0 Members and 116 Guests are viewing this topic.
darkspeed
Quote from: Magluvin on February 10, 2011, 11:40:57 PM
Hey Herg
I read it, and I need to read it a few more times to get a full understanding.
Is he saying that the Extra coil acts as an extension of the secondary to raise the voltage, without affecting the primaries load?
Gota read more around it.
Mags
Tesla..
The energy transfer from L1 to L2 is always more efficient at lower freq with tight coupling but it is not always possible due to L2 voltage rise and thus risk of arc over to ground.
The L1 and the L2 are in tight inductive coupling
They are located at the base ( grounded end ) of the system so they see more current than voltage.
The L3 is remote from the L1/L2 so it is able to raise the voltage to a great degree on the top ( capacitive end ) of the system without risk of arc over.
The TMT was designed to cycle way below 20khz ( 5-6khz ) so there was no energy wasted in RF transmission
The current pumped down in to the volume of incompressible fluid ( earths electron mass ) could then be drawn off at the same frequency at a  distant location
iceweller
Quote from: core on February 10, 2011, 07:52:57 PM
Some good reading.
'The principles of electric wave telegraphy and telephony' written by a brilliant man Sir John Ambrose Fleming.
Chapter 3 'Dampening and Resonance' and Chapters 4,5,6 'Stationary electric waves on wires and coils' is an excellent read.
Unfortunately the PDF is too large to upload to the site.  :( If you go to Google books and paste the name in the search box you can get a free copy.
Enjoy
Core
A book I would also suggest in understanding Tesla's "wireless" transmission concept and how this has been misinterpreted (and still is amongst many engineers), is "Guided Weapons & Computer Technology" by Leland I. Anderson:
http://www.tfcbooks.com/mall/more/337ntgw.htm
  In particular, the Fessenden - Tesla patent interference transcripts which I heartly suggest to read.
iceweller
Quote from: dllabarre on February 11, 2011, 12:36:44 AM
Does anyone have the URL to the hand drawn picture of a ferrite ring core where the rings on the right hand side of the core get progressively smaller?
Thank you for any help,
DonL
  Though I sincerely doubt the veradicity of the drawing, I have zipped the 2 relevant ones in one file FYI (one is the reconstruction of the hand drawing). I am still waiting for an answer to the real source of this paper but it appears to be fake.
scratchrobot
Could it be that the device is an electron muliplier? When a charged or neutral particle, an ion or an electron, strikes a surface it can cause electrons associated with the outer layers of atoms to be released. The HV is used to accelerate the electrons.
An 'electron multiplier' (continuous dynode electron multiplier) is a vacuum-tube structure that multiplies incident charges. In a process called secondary emission, a single electron can, when bombarded on metal (or PbO coated surface) induce emission of roughly 1 to 3 electrons. If an electric potential is applied between this metal plate and yet another, the emitted electrons will accelerate to the next metal plate and induce secondary emission  of still more electrons. This can be repeated a number of times, resulting in a large shower of electrons all collected by a metal anode, all having been triggered by just one. Therefore, another name for electron multipliers is 'avalanching ion detector'. 12 stages of acceleration will usually give a gain in current of 10 million.
gyulasun
Quote from: forest on February 10, 2011, 07:34:07 AM
But stop discussing - fortunately I found what I mean is stationary wave  and here is the video (not mine) :
http://www.youtube.com/watch?v=GMXlzCX5gio&feature=related
As you see wave is bouncing between barriers , like Tesla waves around globe.
If you wish I could shortly describe how I see resonant circuit could gain energy indirectly using this effect and external energy source untrappable by other ways.
Hi forest,
If you don't mind I would read your thoughts on the above in bold.
thanks,  Gyula
