0 Members and 1888 Guests are viewing this topic.
Pirate88179
No disinfo here.  That appears to be a heating element.  Have you never seen one Quark?  I guess not.
Then please explain to me how you would fill a tube with silicone and keep the wire from touching any of the ID while you did this?  You can't?  I am not surprised.
Quit this disinfo crap as it is wearing very thin on me and all of the others.  If you can't explain what is going on...fine...but don't try to hide your ignorance by claiming disinfo on others.  I never said this was what it was but raised the possibility....ok?  I have seen many, many heating elements that look just like this.  Have you?  If not, why not?  Can you fill a tube like that and keep it from shorting on the ID?
OK then.
iceweller
@Pirate:  Yes it may very well be a heating element.
@Quark: I know very well what NST wire is and how it looks like - I think you misunderstood. I was referring to the "copper" coil not to the wire. Look at the lower left of the enhanced picture. The blue NST wire comes out of the GB top right does 1/2 turn under the "copper" coil, is connected to a hidden component wrapped with what looks like some alu foil and then connects to the copper tube/heating element where the white insulator/dielectric is visible.
   The other end of this large coil can be seen in the dismounted coil pictures I posted (and wattsup) and here you can see the coil being split in 2, the lower part was mistakingly exchanged for a shadow which it is not, just the other part of the split open coil. In here I believe is routed the other side of the green NST wire and possibly another "hidden" component (covered in alu foil) before connecting to the coil.
   An additional note as it seems nobody commented on the last picture I posted. The long white wire comes out one end of the coil; I believe this wire is routed inside the core of the coil, hence it's length as it is nowhere else to be seen when the coil is mounted - so it is connected somewhere inside, maybe to ground. The other side of the wire certainly goes inside the GB and is cut near the coil, as is the RED wire (it is not connected to the copper coil, it just is routed through it as the white one and is cut, observe the pictures). This Red wire appears to be the same red wire that is the output, after going through the coil in that point. What happens there, is a mystery.
quarktoo
Quote from: iceweller on March 05, 2011, 07:02:27 AM
It would have been so easy to figure out if Kapanadze had just run those wires off the spark gap in parallel to the primary huh? All he had to do to fool you was run it back through the green box. It didn't fool Dole.  ;D That guy is super dooper smart.
Speaking of green, Stan Meyer used oxygen in his magnegas generator. Funny how Kapanadze used the same exact color you paint an oxygen tank to paint his "green box" huh?
It is a mag gas generator set up as a magnetic compression coil used to produce EMP. I have a EMP test photo from a science paper where the oxygen tank is sitting next to the coil at Los Alamos. Instead of producing a destructive EMP, Kapanadze produces electricity.
You can't see the forest for the trees?
core
Dole is not using gas, he already stated what he was using but his post got covered up by someone ranting about a flux capacitor. If you recall he pointed to a Tesla patent, MIT video, and a TK device. After that he stated 'Easy as 1,2,3'.
When it comes to making a fool of oneself. There is one member here that consistently rises above the rest. Back to the corner you go with the Dunce cap.
Core
WilbyInebriated
Quote from: quarktoo on March 05, 2011, 07:33:36 AM
I and others have explained how the coil works and why.
no you have not. you have bloviated your opinion on how you think the device works and what its components are... furthermore, until you can demonstrate a working device (in the manner of kapanadze) your opinion means no more or less than the other opinions presented. ::)
