0 Members and 108 Guests are viewing this topic.
baroutologos
@ Above,
It is very easy to get lost in traditional measurement techniques and point out OU in kacher systems as the above.
But the one who is really experienced with Kacher setups, will readily understand that the above measurment technique is NOT accurate.
I explain. all is based on the assumption that the voltage in the output cap after the bridge (DC) is equal to the AC-peak volatge generated by the kacher's pick up coil or DC * 1.41 = AC. Ok? not really...
This methodology does not takes into account the capacitative aspect of the system. As anyone will find out an AV plug or a FWBR will charge the cap to a value even though a pick-up coil is not employed, but just a metal thing or even a piece of wire next to many turns coil...
So in few words, i am saying the cap's deposited value IS NOT to be trusted for measurements in order to determine the power dessipated to the R load.
Just do it, and instead of a 10Ohm resistor put a bulb. you will find out no OU there. Not this way anyway.
teslaalset
Quote from: gyulasun on February 23, 2011, 05:54:23 AM
I wonder if the words "ferrite corn" may mean ferrite core in the Tesla coil??
Normally a Tesla coil has air core, no ferromagnetic core.
Anyone can comment? Is it mentioned in the Russian text?
Thanks,  Gyula
Translation by Google on the core:
About the core.
Assistant Tariel nick tarielkapanadze, one of the forums on the question: "Is there a ferrite-to-install" replied ambiguously:
"Ferrites in the Tesla transformer is not used, and this one does not argue! really stupid to use ferrites in the Tesla transformer. But any sane person who knows or electrical work in the electric department, says that it is impossible to transform this power without the magnetic circuit at this frequency (50 Hz), yes, I'm not arguing that we can do without a magnetic core, but then the installation should work at high frequency and judging by the implementation of the coils are physically unable to convert this amount of energy at high frequency, since it is fraught with enormous challenges and the material (PVC tape) just break out, and the same applies to the power cable. It is therefore reasonable to assume that the magnetic circuit is simply obliged to be present in a removable coil.
gyulasun
Hi teslaalset,
Thanks for this translation, I also did this though there may be no ferrite, ok, still all I can say you can believe nobody but only yourself if you are able to do the correct measurements...
rgds,  Gyula
Quote from: teslaalset on February 23, 2011, 06:44:37 AM
About the core.
sano
For Stefan Hartman, moderator
резонансный усилиÑ,ель_Аркадий СÑ,епанов.flv
We need someone to translate this into English language please.
Many thanks.
Regards, Stefan.
Hi Stefan
Please send me a link to the original Russian.
I need a better video. I'll try to provide a translation.
sano
