0 Members and 223 Guests are viewing this topic.
forest
Is this picture from later hydro device ? I think we should make a clean divide between that device and "green box" device. I'm sure there is no gas in green box device, it is too crude.
forest
TEKTRON
Quote from: Cowboy on March 15, 2011, 02:44:19 AM
I found what quarktoo was talking about when he got banned and the information was deleted. Here is the photo of the oxygen tank and nitrogen tank in the back of one of kapanadze's machines. Green is oxygen and black tanks are nitrogen tanks. Oxygen and nitrogen are the two most magnetic gases.
quote]
@cowboy: No disrespect but where did you get the info that nitrogen is magnetic? I use to build and calibrate oxygen analyzers for Beckman Instruments Inc. 30 some years ago. I used nitrogen as a purge, zero gas and oxygen concentrations as a span gas. As far as I know (and please correct me if I'm wrong) nitrogen has no magnetic properties. Oxygen is however somewhat paramagnetic. This property was used to deflect a beam of light hitting a small mirror mounted on a small glass dumbbell, suspended on a quartz fiber. The greater the concentration of O2 the greater the rotation of the dumbbell and beam deflection. This was done in a permanent magnetic field of some 20,000 Gauss at atmospheric pressure.  I did notice however, that when I did provide slight back pressure to the cell with my thumb the deflection was way off the scale. So O2 is way more magnetic under pressure.
What experiment did Q2 give you to preform? What was the outcome? Did you make a vid? I would love to see it.
Thanks Cowboy I am anxiously awaiting a reply :)   ,John
iceweller
Quote from: dllabarre on March 14, 2011, 08:28:13 PM
Don't be giving me an attitude.  I've read the patent and the additional 2nd patent, many times.
You made a statement of fact about the red and white wires going into the green box.
I've never seen a picture of the green box, from any angle, that actually shows those wires going into the green box.  Please post one if you have it.  If not then it can not be a "fact". It's a real good guess based on the patent description. But not fact.
Thank you for your time.
I won't be bothering you with anymore questions here.
DonL
  Don, I am not giving you any "attitude", it is really not my style. Mine was a simple question - did you look at the patent description? If I were giving you attitude it would pretty different, believe me - I certainly wouldn't be here posting frame shots trying to show you.
  The white wire routed through the thick coil goes into the box and yes there is a picture showing this entering the box from a correct angle. The red wire is under and is covered by the coil but it is cut flush with the white one and it also comes from the GB - this doesn't look like a good guess to me and it also corrsponds with the patent concept. As I said, the patent is a concept description and the blocks are to be considered as such. An inventor will never reveal the key secret(s) to the device. Personally I don't trust the patent office at all as it is merely a "screening" system.
dllabarre
What I didn't find was the hot water heater that the pirate fella that got him banned said was there.
I could tell that quarktoo fella knew something about this so I was taking screen shots of what he was saying and he used the exact words that that pirate wrongly used to insult him when he set that pirate straight. If doing that will get you banned and important information deleted then that is proof of what quarktoo was saying about this web site suppressing information.
I got a hold of him in another forum and he gave me a simple experiment to do. He showed my why that ground wire is running up through the center of that coil and I'll be damned if that experiment didn't work exactly how he said it would.
I don't claim to be an expert on electronics but I showed it to someone that was and he said it was the strangest thing he had ever see. Quark says it is the real basis of the kapanadze device and showed me another place to prove that.
Looks to me like he was the only person that knew what he was talking about and got attacked and banned for it. My advice is find another forum Don since people here clearly have a different agenda.
Here is what quark was talking about.
Thank you Cowboy!
I had several conversations with QuarkToo.
He was right about many things.
Please post and/or PM me the test QuarkToo had you do in case your post gets deleted.
Thank you and tell QuarkToo I miss his insight.
DonL
