0 Members and 219 Guests are viewing this topic.
sparks
  An electron say in a hydrogen atom 1s orbital has a mass/velocity equal to 1 milliamp of current.  This one electron can produce one milliamp of current when moving linearly instead of accelerating about a neuclear core.  In one mole of gas there are 6 times 10 to the 23 atoms.  60,000,000,000,000,000,000 potential amperes.  If we add photons and accelerate the electrons so that a percentage of them absorb energy in excess of the binding energy the electrons liberated now slow from 30,000 miles per second to 1 millimeter per second.  In order for any mass to slow it must shed it's inertia by emitting energy.  Heat Light Sound Radiowaves.  Somtimes the energy emitted is a frequency that is absorbed by surrounding gas atoms which results in further electron slowing and you have an electron cascade event and energy from seeming nowhere far in excess of the trigger frequency.  It is not free energy it is potential energy stored in the electron mass velocitygoing radiant.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Magluvin
Hey Sparks    ;D
I have no doubt that a gas can carry current. And that slowing down is interesting.
But do you think it would be advantageous to have the gas inside of a copper pipe shaped as a coil?
If it helps I and most here would like to know, it wouldnt be an easy chore for many to accomplish. So knowing if it has potential would be good info to know before delving into a very different avenue blind. There would still be an issue of if there are separate electrodes inside the ends, maybe just 1 end?, or if its just part of a special super conducting portion of the copper coil/gas capsule. The video shots have a lot of circumstantial views of things to be not sure of a lot.
Good to see ya around Sparks  ;]
Mags
havuhung
Hi ALL
QuoteBut do you think it would be advantageous to have the gas inside of a copper pipe shaped as a coil?
Try thinking for a reversal: In the copper pipe that was drawn out the air (vacuum) electronegative particles of copper (Cu) are elements inside the pipe, it will be This event will be free to split like? . .
Respectfully
Havuhung
penno64
Hi All,
If I could get you to clear your minds for just a few minutes and read this post from yss???
in the SHORTING COIL thread -
Woopy, you have good nose
With reasonable confidence I can say that to access this "effect" one needs very sharp gradients and/or exiting coil at its resonance frequency,
Easiest way to hit resonant frequency is to use spark gap, reed in this application works as spark gap. Thats why people have seen good results with reed and virtually nothing with transistors etc. Ordinary solid state components when driven in ordinary way are slow and transparent for HF and just do not work in this application.
For those who are trying to make solid state version, good choice would be russian "kacher" type circuit. There solid state components are "shockwave" driven and give desired effects. (NB! Kacher can and will affect your health, strong RF emission! NB!)
I dont see how one can easily combine very sharp gradients at exactly right frequency with rotary version and transistors etc. So I would bet on heavy duty reed or some other component exibiting wide spectrum sharp gradient "white noise" emission (and physical breaking of circuit).
Also series AC cap is a must. When there is AC cap in series, Ohm and Kirchhoff do not apply. And thats already half-done deal.
Also forget about directly measuring amps out of this contraption! This power is only good for driving not resistive loads (or charging acid batteries)! To use it for resistive load you must first transform it.
And as always, trust no one, follow your instincts, progress only after replicating basic effects
Is this the effect we are searching for ?
Is Kappas coil just a big version of shorting a coil using higher voltages and a spark
gap for a more abrupt switch giving the effect ?
Somehow I feel all these devices are so closely related.
Kindest Regards, Penno
TheCell
How to build a kacher: Link needed (English please)
IMHO at the cold end of the high voltage coil; at this cold end connected to base of the transistor there you can pick up cold electricity.
lix.in/-8f1771
forum wanderers
free energy
goto 'Discussion of air generator 2'
IMHO there is ONE way discussed how to get this energy.
Way to high skilled, and there are many high skilled there.
User grizly mentioned already here in this thread: put a metal plate nearby the kacher in series with a light blub which is grounded.
Capturing this energy needs a capacitor like device, once done this can be used to light a bulb i.e.. The information all about kacher should be available here.
Another one:
goto http://fuellesspower.com/
look at the free energy demo kit.
The same experience had a user in this russian forum.
goto 'Discussion of air generator' (the starting thread)
there to page 153
There is mentioned the cap that loads up with no further energy put into.
Quote Start
From experience, I noticed that Conder with facings of aluminum tape and a dielectric of paper strongly exhibit this effect.
A structure of metal-organic-metal way, is the orgone energy accumulator, and perhaps here and orgone some sideways.
Quote End
A coil , a diode and a cap , all connected in a loop, a impulse on the coil and the effect should be observed.
