Pirate88179
wattsup:
Great explanation there.  At the risk of over simplifying what you have said, would it be fair to say that TK has developed a joule thief circuit for incandescent bulbs?  What you describe is really how the JT circuit operates and allow them to do all of the seemingly amazing things that they can do.
Again, great summation.
forest
Quote from: Pirate88179 on January 31, 2011, 03:42:25 AM
wattsup:
Imho if you want to see it like a JT , think about joule theft with Avramenko plug sucking displacement current from ground.
lasersaber
@wattsup
Your explanation sounds a lot like what I see happening with my Joule Ringer.  I think I will start trying to light incandescent light bulbs instead of CFLs and see what happens.
Here's a picture of my current device running disconnected from the batteries.
quarktoo
Actually you are all wrong and I can prove it. Normally I spew more BS than everyone here combined but I am just trying to get some ideas out there.
Last night I did my homework and studied the patent and then got lucky and found a few documents that supported it.
Here it is in a nutshell:
The coil is called a loose coupling transformer. The reason that there is that bottle end sticking out or a threaded bar is because that is how they are sliding a piece of ferrite in and out to adjust the coupling between the two bobbins.
There is a unexplainable electromagnetic phenomena or two and this one exploits that just enough. You can sink approximately 10% of the primary tank into the secondary load coil.
The primary runs at 8 times the frequency and voltage as the secondary. One end of the secondary is tied to the primary tank circuit which is a parallel LC tank. The other end of the secondary is tied to earth ground and so there is no short of a dipole. There is another exploit back to the primary that I am going to keep to myself for now but I will tell you this - He in fact replicated Tesla's device and that is all it is.
It is in the fish tank to muffle the noise of the spark gap.
While you would need to have the equipment and be good at building with passive components, this device can easily be replicated and I am 99% sure the earth ground can be eliminated and I think I figured out how tesla did that with his car - same thing.
Anyway - read the patent. He explains it fully. The parts that he didn't explain, I just did. It's simple.
The end of the coil that sticks out indicates to me that SR193 did in fact replicate successfully. In fact - you see three wires attached to the ground just like the patent. That patent drawing is so good and the device is so simple, this may be the first device you could replicate from a patent.
In the video where you see three different color coils - those are just chokes for a larger system. Don't be fooled by the difference. The choke have iron rod cores and the transformer has ferrite cores that are loose coupled.
The arcing over to the side of the cap is because he does not have a more expensive 3 wire RF cap so he is just shorting to the can. Stray resonances are one of the problems he has had to work hard to filter out to keep it stable especially with a changing load. Oddly, this is where he is adding another harmonic for a total of 3.
Hope that helps you see what is there. This has noting to do with a joule thief.
