0 Members and 117 Guests are viewing this topic.
core
Quote from: Magluvin on February 08, 2011, 09:25:37 PM
And if it is that you get more with shorter switch close/open  it could be that if the power is on longer the field could be weaker from heat in the coil.
I'm not so sure about that, this is DC and if the current is consistent magnetic field strength should not change. I can not see there being an issue with excess heat as the contact is made for a fraction of a second if not less.
  Otherwise, I would say that the longer you stay on the switch the more chance that the filed build will get all the way.
That was my reasoning also but that appears to be completely false.
Respectfully,
Core
core
Quote from: penno64 on February 08, 2011, 09:21:14 PM
@core
For a long time now, I cannot get this guys videos 1 & 2 out of my head.
Unfortunately, I do not have the type of capacitor he shows in the demo.
So I can not replicate.
I keep thinking that the earth is a massive capacitance.
What you allude to is what I think this guy has done.
Wouldn't it be funny if the holy grail turns out to be simply the capacitor.
http://www.youtube.com/user/NRGFromTheVacuum#p/u/10/2cUS03yNl40
Penno
Thanks for the link Penno. I don't think its funny at all in TK's patent he show's what he calls 'Points' feeding a HV module. Also HV does not have to be a value over 1000 volts. As an example 110 volts is considered high voltage.
Respectfully,
Core
core
Quote from: quarktoo on February 08, 2011, 09:35:56 PM
Maybe when you have one of those "ah ha moments", you should start your own thread called "Look everybody - I wrapped some speaker wire on a sewer pipe".
This thread is about Kapanadzi, not your first coil made using the wrong wire, a form that is too thick and some idea that has nothing to do with Kapanadzi.
That's actually funny and I laughed for awhile. Maybe speaker wire and sewer pipe is the 'Pink elephant in the room'.  :D  ;)
Respectfully,
Core
BTW - I forgot you where also TheBuzz my bad.
core
Quote from: Magluvin on February 08, 2011, 10:44:56 PM
Hmm  so maybe small cap HV on a rotary switch would not be so bad on the contacts. Core, were you running the 80uf cap on the failed rotary switch?  Maybe that was the cause. Welding.  ;]
Mags
Yes the rotary gap goes between points A & B on the print. My electrodes on the rotary fouled fairly quick. I'm going to try a better design. On one of TK's video's you can here a 'clanking' sound. I believe this is his mechanical break.
Respectfully,
Core
core
Quote from: quarktoo on February 08, 2011, 11:06:03 PM
Within the last 25 pages of this thread, Kapanadzi's big secret was disclosed. It was just a thought and obvious to anyone with two eyes. The metal rod through the center just holds the two sections all together.
See what happens when you piss me off? I share more thoughts. That would be counter productive in your line of work. The offer still stands. Tell your evil overlords for 100K, I will stop disclosing OU info. It went back up to original offer when I reversed engineered Kapanadzi. That one is so simple a child could build it. So similar to the AH coil it hurts to keep it inside.
Your joking right?
Respectfully,
Core
