0 Members and 65 Guests are viewing this topic.
Pinoy_Tech
Quote from: dllabarre on March 27, 2011, 08:30:26 AM
For clarification:
The schematic shows a LM566 not LM556.
Did you get a message from cosmoLV telling you he mis-typed it and it's supposed to be LM556?
DonL
Hi DonL
Ops! my mistake, (typos he he)! It is still LM566 not 556... not received any.
thanks,
-jronel-
ramset
This is for the Guys that Give a $hit about the world!
Men with out Evil Agendas Or ulterior Motives!
THEY CAN'T STOP IT!!
No How, No Way..........................................
Tariel ,Pretty soon your invention will be a "Mute Point"!
The "Power" is on its way ,in many shapes and forms
this is just one of them!
http://inventorspot.com/articles/worlds_first_artificial_leaf_doesnt_look_leaf_it_acts_one
Runs On "Global warming Gas"[Carbon Dioxide}..................
Whats the secret Handshake Club Gonna do about this?
You "Calender Boys" Oughta wake up Too.......
Chet
Thanks Grandma
Shokac
Quote from: ramset on March 28, 2011, 04:35:18 AM
Chet
Nothing new,
http://bingofuel.online.fr/bingofuel/pmcjln.htm.
CO2 + H2O is in equilibrium with H2CO3
scratchrobot
Don't know if it is relevant but interesting.
The Arc
One of the most basic processes of the sun is the electrical arc. The sun's inner fission reactions act as a battery, releasing free protons and electrons, while the surface acts as a giant conductor.  As these streams of electrons reach the surface, they ionize ferrite at the surface, pushing it into the silicon layer of the photosphere, which in turn insulates the electrical flow to create giant electrical arcs between surface features.  The neon layer acts as a giant discharge lamp, emitting and adsorbing electrons. As the flow of energy (-) from the outside space passes through the atmosphere of the sun, it also seeks orientation along LOCAL magnetic alignments that run through the surface crust.  The LOCAL magnetic orientation at the very top of the surface crust is based upon the electrical flow, and magnetic orientation of the energy flow that occurred as that part of the sun's surface cooled.  As upper surface crust is eroded, lower areas of the crust are revealed and exposed to the surface.  If enough arcing occurs in one area, cracks can form at the surface, with resulting solar quakes and/or solar flares.  The surface "crust" is aligned and oriented along the electrical flow lines and take on a magnetic orientation and a set of alignment properties that existed as that part of the crust cooled.   That specific surface orientation, and the magnetic orientation of the suns core causes electrons to flow through surface structures.  The actual surface and deeper crust alignments will determine the flow of electrons passing through it, and/or the potential for electrons to pass through it.  When the magnetic poles of the core point toward the equator, these are times of intense magnetic storms and massive sunspot activity.  As the magnetic alignment of the core aligns with the spin axis of the sun, we get "quiet" periods, where sunspot activity decreases.  The sun takes 22 years to complete one turn in it's magnetic rotation, resulting in increased sunspot activity every eleven years.
http://www.thesurfaceofthesun.com/model.htm
Interesting ferrite properties.
Ferrites at microwave frequencies
http://www.scribd.com/doc/13359498/Modern-Ferrite-Technology-
Regards,
Scratchrobot
stivep
scratchrobot
thank you for the link.
very interesting.
From the last session of scientific discussion I was attending to  we have covered  subject of magnetic amplifiers and replication of the patent 6,362,718
http://jnaudin.free.fr/meg/megv21.htm
The information from that beautifully disclosed material by   Naudin
was found insufficient as a  prove of concept.
The conclusion that is applicable to any of our OU investigation:
1.When you see OU you must use Watmeter  to obtain the readings and/or confirm accuracy of the scope.
2. And/or use True RMS Volt meter.
3.Make sure  that  maximum  FREQUENCY!! of the measuring device is greater than the frequency of DUT.( device under test)
4.The scope does NOT!!! show you  the " end product" but the factors of the product.
In my example military grade Tektronix TDS654C is NOT!! capable with all of its advanced math functions to show what simple Watmeter or True RMS Voltmeter plus current measurement is capable of .
explanation:"End Product" is summary of factors. e.g
5. wherever is possible  use analog (needle ) based  devices.
note: these people are:
1. not friends who will please anyone. The scrutiny and critical approach is their future.
2, they not for OU or Free Energy. That means that till they see it they will not believe it.
Summary:
I like it very much. That is what I need, help with knowledge,critical approach but friendly atmosphere.
I do not care if they believe in OU or not......as long as they spend their own time analyzing OU.
When the time comes they will be very very surprised .
Wesley
