0 Members and 97 Guests are viewing this topic.
Herger
Quote from: Choose username on January 27, 2011, 07:50:18 AM
Ok, but now i translate more info from teofiliuss:
Quote from: teofiliuss
    Spark is used for resonanse selftunning.
    Giya (Kapa's assistant) suggest that the best way for replicators - begin from high voltage as the input power (against 12V akkum. or battery) for start process. It must be 220V or even more.
Thank you teofiliuss!
P.S.
Tariel really sick, its true. He diabetes in severe form. Any diabetic can suddenly die every day from diabetic shock
Choose username
Grüß Gott! Meine Damen und Herren! I came back and i hold in my beak a new information! 8)
This is translate from very illiterate russian post from one georgian (Kukuri), which apparently live not so far away from Kapanadze. I think in same city.
Link here http://lix.in/-8f6889 (wait and page will be autoscrolled to this post)
Translate here (edited by me)
Hello, guys!
I will continue to answer your questions.
1. Yes, I attended!
2. Detail which is missing in the diagrams - very strange coil (I have considerable experience).
This is the same third coil about which everyone is asking. And here is its strangeness - it is wound on a low-voltage electrolytic capacitor, which in appearance probably 50V 20000microfarad. Such capacitors you can found in power supplies of a power amplifiers. It is also connected to the scheme, but i dont know where. This piece stands vertically. If you look inside the plexibox from top, so that Tesla`s transformer upstairs - first stands this capacitor-coil, and then another coil. also vertically. As Kapanadze said - secondary coil.
Because the capacitor was upside down with solder wires to it, i think it is a working element of the circuit. I saw the bottom of it - there is Mercedes
(-like?) symbol.
3. What else do I know? there is another spark inside a secondary coil!
And more: both coils wound in one layer, wire ~4 mm2. This capacitor-coil not quite round.
Likely a gap. BTW, Tariel repeated several times that which is very important to establish the second coil exactly at the its right place, and necessarily vertically!
capacitor`s diameter ~8-10cm, height ~18-22cm.
Among PCB i drew attention to armenian 400w converter with transformer and our genius hint about it - from this point reference frequency is created. 90% of such converters which proved to me to repairing, generated 49 Hz instead of 50 (curiously enough).
About greenbox. It did not started by TK for more than 5 min, because transistors heated strongly. They burned out a few times during the experiments. They expensive costed here in those days and it was a long time awaiting for new ordered.
TK said that at the low power nothing to do without grounding, and in those days he had no another variants. Later he was made another model, which according to him- grounded no longer used. Sadly but this device i not saw myself.
It is strange but I have not seen the high frequency generating components (transistors, chips, inductors)
(in plexi).
I remeber that plexibox started automatically. It was automatic charge control in starting module, (when the maximum values is achieved - generator began to work). But later it was broken, i think because strong electromagnetic field. The spark gap in plexibox much more than in greenbox and sparks with time intervals.
I was not present at the plexi presentation which was filmed, i was there before it, with friends.
Now i have no access to TK.
P.S. I have not heard that he worked on anti-gravity! he worked on gravity engine, and he did it! This motor rotates inside another plexibox and it works on the principle of kapagen, it was filmed too.
Tariel is a not a mathematician, physicist, electronist, and he has poor knowledge of the formulas
(he is architect). He could not use complicated theories and superconductors. It all was done in one room, and in those years we had elecricity at least 1 hour per day here. Decision should not be difficult. Let`s look.
I think that Kukuri was sure that he saw capacitor as coil's core because he saw notches on the metal of the capacitor's top like mercedes logo. Same notches have some capacitors.
Herger
Thank you.
It is interesting that the coil had to be vertical. I guess that capacitor inside coil is rolled type.  Pulse the coil a certain way and the capacitor is charged if the coil is vertical.  Gravity may be the required vertical force and easy to work around.  I guess that this unit does not require a ground connection.
The hot transistors, I have had this issue when driving a transformer from a microwave oven which required about 5 amperes at several kHz, and output was about 3kv.
Herger
If you use a steady magnetic field around the pulsed coil, then you do not need resonance, and you can use any frequency.  Adjust for best effects.
exnihiloest
Quote from: Herger on February 02, 2011, 09:42:01 PM
A steady magnetic field doesn't change anything. It simply adds to the varying field and have strictly no effect on the signal and energy involved in the varying field, the only one that we can recover.
