0 Members and 155 Guests are viewing this topic.
Magluvin
Hey core
You may be right.  Don Smiths setup was neat and easy to follow. Im just making a connection with what Don was saying about adjusting the output with a resistor.
My lil neon transformer can light the 4w 110v bulb directly. The transformers output is about 1kv, but when the bulb is connected, that voltage probably falls to somewhere in the 120v region, as per the bulb was at full normal brightness as compared to normal input to the bulb.  But in Dons setup, 8kv out, my lil bulb isnt enough to load that down like lil neon, and I suspect my bulb would have its last flash.  But add a resistor of proper value in series with my bulb, and she will light properly. I never really understood what he was saying till now.
But we also have to remember that Kaps device is regenerative. That will be an important part of what he is doing to understand as of how.  ;]
Mags
core
Quote from: Magluvin on February 18, 2011, 11:42:46 PM
........But we also have to remember that Kaps device is regenerative. That will be an important part of what he is doing to understand as of how.  ;]
Mags
As far as 'regenerative' thats the question I have. In this case you have two bobbin A & B. Bobbin A induces a current in B. This current is delayed somewhat by shielding so that when the current in B is rising to max A is at minimum. At this point you now have B inducing current in A in the same direction current is moving (assuming a load on bobbin B). So A induces into B when A is max and B is minimum. B induces into A when B is max and A in minimum. Clear as mud right.  ???
Respectfully,
Core
Magluvin
Lol  clear as mud.  =]    Well I will suspect that if we peal off a bit of hv output, that we can use that to run our primary spark. If there is a resonance that would at least give up some to initialize a primary charge for discharge, it may be easy.  I just havnt seen any circuits that show the regen part yet.  And lets say that maybe one of the coils is just for that purpose, to regen the input.
Mags
core
Pretty amazing there's been about 50 hits on the pictures I posted in just under 60 minutes or so.
Core
Magluvin
Yeah   That and the no. of reads at the top of the thread are a good indicator of attention stats.
Welp  I gota get some zees.  Good conversing Core
Will see ya around.
Mags
