0 Members and 405 Guests are viewing this topic.
Herger
Quote from: quarktoo on February 08, 2011, 01:25:50 AM
Grumpy,
Trying to piss me off?
The fact of the matter is I could clear this whole Kapanadzi mystery up in a single post and you know that because I gave you a document to post a year ago that explained the principle. (Look towards the end) I have also posted how to info. all over this web site. The funny looking end of the coil "should be obvious".
My guess is you know the 1 year disclosure clock has run out and you are trying to get another disclosure to make sure I can't patent and go into production or share the payoff money. Don't worry, that isn't my game. This is pure amusement for me.
My next guess is that you are trying to get Kapanadzi's registered trade secret nullified somehow. Seems we have been using so much counter intel on each other over the years, I am starting to get confused as to what side, who is on. ;D I spotted you early and was also feeding you info. but only to lure you into my lair. You have been most helpful.
Bolo's compressor analogy was priceless. While I play dumb and make fun of it, don't think for a second I am half as dumb as I pretend. One end of the coil is probably going to emit some accelerated particles that need to be shielded with some borated polycarbonate or lead.
Watching you trying to disqualify SR193 is most telling. Maybe you are not smart enough to realize that SR193 didn't have the two bucks to buy what is over one the end of the TK core and instead placed it inside because that is what he had laying around. Or... Maybe you are as dumb as those that decided it was not Kapanadzi's replication because you didn't think it through...
All you have done is make suggestions as if they were fact and talk a bunch of noise.  If you really are all that and a bag of chips, then prove it.
You'll come back with the usual BS about people trying to get you to disclose something or some BS about oppression.  The only oppression and disinfo on this site is from forum trollers like you with your endless BS and derogatory comments.
Save it for the other clowns, CLOWN!
Magluvin
Quote from: Herger on February 08, 2011, 10:10:48 PM
I was just commenting on an interesting post.  Whether or not cold current exists and what it is, is anyone's guess.
Would this be an example of cold electricity?  1 wire from my lil TC and me as the bulb base connection   =]
Mags
darkspeed
Per the green box:
The visible  - adjustable - spark gap has nothing to do with the primary side circuit.
I believe it sets the discharge rate of the output capacitor, allowing him to adjust the conventional current and voltage supplied to a given load.
i.e. bigger gap = capacitor reaches a higher voltage = more current and a lower cycle rate
The primary side circuit frequency adjustment is most likely a variable vacuum capacitor ( as a component inside the green box )
Magluvin
Quote from: darkspeed on February 08, 2011, 10:28:12 PM
Per the green box:
Actually if at the same rate per say, a smaller cap will be at a higher voltage than a large.  Look at some plain examples of HV caps vs high value caps on ebay.
Most large value caps at high voltage can compare, in voltage height =], to smaller value caps.   And just because it is 500nf or even pf, that high voltage will bite you.
Tesla said something like,  There is tremendous power in 1 tiny capacitor/condenser,  something along those lines.  Dont be afraid to use small value.  I can make a car ignition coil blast very good output discharging a .1uf cap at 500v to the primary of 1ohm.   80uf can weld.  ;]  we just want hv discharge into a very low ohm primary.
Mags
Magluvin
Hmm  so maybe small cap HV on a rotary switch would not be so bad on the contacts.  Core, were you running the 80uf cap on the failed rotary switch?  Maybe that was the cause. Welding.  ;]
Mags
