0 Members and 138 Guests are viewing this topic.
quarktoo
Quote from: khabe on February 27, 2011, 05:22:10 PM
Looks like distiller for homebrew  ::)
cheers,
khabe
Don't get too cocky girls. There is a few frames of a video I have not posted that blows this wide open. No way in hell would you use uninsulated copper tubing with no spacing on an inductor but Kapanadzi is using it and lots of it. So did Hubbard and it is the mother of all free energy devices.
There is also a video that I have pointed out before of the Russian wood working factory running on a free energy device where they are using uninsulated copper tubing for coils. I tried to get people to notice but it went right past them.
In every instance, they try to hide the fact that they are using tightly wound uninsulated copper tubing by covering it with tape. The cost of copper tubing far exceeds that of wire and there is no way to use it without insulation unless they are pulsing a gas in that tubing to produce a quick high current pulse and that is exactly how they are pulsing this magnetic compression coil and what it requires. That would explain why a wire goes INSIDE the tubing on one end and attaches to the OUTSIDE on the other end.
If you think a flyback is going to magically transform into 5000 watts of power with a earth ground and a coil, you need to study more physics and stop watching the magical Jim and Tammy Fey show.
I could spend the next half hour posting photos of devices that use copper tubing in coils and it is not because they are Tesla type primaries. The reason people most likely could not get the results Tesla did back in the day is, Tesla never disclosed what was in the tube. Note how in all the devices the tube need not be insulated?
FACT: Under the tape of those three Kapanadze inductors are two layers of uninsulated copper tubing. Brew that.
Apparently the box of tampons didn't arrive yet.  ??? Go ahead and ban me Wattsup. I am sick of your stupid threats and constant crying. It will make me right if overunity banned the only guy that disclosed how this and many other free energy devices work for the 9th time. I have years worth of posts pasted into Word files saved of your tactics. It will continue to provide evidence for a book about alternative energy suppression.
quarktoo
Quote from: wattsup on February 27, 2011, 06:21:18 PM
@forest
In your post here;
http://www.overunity.com/index.php?topic=7679.msg276207#msg276207
Is it possible that the brightness is due to an internal spark gap housed inside the coil. He then plugged the end to not show it but had to make a small hole for aeration. I will have to take a closer look at that.
Unlike what @QT says about it being a "magnetic short". What is a magnetic short. Nothing as usual.
wattsup
Wrap a thick band of copper around any part of an inductor and you have a magnetic block or what I call a magnetic short. That magnetic short forces all the magnetic energy to go in the other direction just like the EMP gun that Kapanadze pointed to when he disclosed how it works.
Electro-magnetics 101
Logic 101
Reason 101
- Verses -
Your attempt to suppress this at an elementary level. Anyone with two eyes can see that is a copper end cap. You people doing suppression are so obvious. This web site has a reputation for being nothing more than that and that is why so many other web sites have sprung up. It is only going to get worse if you continue to do your thing.
quarktoo
Note the man standing there with the coil in his hand. Notice how the end of the tubing is crimped closed? That is so the gas does not escape.
Normally I would not have disclosed this as I have known of gas coils for years. That was my way of getting some payback. You push, I push back. People read this stuff and start noticing things and thinking.
Mark Monitor should fire all of you.
ramset
Q2
I don't think you pushed back hard enough!
Whats the gas?
Chet
PS
Who's mark moniter?
Thanks Grandma
quarktoo
Quote from: ramset on February 27, 2011, 07:08:08 PM
Q2
Whats the gas?
Chet
PS
Who's mark moniter?
I call it "Ramset Gas" because it is so magnetic.  ;D
Mark Monitor? Google the sum of all knowledge. From there, use a little imagination. If you run short of imagination, borrow some from Jim and Tammy Fey. They have much to spare.
