0 Members and 228 Guests are viewing this topic.
quarktoo
Quote from: XS-NRG on January 28, 2011, 07:35:09 PM
IS
Voltage prior to current flow does not produce an electron avalanche which is the result of fusion and subsequent fission taking place in a unipolar spark gap. Without that cascade effect, I don't see how you could have cold electricity since to produce cold, we need to produce a space of vacuum.
Particle annihilation or splatter would create that space of nothing.
Do either of you think that a spark gap is inside Kapandadzi's coil?
Choose username
Quote from: quarktoo on January 28, 2011, 06:52:32 PM
Has anyone figured out TK latest pump thingy? It sounds like the magnetohydrodynamic effect Stan Meyer spoke of. I wonder if Tesla used that effect to drive his turbine but didn't speak of or patent it?
Once Tariel has told: The most important thing - understand this hidden principle. Then you can use it to create any device. Without a difference. It can be electric, mechanical, hydraulic, etc :)
quarktoo
When I look at his coil, I really see three secondary coils in series next to the spool.
I think they are being energized sequentially because if they are in series and the end of each coil loops through the core before going to the next coil, then maybe you get a pumping action on the core.
The core then becomes like a magnet but only 1 aether particle (polarity) is coming from the coil (longitudinal wave)
The outside coil pulls from the opposite direction to produce a standing wave in perfect symmetry.
It looks like his coils changed a little when he got rid of the spark gap
Does that make sense? I am not good at explaining things in any language.
LtBolo
Quote from: Choose username on January 28, 2011, 07:51:24 PM
That's been my thought all along. Understand the basic flaw in the physics, and you can apply it in many ways.
Any clue as to what that principle is?
LtBolo
Referring to TK's bad appearance...
There is a very good likelihood that at the energy levels his devices operate at, the smaller devices are putting out soft X-rays, and the big ones might even be putting out hard X-rays or even gamma rays. It may turn out that although these devices might be built for very little, the shielding requirement might make them very impractical in actual use. Admittedly speculation, but, given TK's rapid decline and SR's statements about not feeling well for some time after running his device, there is some support for it.
TK's move toward mechanical versions may have been driven in part by an understanding that the electrical versions simply aren't safe.
Ben Schwartz is supposedly nearing production on the ERR device. Word from him is that the generator plates will be installed in a concrete vault below ground. Iron rebar cannot be used to reinforce the concrete, or it will explode, and apparently will require fiberglass rods instead. I was thinking that the problem with the ERR was actually random lightning strikes, but at the power levels these things are supposed to operate, it could also be nasty emissions.
At the very least, if you get something working...please...be careful. It simply might not be safe.
