0 Members and 187 Guests are viewing this topic.
scratchrobot
'transistor setup are most important with back loop to generator.'  ???
Maybe that's why he did not draw the lines and he use 2 different sources?
quote from first pdf-link i posted on previous page.
'The LM 566 delivers either an FM square wave or an FM triangular wave. However, this is not    important, since the square/triangular wave can be converted into a “good” sinewave with the use of a simple RC filter.'
I don't know what an RC filter is but i will  ;D
scratchrobot
poynt99
There is another correction to the diagram I posted above.
The LM566 Pin4 input on the left side should be Pin6.
.99
forest
if the output is high frequency and unstable voltage the best way to step it down is to modulate it to AC and use transformer plus diode bridge and large cap, right ?
baroutologos
So in summary, just delete the ground symbol at the LM566 pin1 as pinoy_tech showed, and the circuit is fine.
That circuit posted by CosmoLV is actually a fixed frequency resonator or inverter setup.
if the fixed frequency is not the wanted thing, I have created resonators that greatly surpass this schematic being relative low frequency (10-50Khz) and low voltage (1-2Kv) thus creating a strong oscillating signal in a given coil for given power consumption.
The point of the given schematic is...????
scratchrobot
I don't have transistors to do experiment yet so i did it on www.falstad.com/circuit/
http://www.youtube.com/watch?v=BpuJW1t9Z4U
Maybe the point is the fixed frequency ???
