0 Members and 83 Guests are viewing this topic.
exnihiloest
Quote from: quarktoo on February 01, 2011, 04:55:59 AM
The numbers I had to work with from a Russian was the secondary is 1/4 wave length of the primary. The mutual coupling is weak (10%) which is what I would expect to see otherwise your tank is going to require a lot of power.
What I was speaking about is current technology of radio engineering in AM broadcast transmitters. The efficiency of the coupling is more than 90%. This method is even widely used to cascade several stages in a chain, it permits to match the high impedance of an anode output to the low impedance of the cathode of the next stage in a common grid tube amplifier.
500Hz on the primary side divided by 10 on the secondary.
It is not said in the patent.
500 hz is much too low, it is certainly not compatible with the coil we see in Kapanadze's device. Such a coil is not tunable at this frequency. Even if there is no HF, a frequency of at least tens or hundreds of Khz is required for such a coil to be tuned.
Feel free to contribute your own but if you think this circuit is explainable with classic EM and RF theory you may be disappointed
The source of energy is unknown. This doesn't disprove classical electromagnetism. If you suppose it is wrong, you must suppose that all other physics laws are also wrong because they are tightly linked and logically related. Therefore you can't "explain" anything because you have no more basis, you can no more talk about "current", "frequency", "voltage", "inductance" and so on because only science defined them. And finally you just would speak of magic. As it is not the case, it is obvious that classic EM still applies, it appears in your own speech. We can't arbitrarily keep what is pleasant in EM and reject the rest, we would loose consistency and logic. So if there is an anomaly, it should be very subtle and at the fringe, not in the way a particular coil can be tuned or coupled.
dllabarre
Quote from: quarktoo on January 31, 2011, 11:50:04 PM
Bearden and Bedini have ranted for decades on not destroying the dipole. It shows you a method of how to accomplish that. It is a new trick for me so I am thrilled to have spent the time I did since the possibilities are endless. It does not use an accelerator or convert mass to atomic energy. Unstoppable! Tesla's patent covered it and from a patent search Kapanadzi does not have a patent in the US.
You don't a patent to build and sell a produce and if someone patents it after you do that, you can invalidate their patent.
Q2
Please excuse this stupid question but which Tesla patent are you referring to?
DonL
Omnibus
Of course, it is not true that the laws of contemporary science are tightly inked and logically connected. Even the basic laws of theoretical mechanics aren't, as I've shown here: http://www.overunity.com/index.php?topic=8438.msg272750#msg272750
Classical electromagnetism isn't in any better position either. Maxwell's equations, for instance, which are fully applicable in the case of the homopolar (Faraday) generator, badly fail to account for the voltage observed experimentally in this generator. To explain the observed voltage one has to rely on the Lorentz force which cannot be derived from the Maxwell equations and it should if the Maxwell equations are truly the equations describing the electromagnetic phenomema.
The list with fundamental problems in incoherence, lack of logic and sheer nonsense the contemporary science suffers from can go on and on. Unfortunately due to the dishonesty of the few competent and the massive incompetence of the majority makes not only the mainstream to be in shambles but it allows that creedence be given to obvious esoteric blabber and sheer charlatanism. The discussion at hand is not the only example where gullible enthusiasts can be led by the nose for months and years by a manipulator, even if he does his manipulation subconsciously and truly believes in what he demonstrates.
core
Quote from: LtBolo on January 28, 2011, 09:17:57 PM
Referring to TK's bad appearance...
There is a very good likelihood that at the energy levels his devices operate at, the smaller devices are putting out soft X-rays, and the big ones might even be putting out hard X-rays or even gamma rays. It may turn out that although these devices might be built for very little, the shielding requirement might make them very impractical in actual use. Admittedly speculation, but, given TK's rapid decline and SR's statements about not feeling well for some time after running his device, there is some support for it.
TK's move toward mechanical versions may have been driven in part by an understanding that the electrical versions simply aren't safe.
Ben Schwartz is supposedly nearing production on the ERR device. Word from him is that the generator plates will be installed in a concrete vault below ground. Iron rebar cannot be used to reinforce the concrete, or it will explode, and apparently will require fiberglass rods instead. I was thinking that the problem with the ERR was actually random lightning strikes, but at the power levels these things are supposed to operate, it could also be nasty emissions.
At the very least, if you get something working...please...be careful. It simply might not be safe.
  I was a bit alarmed also from his appearance also. I believe what LtBolo stated above could be true but there is another way to sport that look. Tariel has that 'Hobo' look. This is an appearance that is mastered on the streets of NYC. I see them all the time, there is one guy who is always at the foot of the George Washington bridge, he has the look down pat. Here are the rules for the Hobo look.
1 - Smoke 3 to 5 pack's of cigarettes a day.
2 - Drink 2 bottles of vodka a day, vodka can be substituted with Jack Daniels or Southern Comfort.
3 - Eat nothing but garbage. No complex carbs on this diet or high protein products simple carbs work best.
If you look at Tariels video's he has rule #1 down pat. I don't doubt for one minute that he has mastered rule #2. Rule #3 is a gimmie. He spends so much time experimenting that proper diet takes a back seat.
Now what LtBolo stated can be true, very true. The 'key' would be to see what condition his son is in. I will guess that his son spends many hours with him if not every moment. If he is showing these effects then it could be radiation. Or he could also be following the 'Hobo-diet'.
Part 2
  Now on the experimental front. I have taken a different path then others. I stand stubbornly firm that in order to interact with the environment you must incorporate the environment in your design. I have done just that and have been given just enough of a 'magical' peak to move forward and continue.
  On the topic of the environment. Air is the name we give for the gas we breath. Many people seem to forget this. The gas you breath is in a 'super-heated' state. In a nutshell it has absorbed enormous amounts of energy to get to that state. If it didn't it would be at or below the 'saturation' point. Clearly if it wasn't super-heated your lungs would be full of liquid. So the first thing that must be understood for me is that an 'air' core is actually a 'gas' core.
  A typical air core doesn't trap the atmosphere it allows it to pass through because clearly the ends are not sealed. So any 'disturbance' that is created is quickly neutralized via the escape routes (ie.. the open ends of the tube). A great example of trapping a gas can be seen with a basic Xenon flash bulb. In this bulb high voltage is used to ionize the gas. Knock off enough electrons and a conductive path is created for current to flow. This gas like most others will self-heal itself meaning goes from highly ionized to neutralized on its own, very fast, when HV is removed. The amount of HV is important, enough must be injected to create this 'change of state'. Of course this gas must be 'trapped' to work effectively. So it stands to reason that a Xenon bulb can also be used as a fast acting switch to drive a current.
  It is along these lines that I have been tinkering. The exception is that instead of Xenon I will use Air. Not only that, I will trap the air in a closed tube. In theory this is a Gas core (aka air core) but I am not allowing it to neutralize with the open atmosphere. With this in mind prior to building I had many questions that I could not answer.
One of the biggest questions was 'What would happen if a strong magnetic field where present when the sealed tube was ionized?'. High voltage is 'cheap' meaning it does not require a lot of power to create. But yet HV creates effects on the atomic level with very little power input.
There are many avenues of approach one could take. With that I figured I would start with the simplest design and build on it. For starters I built a basic setup that consisted of just a 9 inch piece of 1 1/4" PVC tube. From here I capped it with 1 1/4" PVC caps. Prior to capping I drilled a small 1/8" hole on one of the end caps and inserted a 14 gauge copper solid conductor. This conductor is stripped back about 1/2" to expose the copper then inserted into the hole in the end cap. I also epoxied the wire to the cap so it would not move. This solid wire was then wrapped with some rubber electrical tape to minimize leakage of HV.
  Feeding the wire in the tube is the spark gap. Basically HV from a auto-transformer is feed to a spark gap, output of spark gap feeds electrode in tube in an effort to 'ionize' the air inside. On the outside of the tube is wrapped about 90 turns or so of CSA insulated aluminum wire. On top of that is a small coil of about 30 turns of 14 gauge wire. The 30 turn coil was operated manually by hand by shorting it to a twelve volt 6 A/H battery.
  I started a day ago. I first started with very low HV. It was difficult to maintain a spark gap. I am driving my 12 volt HV transformer with about 7 volts or so from a 9volt battery. My HV driver can except up to 24 volts DC input. I have plenty of 'headroom' to work work with. With full power to the driver I should be able to deliver somewhere between 30 - 40kv at around 200 - 400 Hz with a 24 volt input. I tinkered with this for a few hours allowing the battery and jumpers to cool down every so often. I have a electrical meter hooked up to the 90 turn coil, one side of the coil is grounded. This setup is pretty uneventful, there was on three occasions that a was able to obtain about 500 or so volts all other times 0 volts. This voltage reading was difficult to produce consistently out of the 400 attempts of spiking the small coil only three times did the phantom voltage show up.
  Regardless this is the approach I am taking. I plan on raising the high voltage to see if I can repeatedly reproduce this 500 volts (give or take at first it was 460, then 510, and the last time 490volts). I am well aware that I could be chasing a ghost.
  One thing crossed my mind while doing this is to 'dope' the inside of the tube with Americium 241. Small amounts can be found in smoke detectors. This of course brings these experiments to a level that requires proper protection. This I will not try until I have exhausted current avenues of approach.
  Below is a pic of my simple coil.
Respectfully,
Core
