0 Members and 201 Guests are viewing this topic.
ramset
Wesley
Quote:
This video is showing misleading  configuration. That what you see  WORKS but does not work the way you see it
Sir ,
Which Video are you referring to ?
Thank you
Chet
Thanks Grandma
stivep
Quote from: ramset on April 02, 2011, 01:42:16 AM
Wesley
Sir ,
Thank you
Chet
video from Turkey
Quote I have mentioned is NOT a PART OF THIS VIDEO  but is approximate relation of what was happening behind if scenes.
Wesley
grizli
Quote from: stivep on April 02, 2011, 08:42:53 AM
video from Turkey
Wesley
Kapanadze Turkey video or ?
core
Quote from: Pinoy_Tech on March 27, 2011, 12:41:35 AM
As seen on diagram, pin #1 of IC556 appears to be connected to a common ground together with the negative rail on split psu.
If negative rail is grounded itself (other filter cap is useless), ................
   -- Pinoy_Tech --
I agree this is a useless setup that makes no sense. With Pin 1 grounded that capacitor off the PNP's collector is always shorted and becomes non-functional. A more practical spot for that capacitor may be between Pin 1 and ground.
Even with that capacitors in series with a center tap ground it is still shorted and this should neither subtract or add to the capacitance.
Respectfully,
Core
