequency and help in extracting the energy by increasing the "capture time" be avoided? There is a brief window where to "move" this extra static surcharge (for lack of a better term) into a dynamic usable current, but it takes a determined amount of time, which the increased inductance and hysteresis of the ferrite will give. Granted that the faster the "switching" the more energy one can extract in the same amount of time, one needs to learn to walk before running.
