quarktoo
Quote from: wattsup on January 31, 2011, 10:40:36 PM
@tagor
Thanks for the link.
@quarktoo
This patent is dated 2008. The green box video I was talking about is mid-90s if I am not mistaken. Thank you for mentioning this patent of TK. His name is right on the doc. So about 12 years later. This shows a good progression of the device but for sure the patent says exactly what one would expect. Nothing major, just enough to patent.
But there is module #4, the primary high frequency generator module and you see the module #11, the secondary frequency adjuster module that is at the output. This falls in perfectly with a progression from his GB to now.
When you look in the Plexi unit, you can see the real coil types his patent would talk about. They are not like the one in the GB demo.
12 years later, and now we are 3 years after that. Long live the patenting process and god help the world.
wattsup
Not sure what you are trying to say. The parts are laid out EXACTLY as one would expect would be required to fulfill the description of how it operates.
The number of ways you could build that circuit are endless but the general idea of how it works will stay the same. The number of things a person could do to improve it are also endless.
Bearden and Bedini have ranted for decades on not destroying the dipole. It shows you a method of how to accomplish that. It is a new trick for me so I am thrilled to have spent the time I did since the possibilities are endless. It does not use an accelerator or convert mass to atomic energy. Unstoppable! Tesla's patent covered it and from a patent search Kapanadzi does not have a patent in the US.
You don't a patent to build and sell a produce and if someone patents it after you do that, you can invalidate their patent.
You should be able to take roughly 10% or no more than the idle current from the primary tank inductor and it should run OU.  I never though of using a magnetic connection to prevent dipole shorting. How cool! Do your own thing on a breadboard and have fun with it.
exnihiloest
Refering to (given above):
http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=50623
This diagram gives an erroneous interpretation of Kapanadze's patent.
"Chokes" are large inductances having a high impedance to block highest frequency signals in a circuit.
In Kapanadze's patent, box 5 is named: "first filter". If the box 5 was a choke, then no current would significantly flow in the first coil. Only a low frequency current could pass, but we know that this coil is built for high frequencies.
For the same reason, box 7 can't be an "adjustable choke". And a choke has never to be adjusted because of its role of blocking all HF signals. It is different from a low pass filter. Moreover in Kapanadze's patent, box 7 is named: "first frequency adjuster", which is different from "filter" (box 5). Thus it is a pure non-sense to presume that these boxes are "chokes".
exnihiloest
Quote from: wattsup on January 30, 2011, 05:21:43 PM
Even then, I can surely certify that those coil wires are in no way and shape going to be able to mutually transfer 500 watts of juice from one coil to the other
I don't share this opinion. In HF power amplifiers, especially those with tubes which have a much higher impedance than transistors and are tuned for a particular frequency, there are high Q resonant LC circuits. As the impedance of the charge, for example an antenna, is much lower, only few turns of wire coupled to the tuned coil are enough to transfer almost all the power from the resonant circuit to the charge, in an efficient way (the same as a down transformer with a big winding of thin wire for a high voltage input and a much smaller one but with wire of larger section for the output).
In Kapanadze's device, a ratio until 50 (may be even more) is possible. Perhaps there is 10 kV or more at the terminals of the primary resonant coil, for 200v out.
quarktoo
Quote from: exnihiloest on February 01, 2011, 04:39:38 AM
The numbers I had to work with from a Russian was the secondary is 1/4 wave length of the primary. The mutual coupling is weak (10%) which is what I would expect to see otherwise your tank is going to require a lot of power.
500Hz on the primary side divided by 10 on the secondary.
You can see the output coil appears to be about 1/4 the size on some of the coils and from a tap you see coming off the coil. While it is not in RF frequency range and certainly not "high frequency" it looks to me like two signals getting mixed in the load.
I saw a video of someone trying to look at it with an HP network analyzer and he could not explain what he was seeing nor had he seen anything like it before.
And finally, the tank resonance is going to be destroyed immediately without some chokes which is why I interpreted the patent that way. Feel free to contribute your own but if you think this circuit is explainable with classic EM and RF theory you may be disappointed. It's a self powered free energy device, not a ham radio or a network transformer.
I use the word choke instead of inductor. Semantics..
MasterPlaster
Does any one have this article?
Characteristics and Design of Transformer in Loosely Coupled Inductive Power Transfer System
Also this provides a good read:
http://www.hindawi.com/journals/ape/2010/546529.html
