0 Members and 49 Guests are viewing this topic.
dllabarre
Quote from: iceweller on March 14, 2011, 05:31:04 PM
Check the pics I uploaded in prior posts not long ago a few pages back, it's all there. Both white wires, and red wire.
Keep in mind that the patent focuses on the method of the energy extraction system, it does not include all the additional devices in the GB and other demo videos!
I have these, Thank you.
But what wires are connected to the green box and where?
OR are you saying no wires from the coil actually (electrically) connect to the green box?
DonL
iceweller
Quote from: dllabarre on March 14, 2011, 05:50:09 PM
DonL
   Did you look at the patent description? The white and red wires are cut nearly flush off the external coil, they go into and come from the Green Box. The long white wire is routed inside the core.
dllabarre
Quote from: iceweller on March 14, 2011, 07:27:54 PM
Don't be giving me an attitude.  I've read the patent and the additional 2nd patent, many times.
You made a statement of fact about the red and white wires going into the green box.
I've never seen a picture of the green box, from any angle, that actually shows those wires going into the green box.  Please post one if you have it.  If not then it can not be a "fact". It's a real good guess based on the patent description. But not fact.
Thank you for your time.
I won't be bothering you with anymore questions here.
DonL
grizli
can you please try to draw coil circuit with all this changes you found out *?
Cowboy
Quote from: Cloxxki on June 29, 2009, 09:05:17 AM
Greedy b****d.
After his Noble Price acceptance speech, he'll have little trouble getting generous expense compensation speaking around the globe taking credit for his/Tesla's invention.
So, before they let him go, let's hope someone on here get's sparked by what is seen in the video's to beat the grey guy to it. Too bad for Georgian patent applicants. Maybe he just failed to file the invention completely, leaving the investigator with doubts.
If you read through the patent documents, that is exactly what they state. They say a competent engineer could not replicate based on what little is claimed  and they also state that as such, Kapanadze is claiming perpetual motion which they will not allow same as the US.
There appears to be 3 or 4 wires going to the green box and 6 wires total. You can see them all in the video. Patents are worthless to understand something that they are intentionally trying to hide.
1 The ground wire that is run through the center of the core and then goes to the load.
2. The white wire on coil which has a 2 foot section of red wire spliced to it, then a white wire is spliced which then goes to the load.
3 The spark gap wire (probably) to one end of copper tube.
4. The wire on the side of the green box which probably goes to the other end of the copper tube.
5. The single white wire from the inverter to the green box in spite of the fact that there are two wires to the plug. So probably two wires from inverter. Only needed to charge the capacitor in the green box to start the device.
THE TWO WHITE WIRES FROM THE INVERTER - ONE OF THEM SEEMS TO GO TO THE GROUND BUT HAS BEEN DISCONNECTED IN THIS VIDEO AND THE OTHER ONE GOES TO THE GREEN BOX.
