0 Members and 18 Guests are viewing this topic.
Ghost_Rider
Here is good information.  Try experiment for mass wave and you will see.
Quote from: quarktoo on January 29, 2011, 03:09:20 PM
Don't think about it Forest, it's a pancake coil.
The likelihood that you could replicate something from a patent is usually next to zero.
Patents are to claim intellectual property. Left intentionally vague, they allow the inventor the possibility to claim more than what is there through a lawsuit. It is a legal document, not an engineering guide.
LtBolo
Quote from: Ghost_Rider on January 29, 2011, 05:32:08 PM
Can you point to some information on this experiment, Ghost? I'd like to study this more.
Ghost_Rider
Quote from: LtBolo on January 29, 2011, 06:37:21 PM
Is simple.  high voltage positive pulse to big coil.  Only small current but high voltage.  Pulse must be very fast.  I have friend he use ignitron and big spool magnet wire and get good result.  All avalanche device work even spark gap.  If mass wave move through magnetic field it makes very much stronger for small cost.
Mass wave is in all direction strate around coil
dllabarre
Quote from: quarktoo on January 29, 2011, 03:24:35 AM
Thanks Penno, I spotted that already and got some more info. from him.
Quarktoo
Dole replied to me and asked me to collaborate with you on replicating his circuit.  Please send me any information he gave you or post here.
If you need to see his post to me I can forward it to you.
Thank you,
DonL
stivep
Quote from: forest on January 29, 2011, 03:32:10 PM
Interesting.... are you trying to discourage me from building it ? Huh !?
My point is : seems that for Tesla it doesn't matter if pancake coil have air of magnetic core. The ,method works the same.
I would guess that Tesla at least checked it. There is also small clue that he may used magnetic cores more frequently.
From the same patent.
http://www.teslauniverse.com/nikola-tesla-patents-649,621-transmission-of-energy
"The length of the thin wire coil in each transformer should be approximately one-quarter of the wave length of the electric disturbance in the circuit, this estimate being based on the velocity of propagation of the disturbance through the coil itself and the circuit with which it is designed to be used. By way of illustration, if the rate at which the current traverses the circuit including the coil be one hundred and eighty-five thousand miles per second then a frequency of nine hundred and twenty-five per second would maintain nine hundred and twenty-five stationary waves in a circuit one hundred and eighty-five thousand miles long and each wave would be two hundred miles in length.
For such a low frequency, which would be resorted to only when it is indispensable for the operation of motors of the ordinary kind under the conditions above assumed, I would use a secondary of fifty miles in length. By such an adjustment or proportioning of the length of wire in the secondary coil or coils the points of highest potential are made to coincide with the elevated terminals D D', and it should be understood that whatever length be given to the wires this requirement should be complied with in order to obtain the best results."
925Hz is within the range of soft iron core.Rather then air core, of course I'm not sure.
Well  I have problem with that statement of yours..
The HP 3562A Dynamic Signal Analyzer is capable of tuning to mentioned frequency range.
My HP 3494A Impedance gain phase Analyzer as well
That does not mean that resonant circuit should utilize miles of wire.
to better understanding what I'm talking  about and what is important to understand Ferrite pipe coil of Kapanadze please find some time to go to
http://www.youtube.com/watch?v=QwUgYBzdcrM
if you want to have better understanding of "energy from Vacuum" please find some time to go to
http://www.youtube.com/watch?v=rnkBgp7ZtEA&feature=related
For many there is unclear that photon is pure energy without  any mass but when it hits the blackboard or any body  than electron is elevated to higher orbit.
Spark- in form of plasma is mass represented by electron flow that is why you can deflect it using magnet.
electromagnetic wave is photon flow based on traditional physics.
Dual conversion photon  to electron in (e.g air particle) and than photon  is  described  in second link.
Important factor to understand dependency of photon to electron conversion is size of the particle - photon is bombarding and its behavior
Wesley
PS:  in the middle of  the video ( resonance circuits) there is clear explanation of Q in regards o introduced metal into the coil as well as inductance behavior
Please I know that for some of you it is hard to fallow this video but  you will be much...much.. ahead after that
for those who want controversial but very helpful information please log to
http://www.youtube.com/watch?v=UXvAla2y9wc&feature=related
This video is kind of essentially important
