0 Members and 266 Guests are viewing this topic.
Pirate88179
Quote from: giantkiller on February 28, 2011, 05:56:38 PM
@Pirate,
I notice in certain older countries the builds are very rudimentary. Even if you look at the walls of the buildings surrounding the demo. Stone upon stone. Which brings me to the copper coil. I say they bent the tar out of it to get it to length.  Look Ma! No tools! :D
Exactly right.  I do not mean this in any way to detract from TK's work at all, actually it makes it even more amazing working with what he had available, which is why I think he would have had serious problems pressurizing a copper tube and sealing it while brazing or soldering.  This is not a fact, I am just going with the most probable to me.
Magluvin
As for gas in a copper tube, does it make sense?  Would the copper not play a part in the circuit?  Would the gas even conduct anything from one end to the other of the copper pipe, through the gas alone and the copper containing it is just a mute, non conductive vessel?
Why not just pvc to contain the gas? Or glass, like neon tube glass?
I dont think there is a gas in a pipe or tube that helps us here.  And what else would be inside with the gas?  All speculation, even the gas.  If any of the pipe coils on projects like these, would in some cases have a squeezed down or crimped end, so that it could be drilled and a terminal could be attached, if they were conscious of good connections.
Mags
ramset
Well
Grumpy would know more about this!I have to admit I am clueless On the effects of Gas in a circuit .
TV Tubes?Mags I heard you mention Zinc?[Out side of TV tubes]
I know Q2 Mention Magnagas? Meyer patent!
IMO Nonferrous copper filled with a ferrous gas?
I don't know enough to say "No Way!!" that can do anything?.................
To me the biggest thing he said that would bring a WTF?
Would be his comment that Tesla Used Gas filled
Coils??
Is this correct or BS?
Chet
PS
Here this quote:
Q2
I could spend the next half hour posting photos of devices that use copper tubing in coils and it is not because they are Tesla type primaries. The reason people most likely could not get the results Tesla did back in the day is, Tesla never disclosed what was in the tube. Note how in all the devices the tube need not be insulated?
Well ?some of you Guys Know so much about Tesla
You can name his unborn children?
Is this BS or what??
Listen
I know you Guys want his Blood [what a surprise]
The only other Guy I know who says Gas Is the way to go Is Marco aka XSNRG He was trying to share something the Correa Bros had done ,But nobody would listen [Poynt Knows about this}
What if Gas is a part of this?
You gonna bite off your noses to spite your face??
Thanks Grandma
Magluvin
Rams  all I am saying is, where is there any clue other than speculation that there is gas in a copper pipe/tube?   Plus it was pointed out earlier that if a pipe, even with open ends would act as a winding in the transformer, and a Shorted winding at that, of which would absorb just about all power in the transformer.  Like any transformer  120v to 12v.  Short the 12v side and plug the 120 side in. You will noticeably hear a bigger Crack when plugging in the 120 end when 12v side is opened. Now replace the 12v secondary from the transformer and replace it with a piece of copper pipe. Now plug in your 120 end.  It could pop a breaker if the transformer is large enough, and the Crack Will be heard. ;]
So it just seems illogical to go that route when I havnt seen That much of builds without the gas method.  There are a lot of weird setups out there with no gas, all coils, caps, etc and they are doing amazing things.
Where other than Q2 have we a reference to  Kapgas?   Big distraction.
And this is my opinion, based on knowing things. The gas idea would be last on my list before exhausting "its just a funky transformer" ways.
I like Q2's Getup n go go gotchi doos.  But he gets just not right with people a Lot.  He has been cooler lately and I can give him that. Its great to have imagination into these ideas, and alot of it is good. Some is just common sense thats out in left field. I say finish it and try it, while ya got them ends on the pipe coil. Seal it up locked and loaded.  But results good or bad, it would be good to show.
I have had the hankerin to wind a coil around my xenon flash tube, being it a straight tube with just a trigger ring on one end, to see what I will see. The puls through the flash is almost 300v when triggered. There may be something there. But it is a glass tube the xenon is encased in, not copper.  Who knows  maybe Q2 will see that the pipe allows photons to escape differently than the glass. But I dont think so. ;]
Im not here to fight or prove anything or anyone wrong. Im just sayin it as I seez it.  ;]   So far.
Mags
Free.Energy
Quote from: ramset on February 28, 2011, 08:52:49 PM
I never expected to see Magnegas mentioned in this thread.  Magnegas is a magnetic gas.  You pump it through a tube with a coil around it and induce a current in the coil.  I have a friend that makes it from his sewage using carbon rods and arcing high current between them.
Bringing up Magnegas here is total BS.  Crimping a tube a bending it a couple of times is just an easy way to break it.
