0 Members and 117 Guests are viewing this topic.
Ghost_Rider
Quote from: quarktoo on February 15, 2011, 01:38:36 AM
For the same reason we know you are POYNT99. Your LATIN slogan which the spooks like to use translates into "Bullshit Baffles Brains" which is what Grumpy does.
Baffle this .99:
The most important part of this invention is the 1/4 wave conversion. For every action there is an equal and opposite reaction. The 90 degree phase change erases that Newtonian law.
The magnifying coils eliminate the back EMF and the large ground wire is a mass anchor to keep the phases from twisting each other and the ground so that the coil can pick up that radiant electricity it is transmitting. My guess is that coming right off that 1/4 converter you need that large wire to keep the phases 90 degrees apart and in fact that is seen in the videos.
The spark gap I feel is needed for more than safety since tying these two coils together with wire is going to destroy that phase shift The device is a transmitter that is fed from what it receives. Where does the energy come from? Lt BOLO may have the best explanation there.
I've learned a few other things lately but those are the most important parts.
Now why don't you go back to OUR .99 and get lost like people keep telling you. We are tired of the counter - intel tactic called "poisoning the well" or as you put it with your tag line, "baffling our brains with bullshit".
Just like Grumpy said, you throw a little meat in there and they spill the beans. Well since I knew what you spooks were up to and how you operate, I have been able to separate some of the meat from the BS and learn instead.
The first step into finding your way out of the spooks matrix, is figuring out that you are even in it. Wattsup figured it out - Kudos!
I've been told many times I am the most determined person someone has ever met. I am unbreakable and I know that about myself. Been tested many times.
A long time ago some spooks and military assholes had a go at me. It took me 8 months, but in the end, I broke them. Grumpy lasted a few months and 99, you lasted even less. Go away or I am going to ride you like a rented mule all the way into the light of day.
You wrecked this forum by taking "people of interest" to OUR where you could intensively spy on them without having to read through all the BS here and where you could keep them from spreading information.
You are a creepy person.
Get real!  I don't sound anything like Grumpy or Poynt99, and Latin is not their thing.
What is a 1/4 wave conversion?  Sounds like a fantasy pipe dream excursion, or logical fallacy.  Is your physics really that bad?  You can at least spell p-h-y-s-i-c-s can't you?
You are truly as unbreakable as a large block of metal, and almost as smart...
The spark gap is to sharpen the pulse and if you had located the translation of the green box video, you would know that the device will not work if he gap stops.  If you had ever actually built and utilized a spark gap, which I am sure exceeds your level of skills by at least 50 IQ points, then you would already know this.  If you already know this then you are just regurgitating the disinformation that your handlers fed you!
The Kapanadze converts or creates depending on the perspective.  So you are wrong, yet again that is no surprise.
quarktoo
Vladimir Utkin's work is a goldmine. I encourage everyone to give that a good read. His word document discloses what he spooks are trying to suppress in the Kapanadze device. Now I understand why SR193 used the multi-pair telephone wire through the center of the coil, why it is split in two and why the big ground wire is used.
Here is that link to the goldmine again in case anyone missed it
http://ut27972.narod.ru/index.html
Herger
Quote from: Magluvin on February 15, 2011, 12:55:59 PM
Hey Herg  =]
Question.   If the energy radiates outward from the coil to a pickup coil, does the pickup coil have a polarity, and maybe why?  Just want to know what to maybe expect.  Is there a distance from other electronics that I should keep a project away from?  Just anticipating things.
And if it causes trouble, me asking you these things, if you would, we could correspond at Magluvins Oven Baked To A Solid State thread.   Q2 seems to have an itch for just about everyone here.  Not very comfortable.
Thanks for the guidance
Mags
The Hell with Quarklooser.   He thinks every form of disinfo is a gold mine of misinfo.
Polarity depends on the difference of potential at different locations.  Just measure it with a high impedance meter.
Herger
Has everyone noticed that the controls for Kapanadze devices are always hidden?
Spark gap are visible, as are the coils, but not the controls.
Fortunately we can figure the controls out despite the disinformation campaign of losername quarktoo the US Goverment Lack of Intelligence Shill.
