joaouchoa and 286 Guests are viewing this topic.
grizli
Quote from: dole on March 09, 2011, 06:34:54 PM
Ordinary SG and the rotary SG, but you see, in this video, there is totally different type of energy, pure, like surrounding. I used it just for the POC. There is many type of energy we even do not dream about.
Back to TK device. I have a small MOSFET version of the pump from the 18V to 500V (I may produce same shooting effect like Ismael with discharge of 500V and 270uF charge from 18V, spends 0,1 A in 30 sec to go there). TK is initially pulsing from the 220V, or more. What is steel missing for the TK device is proper induction coupling primary/secondary in resonance. For now I am only studding the primary pulse for testing a correct impedance, you should not use R. Sometimes I plan a SIDAC / IGBT version. (But this is not actually what I am searching for, somehow dirty, conventional) anyway I would advice everyone to look at the TK patent again now. It does not need to be TT like you may think. Ferrite or steel core is needed because of SG pulse strength and arcing (pulse transformer) it is only in the input coil. Coax is needed to protect loss, capacity and all mentioned before. Now you easy see condenser charge through diodes; discharge section and coil polarity. The whole energy generator is inside the GB outside is only filter and ground connection for coax. Think of pulse to swing, when it swings back you will have sum of surrounding potential and pulsed magnetic field.
Can , or does the mosfet version have the same effect as Spark gap version ?
But ,  what you think about this :  Is not OU and TC related to usage of reactive energy ? For example very high Q low loss TC oscilator (or magnifier)  has HUGE reactive energy inside. It behaves like VERY big pendulum.  Maybe all we need is recactivly charge capacitor which will not lower TC Q factor. All in all we cant use resistor as load in TC system. We charge capacitor , and than discharge it in our load.
For example 1MV TC  has top capacity of 20pF and 500kHz.... 5MW is needed to charge this capacitor 500 000 times per second to 1 MV.
Current needed is 10A
For example we put bridge rectifier and 10V 100F(just figure of speech) capacitor between TC bottom end and ground. For given TC parametes above energy collected at such capacitor is proportional to  5*U  (5 is constant for that tc calculated by common relations).
100V drop at bottom capacitor = 500W of energy collected at bottom capacitor.
BUT bigger the voltage drop at the bottom of TC = lower Q factor.
that is not that much energy, but what happened with Q factor is questionable?
But we may have   low turn coil in parallel with capacitor  coupled to TC oscillator. Low turn coil LC resonance freq is the same as  TC main core. if both are in resonance energy generated on capacitor could be use as excess power. but capacitor must be disconnected from the coil when discharged in resistive load.
dole
Quote from: iceweller on March 10, 2011, 06:33:18 AM
    The + and - should simply
Very good, look at the arrows, if this is correct TK device must be sucking electrons from the ground, so than it make sense what he is saying “SG destroying the earth” or as may be  understood, producing AC. Now I know how perfect damped wave look like, >>straight line!!<< Positive!! Potential difference  :o
More brains please…
d.
Cowboy
Is anybody still working on this? I am looking for a good schematic of someone that has replicated something close to what is being discussed.
Pirate88179
Quote from: Cowboy on March 12, 2011, 05:41:39 AM
Good question.  Close is a relative term.  As far as I am aware, only TK himself knows what he has been doing.  Tons of speculation here and many theories but, thus far, I am not aware of any even close replications.  Others here can correct me if I am wrong but, this is where I believe we are at this point.
