0 Members and 95 Guests are viewing this topic.
TheCell
Q2
starting with the way it might work
sparc gap and or primary coil are draining the ether energy that is ready to be picked up from the primary coil, whose frequency is i.E. 500 Hz
The frequency of the secondary coil is then 50 Hz ; thereby the frequency difference makes the energy flow from the primary to the secondary coil.
(Which victor Grig mentions in 'Principle of work of Kapanadze's device')
The low coupling between the primary and secondary dampens the primary only slightly.
These 2 frequencies must be applied to both coils which costs energy.
At the starting point a battery is providing the power, later on the energy gain from the ether (or what should I call it) should do this.
I don't know transformers, that divide frequencies. The frequency differences may provide a tunnel for the ether energy, but may disturb each other, so there the filters might come in action. The output stage that provides the 50 Hz to the secondary, how it is designed?
The influence of the first coil must be somehow transmitted to the second, therefore the second may not be short cutted by an amp that provides 50 hz. (This influence is it magnetic or static?)
What SR did was saturate a core with approx. 1.4 Tesla Field, but this is another effect which leads to detoriation of the core material, and you exclude converting mass to energy conversion.
Most likely we would create a transformer with losses (like I did and many others , even Naudin)
These 2 freq gen operate with a pll loop .
citation of some part of the above mentioned document:
When in the Ukrainian common energy grid, inherited from the former USSR,
the frequency in Hz was decreased , a massive imbalance was experienced, with power flowing from Russia to the Ukraine.
neptune
Please excuse this reply if it seems dumb . My understanding is very limited , but you seem to say that a transformer can change frequency at the input to a lower frequency at the output . I do not believe this is possible . The nearest possible to this is that at the output , you can experience a higher frequency in the form of harmonics . the 3rd 5th and7th harmonics being the most strong . The only way you could get a lower frequency would be with some form of frequency divider chip .
penno64
@all,
I think lasersaber's latest video deserves closer examination
I just get the feeling he is more than half way there
Don't dismiss this too easily.
Penno
wattsup
First off, the 500 hz I mentioned in my last post is also figurative. It does not matter what the frequency is. As long as the output frequency is above 50hz, it could be 500 hz, you will see a constant bulb illumination.
What I am very happy about is that between my description of the TK GB unit and his patent (that I have seen for the first time yesterday) that is now 3 years old, you can understand the progression.
The filtering modules (could be chokes of very high winds) can have their place in the patent because you do not know the frequency it is working at. At higher pulsing frequencies, chokes will have much less effect as you would think. They could be used as Tesla did as a source of high induction that helps charge his caps.
It is obvious that the patent does not provide enough for a replication. I would even say that the patent is purposely not correct in some aspects but who could challenge it? No one. So there is only left the same as what is left with TKs videos and all other talks, etc. They are all small parts that can help someone get either a better idea of the device or a new idea for a newer design. The later is more plausible in my book and working to replicate the TK device would not be a good choice of spending time and money. Work on your own design guys but just use whatever you "think" you can learn from all of this.
The sad parts of all this is seeing TK from his GB video to today, a good 15 years later and we can see that time has taken its toll. Well another great guy that is cloaked behind the veil of commercialism and so many years later with nothing to show for it. He could have easily spent those same years flying all over the world meeting with companies, universities and governments, teaching his system to the world. Really too bad.
wattsup
quarktoo
