0 Members and 349 Guests are viewing this topic.
quarktoo
http://www.youtube.com/user/Xdole#p/u/1/YzepOmT5N_8
Dole is the sharpest pencil in the box. Notice how he crimped the ends of that coil closed? Maybe he figured out the composition of Ramset gas, maybe not.
I was able to cobble together my own version of DOLE's cold electricity demonstration. That is by far the most exciting thing I have learned in the last 5 years. If I had his address, I would send him flowers. That process needs to be explored in full.
If this web site had any sense, it would offer DOLE money to start threads on his projects. DOLE worries that people will get electrocuted since he uses a 10K neon transformer and a MOT in some of his experiments. He is not only smart, he is a decent person. A class act all the way.
Well Ramset, sorry I have to ban myself for a week or two but I need to rebuild my gas lab left over from my Stan Meyer stuff and do some experiments. Here is a good place to start. http://www.magnegas.com/
Meyer's first patent is also a good reference.
ramset
Well
It's just my opinion,Perhaps I am ignorant ?
But I don't think this guy should get banned so fast!
Perhaps someone can mop up the messy parts?
To much at stake here!
Chet
Thanks Grandma
penno64
Hi All,
I asked the question once before regarding Dole's apparent collector coil
being at 90 degress to the "COIL".
What about his latest video LEMW - any clues as to what he is up to ?
Great work none the less.
I am surprised he has not fronted and explained what he has done !
Penno
wattsup
Well, well, well.
Since all this hot gas is floating around between someones ears, let's take a closer look at where you say there is a plug or crimp of some sort of miracle to the outer 6 turn coils that is supposed to hold gas.
Hmmmmm. See the image below is taken using VirtualDubMod that let's me get in as close as I want to any part of a video frame. Very convenient when you need to look at things that others may be hallucinating on.
When you look at this image you will quickly realize there is no crimped end, no plug, no nothing. Just the end of a thick stock coil wound 6 turns, blah, blah, blah.
When you look at it this close and move the video it gives you a great view of it in motion and there is NOTHING ON THAT COIL END. So I guess your whole theory of gas is now confined to what you produce after a bean fest, which you must be partaking in at least three times a day.
So go back to your stinky drawing board and try to fix your disinformation to something that is at least half palatable before you feed us more irrelevant junk and accuse others of being a troll.
wattsup
Compliments of "Your friendly neighborhood troll slayer".
ramset
Wattsup
I see your pic ,I see your arrow
,And two inches to the right I see the blue tape covering the uninsulated tubing that was mentioned?
At least that is what I got from Q2's post!
I'm working now ,I don't have time to reread,the posts
I was just surprized to see your arrow pointing "There."
Chet
Ps
Here is one quote I just found
Q2
In every instance, they try to hide the fact that they are using tightly wound uninsulated copper tubing by covering it with tape. The cost of copper tubing far exceeds that of wire and there is no way to use it without insulation unless they are pulsing a gas in that tubing to produce a quick high current pulse and that is exactly how they are pulsing this magnetic compression coil and what it requires. That would explain why a wire goes INSIDE the tubing on one end and attaches to the OUTSIDE on the other end.
Thanks Grandma
