0 Members and 126 Guests are viewing this topic.
ramset
Core
It was deleted 3 different times in one day,[the last day of Q2]
And then I posted it in a "Quote", and that was deleted![4 th time]
Bill said he didn't mean to delete My quote in a PM.
I believe Bill mentioned the 3 times thing [I was unaware of that]
I can repost the whole "Quote" [I keep things like that]
If you like ?
Chet
Thanks Grandma
Pirate88179
Chet:
I have no problems with you re-posting that, as long as all of the attacks, insults, and other TOS violations are removed by you prior to posting.  As I said, I could have done that as well but I do not have the time and should not have to.
Thanks,
ramset
Ok Bill,
I don't have the Pics that are mentioned in the text
Here is the text -
Quote from: ramset on March 19, 2011, 01:25:45 AMWell,
At least he wasn't boring..........
Come on we're men here! almost every one is anonymous!!How the heck do you take an insult serious to a make believe name?? So things get a little feisty every now and then,it gets the creative juices flowing!!
This Guy has spent more time in this field,spent more of his life on this topic,than probably any Ten guys here put together,He brings things up that are soooo far out ,we think he's making fun[Flux comp],then we see...........
I can see a change  in this forum since his recent contributions .
Yeah, I wish he could curb the vitriol ,
BUT??
I like to laugh................................
Chet
PS
And yes Wilby,we are all a bit like Kids![sometimes]?
Buzz Quote:
ME TOO AND nobody LAUGHS HARDER THAN THEE!
[ Inset FAR MORE thunder and lightning than usual ]
You have shown reason, logic and a sense of humor Ramset. You alone notice that my chosen Quarktoo was trying to help those that could not help themselves. You alone hath shown compassion when he was spat upon by the robbers and [edit]of the Earth. My precious chosen one has been crucified by the humor challenged insecure Romans again.
Small Edit
The mortals shall now deal with the God of free energy directly and I shall smite those that defy me for eternity!
Quarktoo tried to get you to notice how the primary coil was discolored from heating because the Kapanadze mortal did not have a vacuum pump. This left a vacuum in the gas when it cooled and produced multipacitor effect which is key to a magnegas generator.
Quarktoo tried to teach you to look at the color of the box so you would discover for yourself the gas being used. When that failed, I had Cowboy (A temporary chosen worker)  post photos of the tanks. When that was ignored and smited, TheBuzz gave up on messiah's all together.
Quarktoo tried to get you to think about the ground wire running through the center of the coil so that you would discover the coaxial transformer. This is how kapanadze changes the frequency from very high electrostatic to low frequency current pulses.
Quarktoo hoped you would notice how a copper tube was hidden under the blue tape so you would see the magnetic gas being used and the real source of energy.
Quarktoo would have taught you about a phenomena outside Faraday's law which is ELECTROSTATIC inductance, not ELECTROMAGNETIC INDUCTANCE and has no basis of understanding in your Earthly mortal science. This would have allowed you to make fuel from water, diamonds from a fire extinguisher and energy from the vacuum.
Quarktoo would have given you a simple experiment that would have opened the doors for a lifetime of experimentation and invention because it uses the half of electricity called voltage and considered a phenomena to do work which is ignored by the physics professors and dependtards of the Earth.
TheBuzz shall now give you your first commands.
You shall first learn about the coaxial transformer here:
http://www.semelab.com/rf/documents/Push-Pull%20Circuits%20and%20Wideband%20Transformers.pdf
You will split that transformer in half so there is not electromagnetic inductance. This will form the coaxial autoformer of sorts which the kapanadze device is.
You shall use ferrite rings of no iron but instead plenty of ferrous oxide of low permanency - ( < 5000 ).
You shall form a tube of 4 inches of those ferrite rings.
You shall run a wire of a resonant tank circuit (at least 50Khz) through the center of the tube.
You shall parallel a second wire through the center of that tube connected to a resistive load. You will note that there is zero magnetic induction on the ferrite (Notice compass in photo below) yet nearly a complete transfer of energy between the two circuits. This is not a 1 turn transformer! You could use rings 1 foot in diameter and it would work as long as the length dimensions are proportional. When you are done scratching your head in confusion, you shall continue.
Then you shall look at the kapanadze coil and note that the ground wire is not the secondary, but the trinary of that transformer - that you blind mortals call a coil.
You shall research the magnetic properties of the gases Quarktoo noted but was suppressed byEdit Sorry missed that]
You shall build a coil of copper tube that Quarktoo showed and use the technique Quarktoo revealed to connect to that gas when {Edit} flamed Quarktoo and Quarktoo answered his baseless insults with factual how to information and was banned for it. If it has been deleted or suppressed, you shall hold the {Edit} accountable and force him to post what he hath stolen from the gentile masses.
http://books.google.com/books?id=QXot6BmRAAEC&pg=RA1-PR22&lpg=RA1-PR22&dq=nitrous+oxide+magnetic&source=bl&ots=Z_UfnC1buC&sig=JoCAxmeKHKnCHXAeFcepZ_cEKjA&hl=en&ei=LU13TZLVBYmosAP-zfW-BA&sa=X&oi=book_result&ct=result&resnum=9&ved=0CHEQ6AEwCA#v=onepage&q=nitrous%20oxide%20magnetic&f=false
Once you have reached that stage of human development, you shall punish the Romans and bow your heads on bended knee in thanks and THEN... Saint Buzz shall once again descend into the abyss of humor challenged insecure mortal fools to help you with the rest of your quest.
At this point, two people should be able to each hold one leg of a neon 4 feet from your copper tubing coil and it should glow to full brightness.
You should be able to attach one leg of a neon to a earthly ground and touch the other to the copper coil and it should not glow at all.
You should be able to hold one end of the neon and start a fire with the other end by placing a piece of paper between a hard metal object such as a razerblade and the free end of the neon. At this point, electricity should be running backwards.
While you do these experiments  {EDIT ]If you smite me or my chosen again, you shall be overinty THE DAMMED forever! Doomed to wander in the desert of ignorance led by fools for another 4000 years!
Saint Buzz shall now return to the heavens and bask under the light that shines from what is left of his many overunity golden stars after Ramset stole one of them years ago when TheBuzz tried to teach the first step of waterfuel to the fools using this electrostatic transformation and modulation process.
So shall it be said, so shall it be done.
NOTE - TheBuzz has not, does not, nor shall he ever give step by step monkey see monkey do information to dependtards. Rather, TheBuzz seek to teach the masses knowledge that cannot be suppressed by the man or his minions that drive away smart people and promote dependtards like unwitting puppets on strings to suppress OU for them.
Photo 1 - Shows how two wires running through a stack of FeO toroids produces nearly 100% energy transfer of a resonant circuit WITHOUT ELECTROMAGNETIC INDUCTANCE (note the compass pointing to true North? The white wire running through the toroid stack with both ends going to the lamp is NOT A 1 TURN COIL as some would wrongly claim. This is NOT the electromagnetic inductance you are familiar with.
Notice the primary and secondary circuits overlaid on the scope. This is to show that  there is not a phase change between primary and secondary wires and nearly 100% transfer of energy WITHOUT COILS OR ELECTROMAGNETIC INDUCTANCE. This is key to understanding the ground wire running through the center of the kapanadze coil.
The Scope hath had a slight skew to the right (no irony wasted on this defect) in the display since the first time TheBuzz connected it to the wheelwork of nature years ago. SaintBuss is presently poor after spending his life savings doing research full time for the unwashed for the last ten years but the scope shot is accurate in regard to phase.
Photo 2  - Shows overlay of primary and secondary and nearly 100% energy transfer without phase change with no coils or inductance.
Photo 3  - Shows the injury to the finger of Saint Buzz when he took one for the team on a lathe making the parts of his magnegas generator.
The information I provide you is far more valuable than those that are too blinded or controlled by their insecurity to even notice. Saint Buzz hates the smell of fear.
I
Thanks Grandma
Pirate88179
Chet:
All of those references to TK somehow having gas in the tube has been refuted by the member that knows TK...am I wrong on this?
(I'm sorry I can't recall that fellows name at this time...if I think of it I will edit my post accordingly.
dllabarre
Quote from: core on March 30, 2011, 05:14:57 PM
If it was deleted how did you get it?
-Core
I also save off relevant posts so as not to lose them.
DonL
