0 Members and 68 Guests are viewing this topic.
quarktoo
Quote from: stivep on January 29, 2011, 09:58:57 PM
Yes you are right I should say ferrite rings joined together create ferrite pipe
Thank you for correcting me.
As far as other comment Yes  respect to Kapanadze.
But  at the same time respect to SR
and he was only 19 years old..So is that the knowledge or just accidental.
If it is accidental that you my friend might become as successful as Kapenadze as knowledgeably is not that important as a little bit of luck.
Thank you for your comment
Wesley
Stivep - Do you think he could have used ring magnets instead of ferrite? Ring magnets are made of ferrite too.
I think it is an accelerator coil.
stivep
Quote from: quarktoo on January 29, 2011, 10:12:59 PM
No( but I might be wrong)
Structure of ferrrite magnets differ  to one of ferrite  rings.
Ferrites are chemical compounds, ceramic with iron(III) oxide Fe2O3 as their principal components.
Ferrrite rings = iron sand + oxidation, bounded in process of compression (soft ferrite)
Ferrite magnets=  magnetic materials + oxidation
and they are used to make permanent magnets,
(Hard Ferrite)
  soft ferrites. The low coercivity means the material's magnetization can easily reverse direction without dissipating much energy (hysteresis losses), while the material's high resistivity prevents eddy currents in the core, another source of energy loss. Because of their comparatively low losses at high frequencies, they are extensively used in the cores of RF transformers and inductors in applications such as switched-mode power supplies (SMPS)
soft ferrites are manganese-zinc (MnZn),  and nickel-zinc (NiZn),
hard ferrites
have a high coercivity and high remanence after magnetization. These are composed of iron and barium or strontium oxides. In a magnetically saturated state they conduct magnetic flux well and have a high magnetic permeability. This enables these so-called ceramic magnets to store stronger magnetic fields than iron itself.
As you see there is major difference in memory.
(If you fallow the lecture from video link listed  in my previous post)
1.DC does not affect current
you will see current flow only when you  close the circuit.
(*watch the video lecture -first few minutes)
2.Steady state of magnet does not affect steady current
That indicates that the biggest problem of magnets is long term memory.
The particles in soft ferrite can change the magnetic dipoles polarity  immediately, although some of memory  remains. That is good.
The particles of hard ferrite are characterized by permanent memory  the dipole reverse put them in to the state of reversed permanent memory.
Than only- the potential benefit of conjunction for both may take advantage of electron path directed by magnetic influance to the right place.
Yes.....Watching video:
Quantum Mechanics: The Double Slit Experiment
http://www.youtube.com/watch?v=UXvAla2y9wc&feature=related
You will see collision of photons and very controversial collision of electrons.
As long as we deal with electrons we deal with mass containing particles.
when we deal with  photons we deal with something that is completely  immune to the magnetic field( of that magnitude)
Do not forget  to look at my previous post  video link
Wesley
quarktoo
I'm pretty sure you are wrong.
I have my own explanation of wave particle duality, the double the slit experiment and it does not involve magical properties like what is being taught in school. Maybe I missed your point but when you cite classic physics lectures, you are also buying into the impossibility of an OU device UNLESS you are using an accelerator and then E=MC2 applies. So your comments conflict with themselves.
Correction - I am sure I missed your point. I understand ferrite and magnets and accelerators. I also just spent a day pouring over that video of SR93 and I am seeing what looks like an accelerator coil. Without acceleration, the second law of thermodynamics is going to apply.
Maybe you should learn about different accelerator coils and you would agree with me. If that is what it is, I assume it would be dangerous to stand in front of. It would be easy to tell by pointing it at an old TV screen. You should see the phosphor screen light up as the particles collide with the phosphor screen.
I cannot predict the affect on the magnets since they all have different elements in them since the particle velocity is unknown.
I could probably replicate this device but am losing interest. Perhaps in the future. I am working on a an alternator project that is taking my time.
Anyway, here are some pics and thoughts on SR193 device. Is he available to chat?
ramset
quarktoo
So an alternator must be able to cause acceleration or you wouldn't be playing with it.
Can you talk about this Somewhere?
BTW a movie,
http://www.youtube.com/watch?v=jB1p4-Az5qY&feature=related
Chet
Thanks Grandma
wattsup
@all
This post stubbornly continues from where my last post left off. Please excuse me for the length but it is required to pass on this information in a clear manner on how I have learned the TK device is doing what it is doing in the demo. This is an exercise in 360 degree thinking so I hope that those interested in the subject will be able to follow along. After this post, I will step away from this for a while because I have my own works to finish off.
One thing I forgot to mention about the TK coil. Or did I? Only one wire out of the green box (gb) goes into the TK coil. There is no other way for him to use this coil. The main reason is the number of bulbs he lit with the green box. Five bulbs that were well lit. So let's say 100 watts per bulb makes 500 watts. Right?
The 12 volts but still 20 amp from the battery makes 220 volts 1 amp at 50 hz leaving the inverter. The 220 volts 1 amp goes to one (or more) high voltage transformers (htv) cranking up and making 5000 volts* but at 5000hz* so the total amperage draw from the inverter becomes minimal.
If TK was using more then one isolated coil in the TK coil, there would have to be a question of energy transfer from one coil to the another coil. For that to happen you would require a minimum of two wires coming from the green box. Even then, I can surely certify that those coil wires are in no way and shape going to be able to mutually transfer 500 watts of juice from one coil to the other and the losses would have been tremendous. So the coil has to be linear and for it to be linear with two coils, either series or parallel or a mix with one coil wire open ended. But all that sounds useless with such wires.
The only real and logical solution for the TK coil is one coil of 4 layers ending with an excess of about 33% of full length on the top layer. It is possible that the 33% length top layer is a "remnant layer" because he had to cut down on the coil overall length to tune it closer to the green box resonance output.
At one point, once TK made the gb, he saw he needed some "muffling" from a gb capacitor discharge, so he probably made the coil and saw the bulbs were not lit enough and by removing one wind at a time, he found the right number of winds to match better the gb output and increase the output to the bulbs. Any one can do it. By the same token, his output from the green box could have already been stabilized and again the TK coil could still be a dud. So at this stage the TK coil should not be taken seriously until the green box theory is workable and the problem left to solve is output matching to load and low end loop-back. I'll get to that soon.
However, a one coil TK coil would have an effect on a high voltage side stream of low amp spikes, like a spark gap or a capacitor discharge reducing the high voltage with its fewer winds and by doing so increasing the amperage by its copper mass. It would fall in perfectly with how TK described it as a stabilizer for his bulbs. Ah, but this could be also a ruse, we now.
The one coil wind can also be a bifilar wind that still has one wire from gb in and one wire out to the load. There is simply an inter coil connection and the bifilar will provide a better capacitive function for the TK coil. But that's it and that's all. There cannot be any more functionality then this, either one single wound coil or a bifilar coil either of which are in series with the outer 6 turns coil before it goes to the bulbs. There is no reason to think that pulsing that 6 turns heavy coil will induce 500 watts of output into the inner coil. Just not possible especially or reagardless of any resonance point.
So now I know what the coil is and it can now be put aside for now because based on this, now I know a lot better how he is doing it. But let's go further on.
First and foremost is - what does the gb demo demonstrate? It is demonstrating lighting five bulbs. Stop right there. So all he needs is at least 50Hz for the bulbs to be visually constantly energized and bright. Now take the output 500 watts at 50 times per second but each applied pulse does not need to be 100% duty width because even at 10% duty width you will see the bulbs fully lit at 50hz. I tested it. At 10% duty width you are again not using 90% of each pulse cycle but your bulbs are still fully lit.
Two transistors, as one pulses at 10% width and is off 90% of the width, the other one sends the energy 90% of the time back to source. Ha. Ha. Spider senses are tingling. I think this is the simple idea. Very simple indeed.
One transitor is pulsing the 10% all the time. So it is at 500 hertz. The other transistor is on only 10% of the time to the bulbs. So at each 10 hertz the pulse goes to load. The whole device in the green box includes high voltage, continuous pulse to loop back and load pulse.
This means the inverter/battery is being solicited at maximum just to start the device. Once it's started 90% of the looping is happenning inside the green box. When he removes the battery, his black box transformer is definitely not supplying 12 volts at 20 amps and that is fine because the inverter does not need that much anymore since 90% of it is being recirculated already. All he needs is the make-up energy to loop the device indefinitely. Just enough to loop the make-up with his black transformer box while still leaving enough for the bulbs.
Now consider the inverter he is using is a rather old model that obviously does not have the modern minimal dc input requirements or else the inverter would simply beep and stop. His inverter will use any input and provide output. This is an important point to keep in mind. The inverter throughput must be as linear as pôssible.
But now, if you consider the above statements, you will quickly realize that there is a certain level of illusion involved in the TK device. One would presume by looking at the demo that the TK coil is ultimately lighting up five bulbs and at 100 watts a piece, so it is consuming at least a good 500 watts. But that is not the case and that would explain the funny smirk in some of the guys faces during the video. And this is where all have failed because you are trying to do it the standard way.
You do not need 500 watts continuous 50 hz to light up those bulbs. All you need is 500 watts at 10% duty width at 50 hz and the bulbs will stay as bright as they are. lol
Two switches on the gb. One starts the system and the other starts the 90% loop back. If the loop back in ON first, the device will not start because the other end of the spark gap will act as a premature load.
OK so where to start with all this will be the next questions? Guys with already built units will have an easier time with any needed mods. Guys with EE smarts will understand the trans usage. Much better then me.
(*) The HV volts and frequency mentioned above are just figurative and can be much higher. It does not matter. You can match lower voltage with higher inductance.
This same simple idea can be extended to mechanical or hydraulic systems since it is all ratios. The basic idea is use an elephant to move a mouse that looks like an elephant.
There are so many ways to play with the ether around us.
wattsup
PS: I hope someone can translate this for our overseas friends.
