Ghost_Rider
Quote from: Herger on January 28, 2011, 07:01:25 PM
The effect before the electrons drift is not cold electricity or cold current.  This is the wave effect, for lack of a better term, that can cause current flow under certain circumstances.
This is true.  Effect before current is not cold current.  Cold current is when the effect change charge on matter.  Sometime all is cold current and sometime no cold current.  When magnetic field same direction as wire is mostly conduction.  When across is mostly cold.  Cold is bad word.  Cold does not make wire hot.  that is all.
Ghost_Rider
Quote from: quarktoo on January 28, 2011, 05:16:19 PM
Here is a good definition of cold electricity.
http://wikibin.org/articles/cold-electricity.html
Cold electricity is a process that involves two phenomena of physics, electron avalanche in a high voltage spark gap exposed to open air at atmospheric pressure and electron-positron annihilation. Gain is a term in electrical engineering that is used to describe a ratio of increase. Electron avalanche in an open air spark gap can be employed in an electric circuit to provide a gain in current in the circuit. Electron-positron annihilation is a process by which electrons combine with positrons to produce radiant energy.
The production of gamma radiation and magnetic longitudinal waves can be employed to induce a voltage gain in an electric circuit by means of the photoelectric effect. Thus, electron avalanche and electron-positron annihilation can be utilized to produce a gain in current and voltage within an electric circuit to produce electric power.
Some people make this up and is not true.
quarktoo
Quote from: Ghost_Rider on January 28, 2011, 09:25:25 PM
Hi Ghost_rider,
If someone just made that up, any chance you could set the record straight then? Also, do you understand the principle of operation of TK's device? If so, what is it?
penno64
@all,
That delamorto is really progressing -
http://www.youtube.com/user/delamortodelamorto#p/a/u/0/OegYgl3STHY
@quark,
I can help if you want dole's cold stuff. Let me know
Penno
quarktoo
Quote from: penno64 on January 28, 2011, 09:38:22 PM
@all,
@quark,
Penno
Hi Penno,
Dole did get back to me and gave me some info. but I'll take all the help I can get. PM me or if there is a thread, lead the way.
