0 Members and 97 Guests are viewing this topic.
grizli
Quote from: quarktoo on February 01, 2011, 03:07:34 PM
Here is the principle of the Kapanadzi. That wire running through the core is the pink elephant in the room. The two frequencies pump that wire running through the middle.
One coil (small) may be air core with just a wood core. Everything else is just a matter of personal design.
Play with this principle and you will find what you are looking for. It is seen in all the devices I have looked at so far - no exceptions.
if coil is quarter wave length than this is identical to Tesla coil colorado spring notes experiment with bulbs in series between magnifier coil and ground
quarktoo
I am like LTBolo in that I am stuck on the theory too. His theory uses a compression which is the opposite of both voltage and subsequent electron flow. These are vacuum energies and any absorption or transfer of energy would only lead to entropy or losses.
We have all seen plenty of coils but what we have not seen is a coil with something running down the center. Therein lies the secret to this device.
I suspect there is a copper tune that has been sliced to form a 1 turn coil. Because the magnetic field in the center of the core is pulling from both directions equally there would normally probably not be a gain. However, there is this resonating choke at one end which is probably spilling some energy out one end.
Another aspect it that a massive twist of electrons is going to occur on that copper pipe.
If you are looking for a way to explain this using something you already know, you are most likely going to be disappointed. Standing wave hertzian compression, acceleration something along those lines.
Empirical experimentation is going to be the only way to get there.
Brother22
I made already many experiments in this topic and I found two main items to solve
The first is to get and keep the resonance between the primer and secondary coil? The solution, I believe lies in an IC with the number of CD4046.
The second problem is to pick up huge spikes - the energy from the coils. When you study the Tesla patent #568,180 you can see how he did it.
If somebody can translate the Russian description?
http://docs.google.com/viewer?a=v&q=cache:zeS4pky11dMJ:www.hvlabs.hu/zpe/Gruz/forum_matrix.ru/4/magic%2520kapanadze.doc+magic+kapanadze.doc&hl=de&gl=de&pid=bl&srcid=ADGEESgflyM2rgZ0-9GnnSvzZiC_9qtaLiBNou57-Bmtuszwt-22SEAM3_uvwRtR3I7aC6F_Q8TWNnEOdxkp3SfkqPUMfF4tTj2Zj-HO_B5b8psvXSd1lVlB-usU9ZmpCBencOM-Dplt&sig=AHIEtbQzASj9HONFBlsXM8_WNdqhPNCdYA
Br.
exnihiloest
Quote from: TheCell on February 03, 2011, 10:29:23 AM
Thats your opinion .
It is not my opinion. It is the state of actual human knowledge, the field theory, based on logic, consistency, observations and experiments.
In this matter, you can oppose neither obscure theories based on verbiage, nor old useless patents claiming extraordinary results that nobody is ever able to reproduce (if such a patent worked, we wouldn't not be here, still searching for FE).
To be credible in this matter, you can only show facts which would contradict the common knowledge.
So instead of listening to magic sentences as "If you use a steady magnetic field around the pulsed coil, then you do not need resonance, and you can use any frequency.  Adjust for best effects", you should do it yourself. I guess the author is not convinced himself, so he let waste the time of others rather than his.
