0 Members and 254 Guests are viewing this topic.
nickle989
Here is a tip ... most may already know.
If you are using an insulated wire that has rating of 600v or whatever .. then you are loosing radient energy and creating a barrier thus making it harder to achieve any results.  Air is also a good insulator so distances are very much important.  Even wire that is rated for 12 volts has a high insulating factor because of the amps that are used on 12v systems.
I use magnet wire where ever possible.  If stranded is needed make an enamel dipping tank or runner.
The water pipe coming out of the ground would also be galvinzed.  Mineral componets of the water also important for conductivity.  How do large scale Hydro lines work ... High voltage AC pumped through the lines .. but no ground to complete .. there is a ground grid at the transfer station and on your house.  In Manitoba hydro uses DC lines for the long distance and then converters to AC for the local distribution.
So there are easy ways of picking up electical power and why some reported "free energy" does not work in all areas.
Where does all the lighting strikes go .. into the ground to charge up the big old battery.  What do we do with all of our ground waste energy?
baroutologos
IMO this thread has died now...
No one has ever so far pointed out any procedure able at producing that we say overunity, neither was stubled upon to any by my experimenting or of others.
Also few people now and then, have claimed to know something, again failing to even faintly point out such a imaginary procedure, let alone to explain the workings of it.
But the sadest of all is the lack of experimentation, handling the topic as UFOlogy by adding only theory upon theory and constantly arguing each other so as to reach some 420pages with less than 5-10 pages or primary experimatation.
Perhaps this was meant to be by the very start. Kapanadze's urban legend thread and his wonderful machines that are supposed not to see  the day of light (even at conceptual level)
So... keep going. 500 hundred pages is near!
ramset
Bart
Its Not Dead ,Its Evolving......................
I think I heard a Heart beat??[In the Mens Bathroom :o]
Scary !!
Well there will be lots to discuss soon.............
Chet
PS
I would love to hear what Wesley has to say about Shokacs
Pic! BTW ShowKac NFG ON The VID IMHO
Thanks Grandma
stivep
Quote from: ramset on April 05, 2011, 09:56:26 AM
Bart
Scary !!
Chet
PS
Quick :
As I'm ruining out to make some money.but I'll be back
wire inside coil is capacitor
You have factor of capacitance  between wire and tube but you have............ o   fu.k
.......... dont take me  for my tong...........
I think I have got it.
1. capacitance between wire and tube
2.capacitance between winds of wire ( each individual circle of wind- between themselves)
3.capacitance between tube winds  ( each individual circle of wind- between themselves)
4. if you connect tube than you dealing with bifilar  is'n that one of possible factors of  controversy of TK coil?
depending on how you connect the ends of the tube !!!!!
Whatever Shokac did it does not matter for now because I did not read it nor analyze it as of yet.
what matters is that I haver got a hint.!!!
I'll Be back
Wesley
PS: capacitive coupling ( Vladimir Utkin- my Hero)
think about it
Ok I'm back instead of posting new post I just continue this one
Lets think.
concentric cable= wire in copper tube.= shielding
Picture by Shockac is wire in coper tubing
1.We can threat it as coaxial cable only if we ground shield
2.Coaxial cable  has SW(standing wave) and SWR (SW-ratio) is the measurement of power flow of EW.(electromagnetic Waves)
When energy can not go out completely because of impedance
of coax than part of this energy is reflected and returned back
SWR 1:1 is ideal for coax.
With the length of the coax you may notice with your  hand warm spots. The spots are the concentration of energy points with SWR at high. Part of this energy is lost as heat in these points. the biggest impact is the energy returned to the power source ( Power transistor or tube or circuit)
Transmatch/ antenna tuner/ output resonance circuit
is the  impedance matching device to  tune impedance of the load(say e.g.antenna) to the impedance of power amplifier( say power transistor or tube with resonance circuit)
In most common scenario it is 50 ohm standard.
wire in the tube is almost ideal coaxial cable  (but does not  have 50 ohm impedance. And only if the shield is grounded.
So let's say Shocac show picture of:
a.coaxial cable...with high SWR
b.coaxial cable with out connected ground
c.concentric capacitive coupling component
d.bifilar.
e. leaky coaxial cable ( if we make  holes in geometrical spacing in the inner service of the pipe so the holes are directed to the main primary coil.)
Note: do not confuse yourself with the word "primary"
"Primary" in here  does not  mean "primary winding"
but does not eliminate it's role as primary winding if one want's to use it as "primary winding for the circuit "
if "a"
than
-shield will prevent wire inside to interact with the main primary coil  inside
-but shield will interact with  main primary coil inside The amount of SWR will determine
hot spots of power and the number of hotspots( edys current in tubing)
- part of the energy will be reversely reflected to the source as BEMF cosing phase shift
- interaction will create response of the main coil(the one inside tubing)only in these points ( very interesting)
if we go further  we may drill holes in the place of hot spots to let energy out and interact with main primary coil
Note:The problem I see in here is stability of the frequency as the position of hot spots and/or holes depends  of frequency delivered
if "b"
than
Outer shield will no longer be shield but second plate of capacitor. Question than is how the electromagnetic wave is spread and or what is the characteristic of propagation
(Next Sunday I will discuss it  on scientific  meting)
-there will be secondary electromagnetic field created around the tubing,  as the reflection of that what is going on in inner wire.
if "c"
than
-this is only pointing to  the existence of such capacitive coupling in any of these examples, but the role of such coupling in anyone of these examples  will add to different effect as the end result.
-So we have capacitive coupling between two coils from  which the tube is not connected anywhere at all .If we deliver frequency of length equal space between wire and tube than
"maximum every sign shape in within the tube will create hot-spot om the tube.but than frequency should be in GHz( example 1.2GHz= wavelength 23cm) In reality we do not deal with such diameter of concentric nor coaxial.Even diameter of coil by itself is nowhere near this in TK device.
Note: square wave signal from generator contains singular sign wave components  from low  to GHz
in each of the square shapes  so we may or may not be dealing with interaction of components in regards to that interaction
That might explain why Square shape was utilized at the beginning of  by everyone including me and TK.
-but we have to remember that almost 100% of direct interaction of the wire  is limited only to tubing and tubing is direct interface to anything ( if any)
than
wow......... it is getting interesting here.. uch.............
remember that controversy with gas? ..........
how about if we  connect the wire inside the tube with edge of the tube at the end......
and than we use electrical tape to rap an" just the insulation of the wire without copper inside" for others "
to believe that there is"outgoing connection from tubing coil.
what did we achieved is bifilar and than we have to play with to ends inside green box.
-and what if we in did made connection of end of the wire with end of tubing... we will still maintain capacitive coupling altered by shape ,frequency (properties of signal delivered)
-and what if instead "fake  wire"(insulation without the wire) we take real wire but not connect this wire to point of connection of tube and inner wire....
now we can play with three ends
one is wire inside tube
second is the tube end
third is the real outgoing wire
lets see what  happened if we never connected anyone of them
but rap them together keeping them insulated( and fake connection by using electrical tape)
we than-
WE HAVE CREATED 3WAY CAPACITOR or three plates capacitor something like capacitive bridge.. or capacitive switch.
please picture
(from the left side wire connected to plate)
than
(plate inside-in the middle with wire  connected)
than
( from right side wire connected to third plate)
for me it is that what is going on with
earth(plate at left)
my piece of wire e.g antenna at say 100f high)
and ionosphere
the difference of potential between earth and the ionosphere is  36000V  so the antenna (in the middle) represents responsive charge with regards to distance to  one of them
note" the problem that I have with that  philosophy id that capacitive coupling relation is significant between wire inside tube and tube but is small between the third wire ( if one  exist)
As the point of
"contact=diameter of third wire= gauge"
represents small square mm area
but concept is interesting as this would create sort of KBE if "capacitive transistor"
if "e"
than
leaky coaxial cable is very much known in  the field of communication it interacts if improperly installed or power level is  to high  with everything in subways cosing a lot of problems
Please find by yourself in the most comfortable language information about leaky coaxial cable
wattsup
Quote from: baroutologos on April 05, 2011, 09:45:50 AM
Yes, I agree. I dream one day to be the post number 10,000. What a glorious day that will be! lol
For me, experimenting now happens two ways. 90% with the mind doing all the work and only 10% practical benchwork. In the beginning, for me anyways, it was the reverse. 90% benchwork and 10% mindwork.
The great thing about mindwork is that you can analyze very quickly an idea for a set-up from all angles and only once you have a good idea on the outcome being interesting enough, then you do the benchwork.
But in TKs case, it is not us doing our own thing, but us trying to figure out TKs thing. That is not the same as someone doing his own works and of course it requires much more effort to try and analyze all the hidden factors possible.
If we all took the open source method seriously enough, then TK would not have even qualified for our attention since his commercial effort and impending silence goes smack against the open source and we should have just dumped him right away and do something else with our energies. But this is hard to do when you see a nice video showing bright lights while the battery is removed.
wattsup
