leo48
 ??? :o ::)
Guys want to go back to topic and talk about the device  Kapanadze and
leave the chat wasters?  ;D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
iceweller
There is no need for gas in a coil to do that - it works in air (would work in vacuum too as it is electrostatic):
http://www.youtube.com/watch?v=F4KSkSiYs50
http://www.youtube.com/watch?v=n9AYPQt8iwo
  Energy transfer through electrostatic field with receiving coil and/or just plate and unconnected wire. The suggestion here is that the ground wire must be long enough or the effect won't work. Passing any wire through a ferrite core inside the TC produces nice long sparks from the wire.
wattsup
Quote from: stivep on March 18, 2011, 07:04:31 PM
You are fighting and I'm working
Me too, I am working and no more time to fight. I will leave the fighting to others. Seems like I am always alone to do such things so now that there is a moderator here, it is his job.
@all
Regarding the recent photos of the TK device, I had put up those similar photos before @QT busted the bank.
The photo showing the TK coil removed from the device and on the table has the white wire that had to be snipped before it could be removed. If that wire went to the spark gap, why would they have cut it that short? besides, you can see the white is is multi-strand and not suitable for spark gap usage. They would have cut it further away to be able to re-splice it later. Cutting it that short would indicate that it was going straight into the green box and that the available wire length was therefore limited. Hence that short snipped wire.
Also, if that wire went to another wire on the same TK coil, there would have been no reason to snip it.
Also, the green wire from the spark gap takes a sharp left turn so it could be going to the wire coming out of the far end top right or it could also have gone to the outer coil. See image grab below.
@stivep
In the Green Box video, when TK is talking while he is standing in front of the Green Box, there is the fat guy who had held the TK coil in his hands inside the house. Well this fat guy in the background is with one of TKs helpers and he is poking around the device, tilting it and  then his is putting his hands on both ends of what I think is that green wire from the spark gap and the wire at top right and he was pulling on them to see if they were joined. Then TKs helper points to the two coils and the guys asks him something and the helper responds by shaking his head as if to say "no". Do you think you can figure out what they were talking about. This is about the only place they are really looking between the TK coil and the green box.
wattsup
cosmoLV
This is only a part of device schematics â€" i will not release all in one, but this part is real, no jokes no hides...
Little explanation:
resonator is bifilar coil on right side who are making sinus wave â€" this is the tricky part of device (will be released in some days)
above top right box are HV part.
transistor setup are most important with back loop to generator.
Keep your chakras opened :)
Light
i will not release
Who’s asking you for any releases, lifesaver??
But you're showing just a lack of any understanding â€" this’s a HV HF generator, they make them in schools now, you can light a lightbulb with it or make a sparks, and that's it…
So u r still here… ;D
